주요 콘텐츠로 건너뛰기
iPhone 5c SIM Card Replacement
필요한 것
  1. iPhone 5c SIM Card Replacement, SIM Card: 1 단계, 이미지 1/2 iPhone 5c SIM Card Replacement, SIM Card: 1 단계, 이미지 2/2
    • Shut your phone down completely before removing the SIM card and tray.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press the SIM card eject tool inwards to eject the tray.
    • This may require a significant amount of force.
  2. iPhone 5c SIM Card Replacement: 2 단계, 이미지 1/1
    • Remove the SIM Card tray assembly from the iPhone.
    • During reassembly, ensure that the SIM card is in the proper orientation relative to the tray.
결론
다른 42명이 해당 안내서를 완성하였습니다.
Walter Galan
694,573 평판
안내서 1,203개 작성하였습니다
댓글 2개
How would you replace the sim card try if the tray is jammed? Is there a way to open up the phone and replace it internally?
Patricia Lovera - 답글
You can try opening the phone and removing the SIM eject lever, or seeing if its obstructed somehow, with this guide. good luck!
Sam Goldheart -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 15
30일 전: 39
전체 시간: 17,206
