소개
Follow the steps in this guide to remove or replace the LCD shield plate backing the display on an iPhone 7.
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
¿Cuántos segundos son los recomendados?
Sesenta segundos
Absolutely. Just don’t overdo it—the adhesive usually softens up pretty easily. If you are experienced with a heat gun, you’ll have no problem. (If you are inexperienced, it’s easy to cook the display or cause other damage.)
If i use this process, will iphone 7 still be sealed, water/ splash resist after that?
Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Can I use a cpb heating pad to soften the adhesive ? If yes how much time and temperature ?
Will doing this compromise the screen protector (Zagg) that I have on my phone?
Eric Nance - 답글
Hairdryer worked for me but I needed to use a razor to pry it open at the bottom then used the spudger
Attach a suction cup to the lower half of the display assembly, just above the home button.
A wide, single strip of packing tape, well placed, will solve this for you. :)
Mimic44444 - 답글
Last comment works well. Thank you !
Using packing tape for a cracked screen should be included in the description in Step 3.
Cracked screen is most probably the reason you are replacing it.
I agree that using packing tape for a cracked screen should be included in this steps description. I don’t have wide but turned mine horizontal and that worked great.
Mary Knapp - 답글
Bekomme die Oberschale einfach nicht runter! Trotz mehrmaligem erwärmen durch den iOpener und seitlichen bewegen! Weiß nicht mehr weiter!
Wouldn’t that screw up the Touch ID?
Rexx Havok - 답글
Pull up on the suction cup to create a small gap between the display assembly and the rear case.
Insert the flat end of a spudger into the gap.
This was SO hard for me to do with the spudger. I couldn’t get a gap to insert it because my phone was so cracked (even though I used tape on the front) to get a solid seal with the suction cup. I ended up taking a VERY thin knife and inserting it straight down to make the initial break that allowed me to insert the spudger.
I’ve given up using a plastic spudger to try to open any of these phones. I use a metal one with a flat base and a very sharp end…close to a razor. As long as I’m careful, it won’t slip and scratch the base. It’s much easier than using these plastic spudgers.
mcr4u2 -
I confirm that the plastic spudger it’s not the best tool for this operation. I suggest to use a larger metal tool like a “Jimmy” or “iSesamo open tool” (I used the first one)
Cristef -
Im trying to get the screen off right now and my phone is not cracked and its still a pain
Using a blow dryer was extremely helpful and using the suction cup towards one of the lower edges was also helpful
This is not working for me. How long does the heat need to be applied? Still trying right now…. =/
Apply hair dryer for at least 1 minute. I inserted the tip end of a thin mini screwdriver and with some force, pryed it open and inserted my plastic spudger to continue the separation process. It worked, just be patient.
Please wear protective glasses! My iPhone glass was severely cracked, when separating the glass a corner area of broken glass exploded in my face. Apply transparent tape over the broken glass to contain the shards.
I second Jessica’s January 8 comment. I just finished a battery replacement on my iPhone 7 and this step was the most nerve-wracking part. I ended up using a sharper (but not razor-sharp) metal object to get this done with confidence (tried the spudger and guitar pick but not thin enough). The tool I used was the exact duplicate of what iFixIt calls “iSesamo Opening Tool” in their tool selection. I did the heat up with a hair dryer (after attempts with an iOpener hot pad) and the secret (as Jessica also noted) was to not use the angle of attack shown in the pictures, but to push it in more vertically along the bottom edge while pulling up on the suction cup. From there you can easily lever the tool to the lower angle-of-attack (as shown in the picture). I actually used the metal tool for most of the perimeter as well, just don’t go deep (you don’t need to). Notes: my display was intact, and I was able to pull up fairly hard with a glass screen protector still on it.
