주요 콘텐츠로 건너뛰기
iPhone 6 Plus SIM Card Replacement
필요한 것
  1. iPhone 6 Plus SIM Card Replacement, SIM Card: 1 단계, 이미지 1/2 iPhone 6 Plus SIM Card Replacement, SIM Card: 1 단계, 이미지 2/2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force.
  2. iPhone 6 Plus SIM Card Replacement: 2 단계, 이미지 1/1
    • Remove the SIM Card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
결론
다른 33명이 해당 안내서를 완성하였습니다.
Walter Galan
694,561 평판
안내서 1,203개 작성하였습니다
댓글 2개
This granny jammed the SIM card into unlocked iPhone 6s + without the metal slide Is it possible to retrieve it?
Bee Ring - 답글
Hi Bee Ring! If you’re not having any luck shaking the phone to get it out, try inserting a piece of tape in to the slot, double-sided if possible, to try to grab the card, you can also try long thin tweezers. You might also take it down to your provider and see if they have any tricks. If it’s absolutely not coming out, you may need to open the phone, you can follow this SIM eject lever guide, you should need to remove the screen, just open it and look at step 21. You can try to push the SIM card out of the slot with a toothpick, you may need to remove that eject lever. Best of luck!
Sam Goldheart -
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 40
전체 시간: 24,906
