이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the home button ribbon cable. The cable includes the switch, but not the button cover.
필요한 것
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
Regardless of the tool you use, you need to be sure you pull up the entire display.
If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
이 단계에 사용된 도구:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the following two screws securing the metal battery connector bracket to the logic board:
One 1.8 mm Phillips screw
One 1.6 mm Phillips screw
Remove the metal battery connector bracket from the iPhone.
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following screws securing the front panel assembly cable bracket to the logic board:
Two 1.2 mm Phillips screws
Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
Front-facing camera and sensor cable
LCD cable
Digitizer cable
Remove the front panel assembly from the rear case.
Remove the two 1.3 mm Phillips #000 screws securing the home button bracket to the display assembly.
NOTE: When reinstalling the two 1.3 mm Phillips #000 screws, take care not to over tighten them as they can penetrate the other side of the display.
다른 161명이 해당 안내서를 완성하였습니다.
댓글 3개
You had mentioned the phone running hot if the battery wasn't disconnected in the correct sequence, how is this resolved? Also, the phone after lcd assembly replacement is unresponsive, I have gotten a dinging sound that repeats but nothing on the screen...iTunes recognizes the phone but I get nothing on the screen, I've tried reassembling several times with no luck, this is not my phone, I've done many repairs on iphones in the past
and never had this problem...please help, it's an iphone 5s
what kind of adhesive is used on the home button cable - the one with two metallic spherical plates that face the inside of the phone?
Ajaz Karim - 답글
one of the screws on the home button is unscrew-able and i had to get my dad to do it and he could not even do it, im replacing the one on my old iphone to my new replacement screen and know one had ever touched it before, any ideas on what i can do?