This is frustrating. I heated the lower edge with a hair dryer for 1 min on high about 3-4 times. In between each heat cycle, I rocked the suction cup back and forth. I was eventually able to create significant space for the provided tool. This takes a lot of patience. Once the space was created, it was very easy to remove the screen.
use a fingernail, then the blue tool, then the spudger
The iOpener worked just fine for me. Had to keep it on for a few minutes. I also was able to get the suction cup seal right close to the edge, over top of the home button for added leverage. Used the blue tool and transitioned to the spudger. Slow, steady pressure…and patience. ;)
Unable to open an iPhone 7 display assembly. Used gell pack at 150 degrees F. The phone wouldn’t budge when I used the iFixit suction cut. Part of the problem is that the cup doesn’t adhere for long before it looses suction. I suspect it would work better on unbroken glass, but that doesn’t help me now. After spending a lot of time at this, I changed heating methods to a hot air heater. I raised the temp of the bottom end of the phone to, ultimately, 175 degrees, and used a variety of tools to try to pry the glass apart enough to get a spudger (or anything) in, but it didn’t even lift enough for a double-edged razor blade to get in. I’ve been trying this for hours now, and about to give up and throw a lot more money at this to have a service perform the work. I figured that 175 was as high as I should need to go to soften the adhesive without damaging the electronics. Should I have gone higher? I see no mention of measured temps in any instructions or comments.
Have you tried applying tape to the broken screen? This will help a lot with keeping the suction cup on it.
It doesn’t need to get very hot; pulling up on the display is mainly what does the trick. Make sure the two pentalobe screws have been removed and then try the tricks in this step. If all else fails, superglue the suction cup to your display and let it cure, and then pull. Keep in mind you only need a tiny gap to insert a plastic pick and start cutting the adhesive. Good luck!
The trick I found, was to add packing tape right across the bottom over the home button then use hairdryer on the end, then suction cup on the very bottom and it lifted enough to get a gap. No one mentioned how it would be impossible to handle the phone after the hairdryer ;)
Didn’t have an iOpener and 60 seconds on a hairdryer wasn’t doing it for me. Still wouldn’t budge. I had to take a very sharp razor along the seam at the bottom between the speakers. It took about 20 passes for it to separate enough to get the spudger in. Make sure you keep the razor at a 90-45˚ angle and that it goes no more than 1-2mm into the phone. The bottom of the phone is metal, but the casing for the screen is plastic. So if you cut lower than a 45˚ (flat with the phone) you risk cutting into the casing. Apply light pressure when making the passes. I would just do the razor on the flat part on the bottom.
minimalist - 답글
I used a hair drier while lifting up at the same time until I could get the too inside. The seal is pretty finicky. Just take your time and you should be fine. Work the hair drier and the tool all the way around before lifting the screen up and off. There will likely be sealant stuck between the screen and phone. You can just break it with the tool.
This step was impossible for me despite using a blow dryer and having no cracks on the screen. I finally took it to a local repair place and had them do battery replacements for two iPhone 7’s. The girl let me watch her do it. She used a razor blade (just until she had a small opening that she could hold open with her fingernail) and confirmed that she too would have difficulty opening it with a plastic tool and suction cup. The plastic tool was great for prying the rest of it open once a crack was there, but she said she would never try to use that as the tool to initially open it. The tools provided for initially prying open the screen are inadequate.
Chad Twedt - 답글
Slide the spudger to the left along the lower edge of the iPhone.
Twist the spudger to widen the gap between the display and rear case.
minimalist - 답글
I used a hairdryer and a razor
Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch.
Be VERY careful on this next step going up the right side of the phone. There is a ribbon cable 1/3 of the way up from the bottom that is very close to the edge. Do NOT use the blue triangle!!!! Just lightly rotate the spudger to get separation on the edge.
Pull up on the suction cup to lift up the display and open the iPhone.
do not pull up pull sideways it will brake
Made this mistake
Somehow my phone turned itself back on during the opening. Scared me a little, like a patient coming out of anesthesia during the operation. I was able to turn it back off. Gotta be more careful where you grab this thing.
Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place.
The plastic clips mentioned are on the top of the screen being replaced… so not sure why it matters not to break them. Trick here was to pull the screen downwards to open a gap at the top and then insert as shown and raise to break the seal.
This is relevant for other guides than the display replacement guide.
jvalaamo -
Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
same dude im such a freak lol omg haha
Are there replacements ribbons?
Has anyone else noticed very small squares of rubber with a circle cut through it (I think they fall off into the phone when dismantling)?
I just replaced my screen and worked out that these are actually a wee pocket that slips over the pentalobe screw holes on the replacement screen. I’m not sure if it’s an additional water resisting mechanism or if it’s to add additional traction for the screws
Thanks, I was wondering where those were from!
