소개
Remove the old glass from the digitizer and replace it with new glass without replacing the assembly
필요한 것
Use a plastic opening tool to pry the home button up from the display assembly.
The bare display assembly remains.
Make sure to remove the protective cover from your new display assembly as well as the protective cover on the back of the LCD.
Note: When reassembled, the screen may not turn on. Try fixing this by plugging your phone in, and holding down the power and home buttons at the same time for 20 seconds.
Using a hot plate (cooktop) and a temp gun heat up the LCD to about 150-160 degrees. I also soaked the display in Duck Brand adhesive remover. Working a few pieces of glass at a time soaking and heating. I used a small flat head, plastic pry and a high guitar string to remove all the glass from the LCD. Be careful not to twist the LCD assembly.
다른 15명이 해당 안내서를 완성하였습니다.
댓글 한 개
i've buyed this yaxun LOCA adhesive remover, to remove the screens glue, the thing is that how you avoid damaging the display? i found that the display was divided in two parts when i started removing the glue, so the glue remover got between the two parts of the display and with what type of glue you secure the frame? again the one i've buyed is yaxun 7000 glue multipurpose glue and is not a tight cohesion between the frame and the digitizer
