주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
보관됨
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
보관됨
소개
Click here for the official iFixit screen replacement guide for the iPhone 7 Plus. The guide you are currently viewing is a member-contributed guide that has been retained for historical purposes.
  1. Remove the 2x pentelobe screws from the bottom of the phone. Insert your iSesamo tool into the bottom left-hand corner of iPhone 7 Plus and gently pry upwards to release the corner. Heat may be needed to help release the LCD Assembly from the frame. Gently work your iSesamo tool around the outer edges of the device. Be careful not to insert the iSesamo tool too deep into the body of the phone as you may damage internal components that you cannot see.
    • Remove the 2x pentelobe screws from the bottom of the phone.
    • Insert your iSesamo tool into the bottom left-hand corner of iPhone 7 Plus and gently pry upwards to release the corner. Heat may be needed to help release the LCD Assembly from the frame.
    • Gently work your iSesamo tool around the outer edges of the device. Be careful not to insert the iSesamo tool too deep into the body of the phone as you may damage internal components that you cannot see.
  2. Gently lift the screen upward and down to release the retention clips from the top portion of the device and swing the assembly open to the right.
    • Gently lift the screen upward and down to release the retention clips from the top portion of the device and swing the assembly open to the right.
    • Notice that there are two sets of plates that must be removed. The upper plate covers the flex cable for the earpiece speaker FPC, and the camera FPC's. The lower plate covers the fingerprint FPC, LCD FPC and the battery connector.
  3. Three screws hold the upper FPC plate in place. These are all #000 tri-tip screws. Four screws hold the lower FPC plate in place. These are also #000 tri-tip screws. Four screws hold the lower FPC plate in place. These are also #000 tri-tip screws.
    • Three screws hold the upper FPC plate in place. These are all #000 tri-tip screws.
    • Four screws hold the lower FPC plate in place. These are also #000 tri-tip screws.
  4. 필수 도구 키트
    최고의 소형 키트에서 가장 유용한 도구.
    지금 쇼핑하기
    필수 도구 키트
    지금 쇼핑하기
  5. Using a Nylon Spudger gently pry up the earpiece speaker flex at the top. Disconnect the FPC's at the bottom of the phone that go to the fingerprint sensor FPC and the LCD/Digitizer flex. Remove the LCD Assembly from the housing and prepare to disassembly the LCD Assembly and small parts.
    • Using a Nylon Spudger gently pry up the earpiece speaker flex at the top.
    • Disconnect the FPC's at the bottom of the phone that go to the fingerprint sensor FPC and the LCD/Digitizer flex.
    • Remove the LCD Assembly from the housing and prepare to disassembly the LCD Assembly and small parts.
  6. Remove the five screws holding the earpiece speaker retaining plate in place. These are #000 phillips head screws. Remove the five screws holding the earpiece speaker retaining plate in place. These are #000 phillips head screws. Remove the five screws holding the earpiece speaker retaining plate in place. These are #000 phillips head screws.
    • Remove the five screws holding the earpiece speaker retaining plate in place. These are #000 phillips head screws.
  7. Now that the earpiece speaker retaining plate is removed the earpiece speaker should easily lift off the device. Using the flat end of a nylon spudger gently pry the earpiece speaker FPC away from the assembly. This piece is held on by double sided adhesive but should easily come up with some gentle prying. Using the flat end of a nylon spudger gently pry the earpiece speaker FPC away from the assembly. This piece is held on by double sided adhesive but should easily come up with some gentle prying.
    • Now that the earpiece speaker retaining plate is removed the earpiece speaker should easily lift off the device.
    • Using the flat end of a nylon spudger gently pry the earpiece speaker FPC away from the assembly. This piece is held on by double sided adhesive but should easily come up with some gentle prying.
  8. Using your #000 tri-tip screwdriver remove the four screws holding the home button backplate in place. Using your #000 tri-tip screwdriver remove the four screws holding the home button backplate in place. Using your #000 tri-tip screwdriver remove the four screws holding the home button backplate in place.
    • Using your #000 tri-tip screwdriver remove the four screws holding the home button backplate in place.
  9. Using your needle tip tweezers gently pry the home button connector and detach it from the home button flex. Using the flat end of your nylon spudger gently pry the home button away from the back side of the frame. The home button should pass through the hole in the middle of the LCD assembly and fall to your work mat.
    • Using your needle tip tweezers gently pry the home button connector and detach it from the home button flex.
    • Using the flat end of your nylon spudger gently pry the home button away from the back side of the frame.
    • The home button should pass through the hole in the middle of the LCD assembly and fall to your work mat.
    • The home button will not work if it is replaced with an aftermarket part as it is still serialized to the logic board. If you damage this you will have to seek service through apple to restore fingerprint capability. (This will probably result in device replacement.)
  10. Remove the five #000 Tri-tip screws and the one #000 Phillips screw that hold the LCD backplate in place. Feed the LCD and Fingerprint sensor cables through the LCD backplate.
    • Remove the five #000 Tri-tip screws and the one #000 Phillips screw that hold the LCD backplate in place.
    • Feed the LCD and Fingerprint sensor cables through the LCD backplate.
결론
다른 21명이 해당 안내서를 완성하였습니다.
RS Cell and Tech Repair
회원 가입일: 2015년 09월 20일
1,118 평판
안내서 1개 작성함
Android Alliance Android Alliance 회원
Community
79 회원들
안내서 514개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 12,314