Albert -
I just broke cable connecting camera and earpiece speaker to logic board. Be careful with it.
This section is missing a critical step - to lay some Post-It notes or something below the right half of the phone when you swing it open, so the ribbon cables don’t get sliced by the sharp edge of the phone case. I broke the Home Button ribbon cable because there was no strain relief when I laid it open.
I also broke the home button cable and now I have to use assistive touch.
Keep the suction cup on the display to keep it propped up while you disconnect the ribbon cables.
minimalist - 답글
I broke the short ribbon cable that attaches underneath the lower connector bracket. Be SURE when you lift the display, you do it from left to right. I thought I had the phone oriented correctly in my hand, but I was mistaken.
Remove four tri-point Y000 screws securing the lower connector bracket, of the following lengths:
Three 1.2 mm screws
One 2.4 mm screw
These screws just spin for me. They don't back out, but the heads aren't stripped either. I've tried applying backpressure to help lift the screws, but no luck
Jeff Hurst - 답글
What driver do I need to remove these screws i’m stuck
i cant use, the Y000 it isnt working.
What if I stripped a screw what do I do??
Yep, only the 2.4mm came out, other 3 won’t budge, and worried I’ve stripped the heads. Anyone got any ideas?
It’s the screwdriver bit that is the problem. I had the same issue with 2 Y000 bits not grabbing the screw properly. I fixed it by using a small 3 sided file to slightly grind the groves in the Y000 bit just a bit deeper. Then the bit worked like a charm on these screws.
Use Y000 on all 4. U have to be very sensitive on the 1.2mm screws. Put the bit in the screw, put the left pointing finger on top of the screwdriver and turn the driver carefully to the right until you feel a “bump”, thats the trick :-), then you are able to screw the screw out.
For me the key here was a LOT of downward pressure to ensure the Y000 bit caught in the screw. Not sure i can describe how much exactly, but is was significant. Otherwise the bit would not catch.
What do I do if I Stripped one of them?
Can’t get them removed what to do ?
Managed to get the central one out. The upper one won't move, the lower one I've popped out with some force. This allows you to rotate the cover enough to unplug the various bits. Not ideal, but works. I've tried applying a lot of pressure, using the tighten/ loosen method, but the heads have just got mashed… no wonder Samsung are now No1, sigh…
You need to be careful when just rotating the cover as you can accidentally slice through the two black antennas! You only need to nip them…As you can tell I have done this in the past :/
The first, longer screw came out fine, but the other three wouldn’t budge, regardless of more/less pressure or a slight angle or anything. I finally filed down the tip of the Y000 bit ever so slightly, and then it worked. Hope this helps someone.
Filing down the bit worked for me. The tip about putting an index finger on the end of the screwdriver handles and then turning gently until it clicks into place was very helpful! Using these 2 tips I didn't need much downward pressure. Screws are out in a few turns.
Mine came out easily. I placed the screws in the area where the bit goes in my kit so I can keep track.
Remove the lower connector bracket.
my battery cable connector was stuck to the bottom of this metal bracket plate so be careful when you lift it off
This may have been intentionally done by Apple to make sure the battery gets disconnected before any other connector is disconnected. So always make sure to disconnect the battery before disconnecting and reconnecting the connectors for the display.
Use the point of a spudger to lift the battery connector out of its socket on the logic board.
Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
To be honest you don’t really need to disconnect the display cables in step 15 or 16 to get the battery out. Just keep the suction cup on the screen to keep it propped up and to give the cables some slack. The only reason to take these cables off is that it’s a pain to apply the replacement display adhesive with those cables in the way. If you’re not re-waterproofing your phone just leave these attached.
minimalist - 답글
Remove the two 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
Remove the bracket.
Has anyone had trouble getting these two screws off? I’ve been working on these for about 10 minutes and the LEFT screw wont spin. It seems like the little PH000 screwdriver bit won’t even grip it. (The one of the right comes off, no problem)
It looks like I’ll have to pick this project up again with a screwdriver that will actually take off this piece.
I used a #1 flat head tip to loosen.
I couldn’t get the two screws out either—used the correct screw tip and everything. Stripped the screw. Will now attempt to just keep the cable attached…..
