주요 콘텐츠로 건너뛰기
iPhone 5c Logic Board Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iPhone 5c Logic Board Replacement, Logic Board: 1 단계, 이미지 1/2 iPhone 5c Logic Board Replacement, Logic Board: 1 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the audio control cable connector from its socket on the logic board.
    • Disconnect the rear facing camera cable connector from its socket on the logic board.
  2. iPhone 5c Logic Board Replacement: 2 단계, 이미지 1/1
    • A small piece of tape may obscure the logic board grounding clip. If so, use a pair of tweezers to remove the tape.
  3. iPhone 5c Logic Board Replacement: 3 단계, 이미지 1/2 iPhone 5c Logic Board Replacement: 3 단계, 이미지 2/2
    • Remove the following screws securing the logic board grounding clip to the rear case:
    • 1.2 mm Phillips #000 in the top side-wall
    • 2.5 mm Phillips #000
  4. iPhone 5c Logic Board Replacement: 4 단계, 이미지 1/1
    • Use tweezers to remove the logic board grounding clip.
  5. iPhone 5c Logic Board Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Standoff Screwdriver for iPhones
    $5.49
    구매
    • Remove the following screws securing the logic board to the rear case:
    • Two 2.3 mm Phillips screws
    • Three 2.7 mm standoff screws
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  6. iPhone 5c Logic Board Replacement: 6 단계, 이미지 1/3 iPhone 5c Logic Board Replacement: 6 단계, 이미지 2/3 iPhone 5c Logic Board Replacement: 6 단계, 이미지 3/3
    • Holding the phone level, lift the bottom end of the logic board up enough to grasp it with your fingers.
    • Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board.
    • Remove the gold-colored contact cap from the threaded post in the rear case, and set it aside.
  7. iPhone 5c Logic Board Replacement: 7 단계, 이미지 1/2 iPhone 5c Logic Board Replacement: 7 단계, 이미지 2/2
    • Flip the logic board up toward the volume control buttons to expose the antenna connector.
    • Do not try to remove the logic board from the rear case yet, as it is still connected by an antenna cable on the back.
  8. iPhone 5c Logic Board Replacement: 8 단계, 이미지 1/1
    • Disconnect the antenna connector from the back of the logic board.
  9. iPhone 5c Logic Board Replacement: 9 단계, 이미지 1/1
    • Remove the logic board from the rear case.
결론
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,749 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,732개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 224
