주요 콘텐츠로 건너뛰기
소개
Prerequisite guide for disconnecting the battery connector.
    • Remove four tri-point Y000 screws securing the lower connector bracket, of the following lengths:
    • Three 1.2 mm screws
    • One 2.4 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  1. Remove the lower connector bracket.
    • Remove the lower connector bracket.
  2. Use the point of a spudger to lift the battery connector out of its socket on the logic board. Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to  the phone. Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to  the phone.
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Evan Noronha
회원 가입일: 2015년 02월 05일
179,476 평판
안내서 177개 작성하였습니다
iFixit iFixit 회원
Community
107 회원들
안내서 9,563개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 664
