주요 콘텐츠로 건너뛰기
iPhone 6 Pentalobe Screws Replacement
필요한 것
  1. iPhone 6 Pentalobe Screws Replacement, Pentalobe Screws: 1 단계, 이미지 1/1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
결론
다른 100명이 해당 안내서를 완성하였습니다.
Walter Galan
694,492 평판
안내서 1,203개 작성하였습니다
댓글 8개
What size screwdriver do I need to remove these screws?
ronrola - 답글
P2 Pentalobe Screwdriver
sbrown9615 -
really? follow these steps in reverse to reinstall? it already is laughably short...
beautron7 - 답글
also how is this moderate difficulty?
beautron7 - 답글
I have the correct screwdriver, but after taking out the original pentalobe screws, they will not screw back into the iPhone. Really bizarre. Do these screws get easily stripped?
dcs Bu - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 26
30일 전: 124
전체 시간: 64,469
