주요 콘텐츠로 건너뛰기
이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
iPhone 7 Plus Taptic Engine/탭틱 엔진 교체
필요한 것
  1. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체, Pentalobe/펜타로브/별나사: 1 단계, 이미지 1/1
    • 시작하기 전에 iPhone 배터리를 25% 이하로 방전하세요. 충전된 리튬-이온 배터리에 실수로 구멍이 생기면 화재를 일으키거나 폭발할 수 있습니다.
    • 분해를 시작하기 전에 iPhone 전원을 끄세요.
    • iPhone 하단 가장자리에 위치한 3.4mm pentalobe/펜타로브/별나사 두 개를 빼세요.
    • iPhone 디스플레이를 열게되면 방수 씰이 손상됩니다. 이 단계를 수행하기 전에 교체용 씰을 준비하거나 씰없이 iPhone을 재조립할 경우 액체에 노출되지 않도록 주의하세요.
    The recommendation of discharging the battery is completely unnecessary. Even a 25% charged battery can explode. Completely ridiculous suggestion.
    pargoff - 답글
    The risk of thermal runaway on these batteries decreases with the battery's SOC (state of charge). Below 50% charge the risk is fairly low, and at 25% charge the risk of a thermal event is near zero. If I recall correctly, the same suggestion appears in Apple's official (non-public) service manuals for the iPhone.
    Jeff Suovanen -
    @jeffsu Yes, that is correct. Apple does require all certified staff to discharge the battery below 25%. This is an industry standard for all LiION batteries. If you don’t want to do this, just make sure to not puncture the battery and disconnect it first thing.
    iHelpU.Tech - 답글
    Hang on a second here, doesn’t the Ifixit part I ordered come with the seals? The display assembly? It doesn’t. Now I have to wait another week?!
    Vanessa Pinter - 답글
    How do you turn off if the screen isn’t responding to touch?
    adam - 답글
    The replacement battery came with the seal—but how do you put it on???
    lkollar - 답글
    Instructions for replacing the seal are here: iPhone 디스플레이 접착제 교체
    bester - 답글
    I just found the instructions on how to install the seals AFTER I was completed and had to figure it out. Maybe, just maybe you should link this somewhere on the guild instead of buried in a comment. Just a thought.
    Charles Meitin - 답글
    Step 1 is: Read through all the steps and comments or the method prior to starting on this Step 1. There's a lot of much needed information and experience that you can learn from which will reduce the chance of struggling, wasting time or even breaking your device.
    My favourites are:
    Use a hot water bottle.
    Label all screws you remove with their size and location on a piece of paper with double sided sticky tape.
    Test the lightning assembly at step 13
    There is a Standoff driver bit in the box, don't use a screwdriver.
    etc...
    Neil Eriksen - 답글
    A tip for looking out for all those little screws. I used an ice block tray, for all the little screws etc. I numbered each with the step number, as in the instructions, but not all steps have bits to look out for. Where two different size screws are used I had a tray for each size and marked step a and step b. For this I coloured each tray sticker with the colour of the screw as shown in the instructions. All this worked a treat with no confusion or using the wrong part.
    Herb
    Herb Adler - 답글
    The screw size for those with a screw set is P2.
    Gareth Flandro - 답글
  2. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체, 여는 절차: 2 단계, 이미지 1/1
    • iPhone 하단 가장자리를 가열하면 디스플레이를 고정하고 있는 접착제가 부드러워져서 보다 쉽게 ​​열 수 있습니다.
    • 헤어 드라이어 또는 iOpener를 준비하여 iPhone 하단 가장자리를 약 1분 동안 가열하여 밑에 있는 접착제를 부드럽게 하세요.
    How long should I use a hairdryer for?
    Warren Binder - 답글
    I used it until it was hot to the touch but not too hot where you burn yourself.
    gczarny -
    Hey, I just took apart my first iPhone 7 plus today, and it was easier for me to use guitar picks and a magic glass tool. I did tear the home flex on the screen—now I know to be more careful of that on disassembly—-~Katrina of iPad Rehab Microsoldering
    jessabethany - 답글
    First I tried to remove the screen with the hot iOpener, but it doesn’t worked, the day after I putted the Iphone in the sun for a while and then used the hot iOpener, then the screen was easy to remove :-)
    Marc Boon - 답글
    Get a T-shirt add heat to a lil corner of it, with either a hair straighter or an Iron , touch the T-shirt if it’s seems hot but doesn’t burn u hold that lil hot piece of T-shirt against the edge ur trying to pry open , if it’s still not opening add a I’ll more heat,
    www.tertlegerl - 답글
    I don’t think the iOpener was effective at softening the adhesive. Using a suction cup and the spudger is good enough.