Use the PH000 and apply a little more force before spinning, should come right out!
^To anyone having trouble, this is the correct answer. Put the phone on a firm surface, align your driver carefully, press down hard, and twist. As long as your driver is approximately the right size, it’ll come out.
the two screw i have are stripped and i have n way of getting either screws off whats my next bet
The PH000 bit is to large. I can’t get the screws out either which really sucks…now I have to put everything back together, find another bit that will work and try this again another day. Not impressed with IFIXIT’s attention to detail so far :-(
Using iFixit’s driver kit, I prefer a PH00 for this, which is larger than the PH000. If you think the PH000 is too big, something is wrong.
I think part of the issue with the iFixit PH000 is that it is slightly too pointy. The PH00 fits better because the splines engage the slots of the screw before the point bottoms out. The PH000 tip bottoms out in the screw’s center point and the splines don’t engage as well. I have other PH000 tips that are more blunt nose and they work better than the iFixit bit.
PH000 screwdriver didn’t work for any of these screws, or the barometric vent, or the taptic engine. It was too big. I had to use a different screwdriver from another kit I had.
minimalist - 답글
Disconnect the front panel sensor assembly connector from its socket on the logic board.
Das ist sehr mutig, das Kabel dort so zu strapazieren.
Mich würde das Display daneben stellen und mit irgendetwas stützen, dass es nicht umkippen kann um Beschädigungen an dem Kabel zu vermeiden. Das reißt sehr schnell ein.
Is this the connector for the earpiece, as well? I did the screen replacement and everything worked, except now I can’t use my earpiece… I’m afraid I didn’t fully connect this particular portion.
Victor Bui - 답글
@victorbui714 Correct, this is also the connector for the earpiece speaker. Check the flex cable carefully and make sure it wasn’t pinched or torn. Make sure the connector socket is clean (give it a blast with some compressed air if needed) and try reseating it. If that doesn’t help, you may want to remove the earpiece speaker and inspect the four springs on the back, and check that they’re intact and making good contact with the four circular pads on the flex cable. Give the pads a wipe with some IPA and try not to leave any skin oils on them. If none of that works, try replacing the entire flex cable/sensor assembly. Good luck!
Remove the display assembly.
When removing the screen, be aware of the two tiny square black rubber grommets on the Penelope screw brackets that secure the screen. They can fall off very easily and be lost without even knowing it (it happened to me, but was lucky enough to find them).
Guy Cooley - 답글
Sorry, I’m so unclear about when to replace the Adhesive tape. Should I put the iPhone 7 Display Assembly Adhesive at this step, or after I’ve replaced the battery?
Victor Bui - 답글
@victorbui714 Battery first, then adhesive during reassembly, as it says in the instructions. ;)
This is the 3rd screen iv put in my phone and everyone them bust at the top by the camera every time iv bought one of these screen idk if it’s the manufactures fault or what?
trent bost - 답글
@trentb28922 Ouch! That’s not normal. Is your phone’s frame bent? Are you having to use a lot of force when you install the display?
Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
One 1.1 mm screw
Three 1.3 mm screws
No reason to touch that screw unless you’re removing the shield—in which case, this step instructs you to remove it.
So I stripped the screw furthest to the left, how can i possibly remove it now? Can I just buy a new LCD shield and home bracket button and screw and will that work just fine on the new screen replacement? this stripped screw of mine is not coming out
That should work, as long as you can still get the home button/sensor out without damage. For removing a stripped screw this size, I’d probably try supergluing it to the driver—or else just drill the top of the screw off and then remove the bracket, leaving the screw shaft embedded in the old display. Good luck!
I used the same driver for all of these screws. Had to apply a lot of pressure before trying to unscrew it and it was fine.
This is wrong, the size you need is Y00 for the 1.1mm screws and Y000 for the 1.3mm one.
The heads on those screws are identical. I’ve never had any trouble using a Y000 for all of them. Use whatever works for you I guess.
I’ve managed to strip the screw on the right hand side - not the far right, just right of the home button. Any ideas on how to get it out without glue (I don’t have any)
My screwdriver is too big to get out the screws
My eyesight isn’t what it used to be. That said, the replacement screen that arrived already had screws in the two outside positions. It took me a minute to figure this out when I was trying to install the home button. I couldn’t figure out why the screws weren’t going in. I thought the holes were filled or something… Nope. screws. Took them out and used them.. all good.
