소개
Learn how to replace your iPhone 6 Plus screen. This part comes with the front-facing camera, earpiece speaker and sensor cable already installed, making for an easier repair.
All you need to do is remove the old screen and transfer the home button to the new screen, in order for Touch ID (fingerprint scanning) to function.
동영상 개요
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
Close the handle on the iSclack, opening the suction cup jaws.
Place the bottom of your iPhone in between the suction cups.
Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
If you don't have an iSclack, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the two 1.8 mm Phillips screws securing the home button bracket to the front panel.
Carefully wedge the tip of a spudger underneath the home button connector cable.
Gently move the spudger across to separate the home button connector cable from the adhesive securing it to the front panel assembly.
Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
The screen remains.
Compare your new replacement part to the original part. You may need to transfer remaining components (such as the two rubber grommets at the bottom of the screen) before installing.
다른 734명이 해당 안내서를 완성하였습니다.
댓글 95개
I have original home screen button, but the panel and home button cable was part of what was damaged on the phone. With that in mind will it still work with original home screen button, but replacement panel?
Pot Kerwin - 답글
This is a tough one. I do not know that you'll be able to salvage the Touch ID functionality of the home button with the connector being damaged. You may need to purchase iPhone 6 and 6 Plus Home Button Assembly and iPhone 6 and 6 Plus Home Button Gasket. This will no longer retain the Touch ID functionality though.
I will be testing this out myself as soon a I get a new touchID cable/along with the LCD Panel. I did a screen replacement, all went well and works great, however I punctured the TouchID cable when prying it off of the old display.
I ordered a new cable with the panel, as I understand it as long as you have the ORIGINAL TouchID assembly which I do, after replacing the cable it should work!
Instructions are incomplete ! You also have to remove the aluminum plate and the rear camera/speaker assembly.
Also, my touch ID does not work anymore :/ nothing was damaged and plug is connected. Resetting the phone made no difference.
Why would it not work if I used the same Home Button and logic board?
hey having the same problem with my touch id.. did you ever find a solution?
