주요 콘텐츠로 건너뛰기
iPhone 7 Plus Battery Replacement
필요한 것
동영상 개요
  1. iPhone 7 Plus Battery Replacement, Pentalobe Screws: 1 단계, 이미지 1/1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Plus Battery Replacement, Opening Procedure: 2 단계, 이미지 1/1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 7 Plus Battery Replacement: 3 단계, 이미지 1/2 iPhone 7 Plus Battery Replacement: 3 단계, 이미지 2/2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 7 Plus Battery Replacement: 4 단계, 이미지 1/3 iPhone 7 Plus Battery Replacement: 4 단계, 이미지 2/3 iPhone 7 Plus Battery Replacement: 4 단계, 이미지 3/3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
    • While pulling up on the suction cup, twist the spudger to widen the opening between the screen and rear case.
  5. iPhone 7 Plus Battery Replacement: 5 단계, 이미지 1/3 iPhone 7 Plus Battery Replacement: 5 단계, 이미지 2/3 iPhone 7 Plus Battery Replacement: 5 단계, 이미지 3/3
    • Insert the flat end of the spudger between the front panel and the rear case at the lower left edge of the iPhone.
    • Slide the spudger up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  6. iPhone 7 Plus Battery Replacement: 6 단계, 이미지 1/2 iPhone 7 Plus Battery Replacement: 6 단계, 이미지 2/2
    • Remove the spudger from the left side of the phone and insert the flat end into the bottom right corner.
    • Slide the spudger up the right edge of the phone to the top corner, breaking up the adhesive holding the display in place.
  7. iPhone 7 Plus Battery Replacement: 7 단계, 이미지 1/2 iPhone 7 Plus Battery Replacement: 7 단계, 이미지 2/2
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are delicate ribbon cables along the right edge of the device connecting the display to the logic board.
  8. iPhone 7 Plus Battery Replacement: 8 단계, 이미지 1/2 iPhone 7 Plus Battery Replacement: 8 단계, 이미지 2/2
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  9. iPhone 7 Plus Battery Replacement: 9 단계, 이미지 1/2 iPhone 7 Plus Battery Replacement: 9 단계, 이미지 2/2
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  10. iPhone 7 Plus Battery Replacement: 10 단계, 이미지 1/3 iPhone 7 Plus Battery Replacement: 10 단계, 이미지 2/3 iPhone 7 Plus Battery Replacement: 10 단계, 이미지 3/3
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  11. iPhone 7 Plus Battery Replacement, Battery Disconnection: 11 단계, 이미지 1/1
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
  12. iPhone 7 Plus Battery Replacement: 12 단계, 이미지 1/2 iPhone 7 Plus Battery Replacement: 12 단계, 이미지 2/2
    • Remove the lower display cable bracket.
  13. iPhone 7 Plus Battery Replacement: 13 단계, 이미지 1/3 iPhone 7 Plus Battery Replacement: 13 단계, 이미지 2/3 iPhone 7 Plus Battery Replacement: 13 단계, 이미지 3/3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  14. iPhone 7 Plus Battery Replacement, Display Assembly: 14 단계, 이미지 1/3 iPhone 7 Plus Battery Replacement, Display Assembly: 14 단계, 이미지 2/3 iPhone 7 Plus Battery Replacement, Display Assembly: 14 단계, 이미지 3/3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  15. iPhone 7 Plus Battery Replacement: 15 단계, 이미지 1/3 iPhone 7 Plus Battery Replacement: 15 단계, 이미지 2/3 iPhone 7 Plus Battery Replacement: 15 단계, 이미지 3/3
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
  16. iPhone 7 Plus Battery Replacement: 16 단계, 이미지 1/2 iPhone 7 Plus Battery Replacement: 16 단계, 이미지 2/2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  17. iPhone 7 Plus Battery Replacement: 17 단계, 이미지 1/1
  18. iPhone 7 Plus Battery Replacement, Barometric Vent: 18 단계, 이미지 1/1
    • Remove the following two Phillips screws securing the barometric vent to the rear case:
    • One 2.9 mm screw
    • One 2.1 mm screw
  19. iPhone 7 Plus Battery Replacement: 19 단계, 이미지 1/2 iPhone 7 Plus Battery Replacement: 19 단계, 이미지 2/2
    • Gently push the barometric vent in the direction of the Taptic Engine to separate the adhesive securing it to the bottom edge of the iPhone.
  20. iPhone 7 Plus Battery Replacement: 20 단계, 이미지 1/1
    • Remove the vent.
  21. iPhone 7 Plus Battery Replacement, Taptic Engine: 21 단계, 이미지 1/2 iPhone 7 Plus Battery Replacement, Taptic Engine: 21 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
  22. iPhone 7 Plus Battery Replacement: 22 단계, 이미지 1/1
    • Remove the three 1.5 mm Phillips screws securing the Taptic Engine to the rear case.
  23. iPhone 7 Plus Battery Replacement: 23 단계, 이미지 1/2 iPhone 7 Plus Battery Replacement: 23 단계, 이미지 2/2
    • Remove the Taptic Engine.
  24. iPhone 7 Plus Battery Replacement, Battery: 24 단계, 이미지 1/3 iPhone 7 Plus Battery Replacement, Battery: 24 단계, 이미지 2/3 iPhone 7 Plus Battery Replacement, Battery: 24 단계, 이미지 3/3
    • Peel back the three adhesive strips on the lower edge of the battery.
    • If possible, use your fingernails or blunt tweezers. Be careful not to poke the battery with any sharp tools.
  25. iPhone 7 Plus Battery Replacement: 25 단계, 이미지 1/3 iPhone 7 Plus Battery Replacement: 25 단계, 이미지 2/3 iPhone 7 Plus Battery Replacement: 25 단계, 이미지 3/3
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  26. iPhone 7 Plus Battery Replacement: 26 단계, 이미지 1/2 iPhone 7 Plus Battery Replacement: 26 단계, 이미지 2/2
    • Repeat the previous step for the second and third strips.
    • Hold down the battery as you remove the final strip, or the strip may fling the battery when it separates from the case.
    • If you removed all adhesive strips successfully, skip the next step.
    • Otherwise, if any of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
  27. iPhone 7 Plus Battery Replacement: 27 단계, 이미지 1/2 iPhone 7 Plus Battery Replacement: 27 단계, 이미지 2/2
    • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. It should be slightly too warm to touch comfortably.
    • Overheating the iPhone may ignite the battery.
    • Flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
    • Do not insert your card in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath.
    • Do not pry against the logic board or you may damage the phone.
    • Keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals or catch fire. Do not use any sharp tools to pry at the battery.
    • Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
    • Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
  28. iPhone 7 Plus Battery Replacement: 28 단계, 이미지 1/1
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove the sleeve before installation by pulling it away from the ribbon cable.
    • Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess.
    • Adhere the battery, disconnect it, and continue reassembling your device.
    • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
다른 406명이 해당 안내서를 완성하였습니다.
Scott Havard
회원 가입일: 06/27/16
49,621 평판
안내서 31개 작성하였습니다
댓글 51개
can the battery from iPhone 7plus fit in the 6s plus? looks to me like is the same type of connector and same dimensions so it would be an easy way to gain 150 extra mah by using the iphone 7 plus battery
Alex
alexandrupaulpopa - 답글
No, because the size are diferents
JOSE RAMON -
Of course you can! WHY NOT?
Manuel Tugentman - 답글
How can I attach the screen back to the body after replacing the old battery,do i need any adhesive to attach the screen to the body?
Kaustubh Iyer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 73
7일 전: 724
30일 전: 2,660
전체 시간: 472,984