My 7 had quite a bit of loctite holding these bad boys on. I stripped the one to the right of the home button and after using many “sentence enhancers” I was able to remove it using good tweezers and quite a bit of hand strength. I think that heating up the screws here is not an option because the cables lie underneath the plate and would probably get damaged from the amount of heat needed to loosen the loctite. Be patient here, and maybe have spare Y000 drivers because you may damage your driver getting these screws out.
If your having trouble. I recommend you guys to buy the Y00o driver at amazon. It look golden. It works very will .
Hi all, I’m really hoping someone will be able to give me a hand here, so the 1.1mm screw on top of the home button is stripped, and absolutely refuses to get out. I have tried the superglue technique mentioned and am worried it may have even glued the screw to the bracket. The only solution I can think of is to bend the home button bracket on either side of the middle screw, and use the bracket itself to remove the screw from the home button. I have ordered a new home button bracket either way, does anybody have any other ideas? Should I even attempt what I am proposing?
Thanks in Advance.
Does the ground strap go over or under bracket?
I magically used an X-acto knife tip to lift the edges of the home button screw to loosen it, and then turned it slightly with the X-acto blade tip in the screw slot to get it started, then the 000 screwdriver could finish it.
I can’t stress how important it is to not overtighten the one on the button. I undertightened the center one at first in fear, and then tightened it more when I realized the button was loose. It ended up ruining the home button :(
Pry under the left edge of the home button cable connector to disconnect it from its socket.
I think you can not do it because your phone is not identify for new cable.
Ali Alsaed - 답글
Best thing to do here is to NOT pry up on the connector, but to insert the pry tool on the left side until the connector is dislodged.
Good tip. Worked perfectly. Thx.
Klaus M -
That worked perfectly, thank you!
I did it. :-( i broke it
Anyone having difficulty reconnecting the two ? I’ve been trying for ages with no luck.
Same problem here - can reconnect them once the new LCD is being installed. Not sure what the trick is.
my Homebutton don´t work after I reconnect all, I checked all flex cables but it still dont work. what can I do?
Dr. Dieter - 답글
so, i’m working on an iPhone 7. I was very careful not to break anything, I even bought an iOpener heat pack and applied it, and everything went off without a hitch, but when I tested the button, It does not work, would it help to reconnect it or something?
Thanks a lot!
Broke my cable. The picture is not clear but you have to separate the thin silver end of cable from what looks like a black piece of rubber. I pulled up on it from under the black rubber like the picture shows and broke mine.
This helped me SO much. Watch it before removing home button. Around 4:56ish
Thank you so much!
Carefully pry up the underlying connector and move it out of the way of the home/Touch ID cable.
If the connector doesn't pry up easily, use a hair dryer or iOpener to heat and soften the adhesive securing the connector, and then try again.
Make sure that you fold this cable out when fitting your replacement before you fasten the shield back down. I didn’t but managed to loosen 2 screws on the shield to get the cable out.
If you have isopropyl alcohol on hand. You can use it to help weaken the adhesive temporarily when lifting up the adhered home button.
Just one tiny drop of isopropyl alcohol or it will reach the lcd screen.
Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
If you don’t have that heating tool, a hair straightener n a T-shirt worked just fine for me
Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
It cannot be stressed enough that this is the one part of this repair that you can’t screw up. Anything else you’ll deal with during this repair can be easily replaced (The screen, and the sensor/microphone/camera assembly). Tearing this cable means an expensive trip to the apple store. or a very unhappy customer if you’re doing this for someone. Heat is your friend. I don’t even use a spudger or a guitar pick for this one, I use a new playing card to pull this up. Even with the card, you have to be careful. The edge of the playing card can nick the cable if you’re not careful to get it under the ribbon cable. If the adhesive isn’t soft enough for the card to get it up, apply more heat. Again, you can’t screw this step up. It’s all or nothing.
Well, no visible damage but the home button won’t work. I contacted a local Apple Authorized Service Center to check options. Since I had personally replaced the screen assembly, they wouldn’t even look at it per Apple policy. They said they would jeopardize their Apple Authorization if they even looked at it. Seems like more of the “Right to Repair” problem to me. Frustrated, but at least I have the accesibility home button working.