    Mac - 답글
    I took a hot water bottle and layed it on the display of the iPhone for a minute, because I did not have an iOpener. That worked for me perfect.
    Michael Maier - 답글
    How can I get all this tools
    Ajibol emmanuel - 답글
    Pour ouvrir mon iPhone 7+ j’ai utilisé un séchoir à cheveux avec modération. Cela a été beaucoup plus facile
    Serge - 답글
  3. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 3 단계, 이미지 1/2 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 3 단계, 이미지 2/2
    • 흡입 컵을 전면 패널 하단, 홈 버튼 바로 위에 붙이세요.
    • 흡입 컵이 홈 버튼과 겹치지 않도록 하세요. 겹치는 경우 흡입 컵과 전면 유리 사이에 씰이 형성되지 않습니다.
    • 디스플레이가 심하게 깨진 경우 투명 포장 테이프를 붙여서 흡입 컵을 부착할 수 있습니다. 대안으로, 흡입 컵 대신에 매우 강한 테이프를 사용할 수 있습니다. 다른 모든 방법이 실패하면 초강력 접착제를 사용하여 흡입 컵을 깨진 스크린에 붙일 수 있습니다.
    Hi! My suction cup doesn’t work. It won’t strongly suck on my screen. Does anyone have any advice?
    kaiminliu119 - 답글
    Heat it up just a little with a hair dryer make sure it’s flat , let it coo a bit now try it??
    robertread - 답글
    The suction cup you provide sucks. In that it doesn’t hold. Luckily I had a set of heavy duty suction cups from when I worked on my iMac.
    Charles Meitin - 답글
    Moi j’ai utilisé un séchoir à cheveux cela a été beaucoup plus facile pour l’ouvrir , mais avec modération
    Serge - 답글
  4. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 4 단계, 이미지 1/3 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 4 단계, 이미지 2/3 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 4 단계, 이미지 3/3
    • 전면 패널과 후면 케이스 사이에 약간의 틈을 만들기 위해 일정한 힘으로 흡입 컵을 위로 당기세요.
    • 틈 사이로 spudger/스퍼저를 삽입하세요.
    • 디스플레이를 제자리에 고정하는 방수 접착제는 매우 강력합니다; 이 초기 틈을 만들려면 상당한 힘이 들어갑니다. 틈을 여는 것이 어려우면 spudger/스퍼저를 넣을 수 있는 틈이 생길 때까지 스크린을 위아래로 부드럽게 들었다 놨다하여 접착제를 약하게 만들어 주세요
    • 흡입 컵을 위로 당기면서 스크린과 후면 케이스 사이의 틈을 넓히기 위해 spudger/스퍼저를 비틀어주세요.
    Be very careful not to pull up with too much force. My screen just shattered while I was pulling up with my suction cup. (There were no previous cracks or chips or anything).
    Benjamin Pounds - 답글
    I’m stuck on this part. I’ve heated the bottom up and attached the suction cup right above the home button, but I can’t pull it apart. I feel like I’m going to break the glass display. Tips?
    whtafrcn420 - 답글
    Someone mentioned above, using strong tape helps .
    MajorCouillon - 답글
    You won’t be able to put the spudger into the gap unless the phone is in a vertical position (speaker side up) in your hands.
    Mac - 답글
    read steps 4-9 before attempting. I cracked my glass because I didn’t
    David Lei - 답글
    My first 7 Plus opening. I pulled up the screen just enough to insert a thin guitar pick at the bottom of the phone to break the adhesive. I didn’t even create a gap as such. I then ran the pick along the sides to continue to detach the adhesive, just like iFixIt show in Step 10 for the top of the phone.
    My screen already had a crack at the bottom, near the home button, so I was nervous about pulling too hard on the screen. It had a screen protector fitted so maybe that helped keep it all together.
    iFixIt’s use of a spudger at the bottom of the phone looked hazardous to me, especially with my damaged screen.
    Big Ed - 답글
    This must be a joke. I’ve been trying for days to pull open the iphone like this. Doesn’t work. I bent the ring on the suction cup trying to pull it off, but nothing happens, no gap, not remote possibility of a pick or spudger getting in there.
    James Osborne - 답글
    Ended up using a blowdryer and a razor blade. Bottom got scratched up, but there was no way that fat plastic spudger was going to fit. I got the razor under the corner, from there worked to middle and twisted with repeatedly adding heat. Lots of heat.
    James Osborne - 답글
    Be aware that there is a small connector, under the home button.
    Herb Adler - 답글
    I found that the edge of the spudger was too thick, so I sanded it down to almost a knife edge. This made it much easier to insert into the gap.
