주요 콘텐츠로 건너뛰기
iPhone 5c Logic Board Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. iPhone 5c Logic Board Replacement, Get Informed before Repair: 1 단계, 이미지 1/1
    • With a grand variety of colors to choose (white, blue, pink, green, and yellow), we decided on blue
    • What difference is there between the iPhone 5c and the iPhone 5? We are going to discuss this. To begin, the back cover is composite plastic, it seems that our work is really cut out for us here...
    • The technical specifications include:
    • Apple A6 chip system (SoC)
    • 4 inch retina screen (1136-by-640-pixel resolution at 326 ppi)
    • 8 megapixel iSight camera
    • 4G LTE connectivity
    • 16 or 32 GB storage capacity
  2. iPhone 5c Logic Board Replacement, SIM  Card: 2 단계, 이미지 1/2 iPhone 5c Logic Board Replacement, SIM  Card: 2 단계, 이미지 2/2
    • Remember to take out the SIM tray
    • As promised, each port, button, and physical slider has changed from metal to plastic.
    • "Very cheap", per chance?
    • These parts aren't all plastic, if not that they also look like much more than that...
    • The volume buttons are considerably large, and so are the 10-hole microphone grid and the 16-hole speaker grid (1 and 4 holes respectively)
  3. iPhone 5c Logic Board Replacement, Unscrewing the Screws: 3 단계, 이미지 1/1
    • These super small Pentalobe screws are slightly different than those of the iPhone 5 and 5s.
    • Here is how the Pentalobe screws compare in size with an Australian coin with an undetermined value.
  4. iPhone 5c Logic Board Replacement, Opening the Iphone: 4 단계, 이미지 1/1
    • Now with a suction tool, we lift the screen.
    • Do not lift the screen completely so that you do not break the screen cables.
  5. iPhone 5c Logic Board Replacement, Battery: 5 단계, 이미지 1/3 iPhone 5c Logic Board Replacement, Battery: 5 단계, 이미지 2/3 iPhone 5c Logic Board Replacement, Battery: 5 단계, 이미지 3/3
    • Now we UNSCREW the two marked screws (see image).
    • We DISCONNECT three cables (designated by the green markings).
    • Remove the black battery cable with CAUTION.
    • Disconnect the cables with CAUTION. When removing the cables, do so WITHOUT FORCE.
  6. iPhone 5c Logic Board Replacement, Display: 6 단계, 이미지 1/1
    • Remove the following Phillips #000 screws that hold support to the front panel assembly to the logic board.
    • Two 1.3mm screws
    • A 1.7mm screw
    • A 3.25mm screw
    • It is especially important to keep track of your screws for reassembly. Accidentally using a 3.25mm or 1.7mm screw in the lower right hole causes significant damage to the logic board of a phone that already doesn't start correctly.
    • Exercise caution to not screw the screws in too tightly. If you are having issues when you are securing them, you may have the wrong size. If this is the case, DO NOT FORCE THEM.
  7. iPhone 5c Logic Board Replacement, Display Cables: 7 단계, 이미지 1/2 iPhone 5c Logic Board Replacement, Display Cables: 7 단계, 이미지 2/2
    • Use a plastic spudger tool to disconnect the front camera and the connector for the sensor cable.
    • Make sure to put the spudger only on the connector, and not on the surface of the logic board.
    • Remember that you must undo ALL of the cables on the logic board.
  8. iPhone 5c Logic Board Replacement: 8 단계, 이미지 1/3 iPhone 5c Logic Board Replacement: 8 단계, 이미지 2/3 iPhone 5c Logic Board Replacement: 8 단계, 이미지 3/3
    • Use a plastic spudger to disconnect the LCD cable from its connector.
    • The LCD and digitalizer connectors are in the same ensemble as the cables, so when using the spudger lift the LCD cables and disconnect both cables. Double-check that the two cables are completely disconnected before removing the screen.
    • To reassemble your cellphone, the LCD cable can leave the connector. The white screen, or white lines in the screen can be caused by a loose connection between the LCD and its connector. If this happens, go back and connect the cable and restart your phone. The best solution to a flickering screen is disconnecting and reconnecting your battery.
  9. iPhone 5c Logic Board Replacement: 9 단계, 이미지 1/1
    • Remove the front panel from the back case.
  10. iPhone 5c Logic Board Replacement, Remove All Screws: 10 단계, 이미지 1/1
    • Remove all of the Phillips #000 screws (2.0mm) that are fixed to the logic board.
    • Remove all of the screws and connector cables.
  11. iPhone 5c Logic Board Replacement, Logic Board Front Part: 11 단계, 이미지 1/2 iPhone 5c Logic Board Replacement, Logic Board Front Part: 11 단계, 이미지 2/2
    • The front part of the logic board:
    • Apple A6 APL0598 application processor
    • Qualcomm MDM9615M LTE WiFi module
    • Qualcomm WTR1605L LTE / HSPA + / CDMA2K / TDSCDMA / EDGE / GPS Tranciever
    • While not as flashy as its newest counterpart, we have to admit a certain affection for the A6 chip.
    • The iPhone 5c contains 1 GB of ram DDR2 with the A6 system chip.
  12. iPhone 5c Logic Board Replacement, Logic Board Rear Part: 12 단계, 이미지 1/1
    • The back portion of the logic board:
    • Toshiba THGBX2G7B2JLA01 128 Gb (16 GB) NAND flash
    • Apple 338S1164
    • Apple 338S1116 Cirrus Audio Codec
    • Qualcomm PM8018 RF power management IC
    • Broadcom BCM5976 Tactile touchscreen driver
    • Murata 339S0209 WiFi module (based on the Broadcom BCM4334)
결승점
다른 11명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
es en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Pablo
회원 가입일: 12/26/17
615 평판
안내서 1개 작성함
Fixlikeit Fixlikeit 회원
Business
1 회원
안내서 2개 작성하였습니다
댓글 한 개
This is a review that’ll get you about half way there, and then you’re on you’re own trying to figure out a whole bunch of other things… Kind of sucked.
Anna Eijsbouts - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,804