Make sure the home button screws aren’t overtightened; that often causes issues. If there’s any damage to the button cable, a repair shop with a skilled microsolderer can patch a new cable on and restore functionality. iPhone 7 home button not working after screen replacement? Worst case scenario, you can also buy a screen repair from Apple, and they’ll include a new home button. I am not a lawyer, but the response you’re describing from the AASP sounds way out of bounds. Good luck!
Just keep in mind that this is a very delicate step that requires a lot of patience. the part is attached to the body of the phone so firmly and there is no gap to put the opening pick under. So the way I did it was applying a good amount of heat onto the part and not from behind. I did it constantly for 5 minutes, a few minutes at a time, then I pulled the connected up slightly (a little too much pressure on the pull and you will break the wire). Pull it constantly and If the heat has been enough to melt the adhesive, it should come off easily and slowly.
Hi, a little thing to help : i heatened up and then insert a cutter blade to start. Work better
Salve, vorrei un vostro aiuto, ho un problema con il tasto home (il tasto è originale preso dal vecchio display rotto) una volta sostituito il Touch ID funziona perfettamente (l’iPhone si sblocca e legge l’impronta digitale) il tasto invece no (il click per intenderci) cosa può essere? Grazie!
Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
Had an issue when putting the screen back on, the side where the cables attach would not sit flush. At first I thought the cables were pushing the screen up. Turned out to be the battery cable shield was just a fraction too far down toward home button. After loosening screws, nudging it up slightly and screwing back in, the screen sat flush as it should. In case anyone else has same issue.
My phone is no more turning on after I replace the screen, no reaction if I press home button or power button
This guide is missing the camera transfer and the stupid little black sticker on the earpiece assembly that causes the earpiece not to work if that sticker is not transferred. This guide is wholly incomplete
James and @computermason—You’ll want to look up the correct guide for your repair, especially if you’re not using one of the kits for which this guide is designed. The guide for transferring all the smaller components is here.
No home button functionality? I just watched a video on YouTube from two years ago saying that the iPhone 7 and 7+ have to be taken to an Apple repair center for the home button to work. Is this still the case? If so why didn’t you tell me this before I ordered this! Please confirm before I start warning everyone not to purchase from you!
@ghaycock If you’re replacing a screen, the home button will work fine as long as you carefully remove it from the old screen and transfer it to the new one, exactly as explained in the guide. The button itself can’t be replaced without help from Apple (which is why iFixit doesn’t sell home buttons for this model).
One thing I don’t see mentioned is the replacement of the rubber gaskets that are on the pentalobe holes. The replacement screen did not come with these on it. I was able to remove them from the OEM screen, but there was no easy way to get them to adhere to the new screen. If they move just a little, you might not be able to properly thread the pentalobe screws. Worst case is that they fall into the body of the phone during this last step of re-assembly. At that point, you’ve already started to have the screen stuck to the adhesive, so you would need to redo the entire adhesive gasket.
You can see the gaskets in this picture: https://d3nevzfk7ii3be.cloudfront.net/ig...
Here they are near the new screen: https://drive.google.com/open?id=14FwpSB...
Remove the three Phillips screws securing the earpiece bracket to the front panel:
Two 2.6 mm screws
One 1.7 mm screw
I am measuring the screws; my digital caliper measures both the top at 1.88mm not 2.6
I just checked the screw measurements and they match what’s shown in the guide. Are you sure you’re looking at the right screws?Are you sure your caliper is accurate? Was your iPhone serviced in the past and reassembled incorrectly? Something isn’t right. The measurements here are the screw lengths, by the way—just in case you were measuring something else.
Reheat your iOpener and apply it to the upper edge of the display assembly to soften the adhesive holding the front camera and sensor assembly in place.
Use a spudger to gently pry the ambient light sensor out of its recess on the front panel.
I’m sorry to comment but this step is wrong. The proximity sensor is sticked to the display. I was following this instruction and the sensor was unvelded from the flex cable. Now it’s workless. It’s a fortune that the only problem with the iPhone is that while calling and holding the phone to the ear, the display doesn’t turn off.