    Herb Adler - 답글
    Use the Opener and a razor blade to cut through the adhesive. It takes about 45 seconds to heat up the Opener in a 1000 watt microwave. Be careful not to damage the thin display ribbon cables on the right side iphone. After you use the razor blade to cut the adhesive on the two sides and bottom you should be able to use the spudger to remove the display screen.
    larrywert - 답글
  5. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 5 단계, 이미지 1/3 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 5 단계, 이미지 2/3 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 5 단계, 이미지 3/3
    • iPhone의 왼쪽 하단 가장자리의 전면 패널과 후면 케이스 사이로 spudger/스퍼저의 평평한 끝을 삽입하세요.
    • Spudger/스퍼저를 휴대폰 왼편 하단 가장자리에서 가장자리를 따라 위로 밀어 음량 조절 버튼과 무음 스위치쪽으로 이동하여 디스플레이를 고정하는 접착제를 떼세요.
    • 디스플레이 상단 가장자리를 후면 케이스에서 비집지 마세요. 디스플레이를 고정하는 플라스틱 클립이 손상될 수 있습니다.
  6. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 6 단계, 이미지 1/2 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 6 단계, 이미지 2/2
    • Spudger/스퍼저를 휴대폰 왼편에서 오른편으로 움직여 하단 모서리에 삽입하세요.
    • Spudger/스퍼저를 휴대폰 오른편 가장자리를 따라 위로 밀어 디스플레이를 제자리에 고정하는 접착제를 분리하세요.
  7. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 7 단계, 이미지 1/2 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 7 단계, 이미지 2/2
    • 흡입 컵을 위로 당겨 디스플레이를 들어 올려 iPhone을 여세요.
    • 디스플레이를 10º 이상 올리지 마세요. 디스플레이와 로직 보드를 연결하는 리본 케이블이 기기의 오른편 가장자리에 위치하고 있습니다.
    The ribbon cable part should be said earlier instead of halfway through
    I just broke one because of it
    BrenX1 - 답글
  8. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 8 단계, 이미지 1/2 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 8 단계, 이미지 2/2
    • 흡입 컵의 작은 손잡이를 당겨 전면 패널에서 분리하세요.
  9. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 9 단계, 이미지 1/2 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 9 단계, 이미지 2/2
    • 디스플레이 아래, 휴대폰 상단 가장자리를 따라 여는 픽을 밀어서 마지막 남은 접착제를 분리하세요.
    I couldn't find the pick in the tool set, so made my own. Then I found the original in the battery box. %#*@.
    Herb Adler - 답글
    Same thing for me
    Jason Skelton - 답글
  10. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 10 단계, 이미지 1/3 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 10 단계, 이미지 2/3 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 10 단계, 이미지 3/3
    • 휴대폰 상단 모서리에서 디스플레이 어셈블리를 약간 당겨서 후면 케이스에 고정하는 클립을 풀어주세요.
    • 책의 뒷 표지를 열듯이 디스플레이 왼편을 위로 펼쳐서 iPhone을 열어주세요.
    • 아직 디스플레이를 완전히 분리하지 마세요. 여전히 약한 리본 케이블 여럿이 iPhone 로직 보드에 연결되어 있습니다.
    So if I broke the cable that connects the display to the logic board. What replacement part would I need to order now?
    Robert Danson - 답글
    Probably the screen
    Christian Sirolli -
  11. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체, 배터리 분리: 11 단계, 이미지 1/1
    • 하단 디스플레이 케이블 브래킷을 로직 보드에 고정하는 다음 삼-점 Y000 나사 네 개를 분리하세요:
    • 1.2mm 나사 세 개
    • 2.6mm 나사 한 개
    Is it really safe to lay the device fully open like a book? The cable leading to the LCD gets stretched across the sharp edge of the aluminum edge of the back cover.
    u204863 - 답글
    Generally I'd say no, it's not safe. In reality I've seen a bit of variance in the cable length, and sometimes it'll be fine—but mostly I'd be prepared to prop the display up or hold it in place at a slight angle so it doesn't put too much stress on the cables. On prior iPhones it was easy to rubberband the display to a box or a can of soda, and something like that would probably work well here too. Use your own judgment.
    Jeff Suovanen -
    You could stick the suction cup back on, near the right side of the phone, with the blue hook oriented in such a way that it becomes a stand for the screen. That way it won’t open much more than 90 degrees, and leaves both your hands free.
    Mark -
    The tri wing screws are so hard to remove. What's the trick?
    shannon caldwell - 답글
    At first I think I was being too careful and was getting no where. I got better results by pressing down on the screwdriver with more pressure while turning and those little screws came right out.
    LadyTech - 답글
    I cannot remove one of the corner screws in this step and i have used the tweezers and the y000 tri tip and i am afraid that it is stripping it. is there a work around for this step?
