주요 콘텐츠로 건너뛰기
소개
Prereq only
  1. iPhone 6 Front Panel Assembly Replacement, Manual Opening Procedure: 1 단계, 이미지 1/1
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  2. iPhone 6 Front Panel Assembly Replacement: 2 단계, 이미지 1/1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  3. iPhone 6 Front Panel Assembly Replacement: 3 단계, 이미지 1/2 iPhone 6 Front Panel Assembly Replacement: 3 단계, 이미지 2/2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  4. iPhone 6 Front Panel Assembly Replacement, Opening up the phone: 4 단계, 이미지 1/3 iPhone 6 Front Panel Assembly Replacement, Opening up the phone: 4 단계, 이미지 2/3 iPhone 6 Front Panel Assembly Replacement, Opening up the phone: 4 단계, 이미지 3/3
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  5. iPhone 6 Front Panel Assembly Replacement: 5 단계, 이미지 1/3 iPhone 6 Front Panel Assembly Replacement: 5 단계, 이미지 2/3 iPhone 6 Front Panel Assembly Replacement: 5 단계, 이미지 3/3
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  6. iPhone 6 Front Panel Assembly Replacement: 7 단계, 이미지 1/1
    • Remove the metal battery connector bracket from the iPhone.
  7. iPhone 6 Front Panel Assembly Replacement, Disconnecting the battery connector: 8 단계, 이미지 1/1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  8. iPhone 6 Front Panel Assembly Replacement, Removing the front panel assembly cable bracket screws: 9 단계, 이미지 1/1
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
  9. iPhone 6 Front Panel Assembly Replacement: 10 단계, 이미지 1/1
    • Remove the front panel assembly cable bracket from the logic board.
  10. iPhone 6 Front Panel Assembly Replacement: 11 단계, 이미지 1/2 iPhone 6 Front Panel Assembly Replacement: 11 단계, 이미지 2/2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
  11. iPhone 6 Front Panel Assembly Replacement: 12 단계, 이미지 1/2 iPhone 6 Front Panel Assembly Replacement: 12 단계, 이미지 2/2
    • Use a spudger or a fingernail to disconnect the home button cable connector.
  12. iPhone 6 Front Panel Assembly Replacement: 13 단계, 이미지 1/2 iPhone 6 Front Panel Assembly Replacement: 13 단계, 이미지 2/2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  13. iPhone 6 Front Panel Assembly Replacement: 14 단계, 이미지 1/2 iPhone 6 Front Panel Assembly Replacement: 14 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  14. iPhone 6 Front Panel Assembly Replacement, Separating front panel assembly and rear case: 15 단계, 이미지 1/1
    • Remove the front panel assembly from the rear case.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
다른 13명이 해당 안내서를 완성하였습니다.
Walter Galan
678,436 평판
안내서 1,203개 작성하였습니다
댓글 3개
Undo the last edit, I was not trying to modify this guide
rwmj5 - 답글
how about replacing the battery ?
LON HOSKINS - 답글
Hi. I messed up with the screws in the cover guard sheet for the display ribbon and my iPhone 6 plus isn't turning on. Does that mean the logic board is dead or the battery ? Should I throw the phone in the garbage can ?
nzf - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 2,790
