주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
iPhone 7 Plus Front Camera and Sensor Cable Replacement
필요한 것
  1. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Pentalobe Screws: 1 단계, 이미지 1/1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Opening Procedure: 2 단계, 이미지 1/1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 3 단계, 이미지 1/2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 3 단계, 이미지 2/2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 4 단계, 이미지 1/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 4 단계, 이미지 2/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 4 단계, 이미지 3/3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
    • While pulling up on the suction cup, twist the spudger to widen the opening between the screen and rear case.
  5. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 5 단계, 이미지 1/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 5 단계, 이미지 2/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 5 단계, 이미지 3/3
    • Insert the flat end of the spudger between the front panel and the rear case at the lower left edge of the iPhone.
    • Slide the spudger up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  6. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 6 단계, 이미지 1/2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 6 단계, 이미지 2/2
    • Remove the spudger from the left side of the phone and insert the flat end into the bottom right corner.
    • Slide the spudger up the right edge of the phone to the top corner, breaking up the adhesive holding the display in place.
  7. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 7 단계, 이미지 1/2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 7 단계, 이미지 2/2
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are delicate ribbon cables along the right edge of the device connecting the display to the logic board.
  8. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 8 단계, 이미지 1/2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 8 단계, 이미지 2/2
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  9. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 9 단계, 이미지 1/2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 9 단계, 이미지 2/2
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  10. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 10 단계, 이미지 1/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 10 단계, 이미지 2/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 10 단계, 이미지 3/3
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  11. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Battery Disconnection: 11 단계, 이미지 1/1
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
  12. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 12 단계, 이미지 1/2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 12 단계, 이미지 2/2
    • Remove the lower display cable bracket.
  13. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 13 단계, 이미지 1/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 13 단계, 이미지 2/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 13 단계, 이미지 3/3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  14. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Display Assembly: 14 단계, 이미지 1/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Display Assembly: 14 단계, 이미지 2/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Display Assembly: 14 단계, 이미지 3/3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  15. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 15 단계, 이미지 1/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 15 단계, 이미지 2/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 15 단계, 이미지 3/3
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
  16. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 16 단계, 이미지 1/2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 16 단계, 이미지 2/2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  17. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 17 단계, 이미지 1/1
  18. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Earpiece Speaker: 18 단계, 이미지 1/1
    • Remove the five Phillips screws securing the earpiece speaker bracket:
    • Two 1.8 mm screws
    • One 2.3 mm screw
    • One 2.4 mm screw
    • One 2.8 mm screw
  19. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 19 단계, 이미지 1/1
    • Remove the earpiece speaker bracket.
  20. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 20 단계, 이미지 1/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 20 단계, 이미지 2/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 20 단계, 이미지 3/3
    • Use the flat end of a spudger to lift the front-facing camera from its housing.
    • Gently bend the camera ribbon cable to the side to clear the way to the earpiece speaker underneath.
  21. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 21 단계, 이미지 1/1
    • Remove the earpiece speaker.
    • Don't touch the four spring contacts with your fingers—your skin oils may cause a malfunction. If accidentally touched, clean the contacts gently with isopropyl alcohol (90% or higher).
  22. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Front Camera and Sensor Cable: 22 단계, 이미지 1/2 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Front Camera and Sensor Cable: 22 단계, 이미지 2/2
    • Gently fold the camera and attached ribbon cable toward the bottom of the iPhone to allow access to the components underneath.
  23. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 23 단계, 이미지 1/2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 23 단계, 이미지 2/2
    • The sensors on this step are fragile. To increase your chances of removing them without damage, use your iOpener or hair dryer to apply heat to the upper portion of the display before you proceed. Alternatively, add a drop or two of isopropyl alcohol and let it penetrate under the sensors before you pry them up.
    • Slide a spudger under the ambient light sensor flex cable, and lift the sensor out of its housing.
  24. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 24 단계, 이미지 1/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 24 단계, 이미지 2/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 24 단계, 이미지 3/3
    • Slide the tip of a spudger underneath the proximity sensor flex cable, and lift the sensor out of its housing.
  25. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 25 단계, 이미지 1/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 25 단계, 이미지 2/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 25 단계, 이미지 3/3
    • Insert the sharp edge of an iFixit opening tool underneath the camera assembly's flex cable, on the opposite side from the front-facing camera.
    • If necessary, use an iOpener or hair dryer to heat the top portion of the display and soften the adhesive securing the flex cable.
    • Pry up to separate the edge of the flex cable from the back of the display.
  26. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 26 단계, 이미지 1/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 26 단계, 이미지 2/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 26 단계, 이미지 3/3
    • Insert the point of a spudger underneath the same portion of the flex cable that you separated in the previous step.
    • Continue separating the remainder of the flex cable, pushing the spudger toward the row of circular gold earpiece speaker contacts.
  27. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 27 단계, 이미지 1/1
    • Continue using your spudger to carefully separate the last of the flex cable from the back of the display.
  28. iPhone 7 Plus Front Camera and Sensor Cable Replacement: 28 단계, 이미지 1/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 28 단계, 이미지 2/3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: 28 단계, 이미지 3/3
    • Remove the front camera and sensor cable assembly.
    • A piece of black double-sided insulating tape lies between the display and three rows of copper contacts on the back of the camera/sensor cable. It may remain stuck to the display, or it may come off with the cable.
    • When reassembling, verify the tape is in place, or else cover the contacts on the back of the cable with an appropriate tape, such as Kapton tape.
결론
다른 113명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
427,783 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,718개 작성하였습니다
댓글 17개
Do I have to do this if i buy a new phone screen or do they usually come with one?
Tom Robinson - 답글
If this Speaker is Not Working or it has any Noise Issues, Apple will Replace whole Front Display Section. Under their Policy, they won’t repair it. Neither Fully Replace your iPhone, only Front Panel Replacement.
macktm -
Does 7 and 7plus has the same camera/sensor strip?
Salman Siddeeque Ali - 답글
No, it’s a bit different.
The spacing between the metal dots for the earspeaker isn’t there on the 7+ model, but is on the 7.
Benjamin Convents -
Anybody got a solution to earpiece not working after ribbon swap?
Seems to be mega common with this repair. I’ve heard a few ideas but nothing concrete. More advice about this issue would be greatly appreciated by me and a bunch of people.
michael wehner - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 70
30일 전: 330
전체 시간: 116,490