I recommend to gently pushing against the transparent plastic enclosure near the sensor and once it’s unsticked, keep pushing against the sensor’s body. In this way the sensor welding doesn’t bear/support any extra load on it.
At least, my iPhone 7G had the sensor sticked to the display. Maybe some day I will replace it (around 20€ - 25€ on ebay)
I won't claim to iFixit nor stop using this website. Whenever I higly recommend to iFixt technitians to revise such kind of “errors”. At least for expensive devices like Apple products.
I editted this guide and added these two comments. I already know about this “trick”. It’s your own decision to follow my suggestion or not.
I have fixed 2 screens now on iPhone 7. The 1st time I didn’t have this problem, 2nd time I did. I would agree with Miguel Cretu and save yourself the hassle and remove the sensor and it’s surround altogether.
In the second picture, there is the splugger that’s on it’s right is near a little window square, white inside. I’ve checked my replacement display and it don’t have inside in WHITE in this little window . Anyone know why have this color (it is not a sticker) and what is the reason? Thanks
I also had to pop out the clear plastic surround of the front camera to put into my new screen. It’s just glued in, so heat and pop it out with a spudger. Best to do this step last so you don’t accidentally tear any ribbons.
Use the pick to lift the camera cable up off of the two plastic posts on the front panel and separate it from the last of the adhesive.
на рисунке №2 винт 3 отсутствует, на рисунке № 3 винт 3 присутствует. нет описание где он был вывинчен. последний винт с правой стороны, около камеры
Remove the front camera and sensor cable.
Look at the camera assembly closely. There are two cables soldered together. Do not separate the pieces by mistake . Get the pick all the way below both ,and they will come off together.
turboduck2 - 답글
I’ve separated the sensor and front facing camera, can I just press them back together or will I need a complete replacement
I’m also looking for info on the screw on the immediate left of the top left corner of the speaker. Did you find the info out?
Cheers!
Remove the three 1.2mm tri-point Y000 screws from either side of the display assembly for a total of six screws.
I d’ont think the screw size is correct, because i had to order a new heat shield plate, because my original broke during the replacement.
I found if I held the flat end of a spudger behind the screw while I unscrewed, it worked well. Otherwise there was too much flex to get a good grip on the screw.
good tip! Yes, there is indeed too much flex when removing the screws.
amberron -
My screws are too tight that I can't unscrew it. What should I do?
I have had this problem so far on all the red tri point screws. The first screw, the home button, and 4/6 of these. I have noticed little to no advice on each one or for stripped screws. I have been able to manage so far but not sure about this one.
Here, I was able to use a soldering iron on the back side of the screw to get it quite hot to release the INSANE amount of loctite that was applied to my 7. Be patient and let the screw get hot. If you try to move the screw with the Y000 and it doesn’t move, WAIT. Don’t strip the screw or your driver.
Good tip using the soldering iron. I’ve just ordered a quality Y driver as the cheap one that came with the screen can’t remove these screws. Why the the Loctite? Had to reassemble what I’ve pulled apart to await the new driver.
I understand home button , but why do i need to replace the shield and camera/speaker?
Heat an iOpener and lay it over the edge of the shield closest to the home button to soften the adhesive holding it in place.
다른 63명이 해당 안내서를 완성하였습니다.
댓글 5개
Awesome Guide! Very easy to follow!!! Thanks!
Use a good tri-point screwdriver for this repair. Some of the screws are very tight!
Absolutely true. The cheap Y000 driver that came with a repair kit was stripped to uselessness by the time I got to the shield screws.
I had a lot of trouble getting the home button cable connector back after replacing the screen and shield. I wound up disconnecting the shield to give the screen side of that connection a little more play and enable the connection to be made.
Incidentally, if you want to take off just the shield itself and not the outer cables, you can skip 19-35, except the outer orange screws in 19 and the outer orange screws in 26. It might make getting under the shield adhesive harder, but in the case I described above, it was quite useful!
Can anyone confirm 7/7P's pentalobe screws have a ring of seal near the screw head?
Cooper Chase - 답글
Confirmed, the screws have a black ring seal around the head.
rcheing - 답글
Can’t get the display front
Bernadette Pfeifer - 답글