    Katherine Monday - 답글
    @katmonday1 No workaround unfortunately. Make sure the driver tip is in good condition and fits the screw correctly. Seat it in the screw, hold the driver perfectly vertical, press down hard (and maintain it), and turn. It’ll come out. If it’s really stripped you’ll have to get more aggressive—try one or more of the techniques in this guide or get some help. Good luck!
    Jeff Suovanen -
    my screwdriver will only remove the 2.6mm screw and not the others, what shall i do?
    AubreyG1 - 답글
    A tip to remember which screw is which as the differences are pretty tiny: I used different colored sharpie fine-points and made a mark on the top of the screws before removing. I thought about having strips of tape that I stuck similar sizes to, but the coloring seemed to work more easily. I only did this for step 11 and it saved me down the road when trying to differentiate the 1.2 and the 1.3mm screws!
    Trey Smith - 답글
    STOP! Before you remove Any screws, be sure to create several bins to hold the various sizes in… or mark them like Trey suggested. I failed to pay attention because I thought they were all the same… they are not. It is very hard to figure out the sizes if you remove them all and store them in a single location.
    John Grant - 답글
    i had a piece of paper with the steps numbered that involved screws. I had double sided tape on the paper and the number of screws and thier position marked. This was so helpful in removing and then finding and installing the tiniest screws on earth. And i have TINY hands. I can’t imagine someone with large paws being able to accomplish any of this.
    Tina Matthews - 답글
    there is one screw thats 1.2 mm but its bigger than the others and will fit in no hole of the entire phone. i got it out bot now i have no idea where it has to go i tried every hole. can somebody help me?
    Lars Göbel - 답글
    what do i do if one of the screws dont want to come off
    Neylley Reynoso - 답글
  12. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 12 단계, 이미지 1/2 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 12 단계, 이미지 2/2
    • 하단 디스플레이 커넥터 브래킷을 분리하세요.
    I am confused, please help. LOL the bracket, the very first one being removed. I see it has three screws the same size and one a different size? I've been trying to fix my daughter's phone and ordered a 0.6 mm Tri Wing screwdriver for iPhone 7 plus /Apple watch. It seems to fit the screws and it seems to be turning them although I can't see that well but they're not coming out. However when I used it on a smaller bracket with two screws they came right out so I'm thinking I don't have the right screwdriver I am at my Wit's End!! I have been working on this phone or attempting to for a while now. I cannot find a list anywhere of the exact size screwdrivers needed to Take apart an iPhone 7 plus. Any help would be greatly appreciated.
    chris west - 답글
    If your tri-wing screwdriver worked for other tri-point screws in the phone, then it should work for the screws you are struggling with! If it feels like the screws are spinning but not coming out, try to use tweezers to pull them out. I often struggle with tri-point screws, and need to apply some downward pressure to remove them. This can be risky though, as you do not want to strip the screw or damage components underneath the bracket. If you continue to struggle, you can give this driver and this bit a try.
    Scott Havard - 답글
    Also be aware that the battery connector might stick to the bottom of the steel bracket. This part had me a bit puzzled at first. lol
    Just gently pry the connector off the steel bracket to release it and be sure the connector isn’t allowed to accidentally reconnect to the board.
    jeffrey griffith - 답글
    I had to use a fingernail to dislodge the bracket. As Jeffrey said, it was apparently stuck to the connector.
    lkollar - 답글
  13. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 13 단계, 이미지 1/3 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 13 단계, 이미지 2/3 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 13 단계, 이미지 3/3
    • Spudger/스퍼저 끝을 사용하여 배터리 커넥터를 로직 보드의 커넥터 소켓에서 들어올리세요.
    • 수리 중에 실수로 소켓에 닿아 휴대폰에 전원이 공급되지 않도록 배터리 커넥터 케이블을 위로 약간 구부려 주세요.
    You could cover the battery socket with a small piece of tape to make sure that it doesn’t accidentally re-connect. It’s not likely to, but I liked the peace of mind.
    Mark - 답글
    on reassembly, make sure that the connector cable is back in place, along side the battery, and not up, or on top in any way.
    Sarr Sheffer - 답글
    I slipped a small piece of paper under the flap.
    MajorCouillon - 답글
    After this step it is worth jumping to step 36 and disconnecting the lighting connector assembly (indicated with the orange rectangle) and connecting the new cable to test it out. After attaching the new lightning connector assembly, reattach the battery, and try plugging it in to see if the new assembly works correctly. If it does, then power down the phone, disconnect the battery, and disconnect the new lightning connector assembly. Then continue. If it doesn’t work, this check will save you a couple of hours of work.
    Evan O - 답글
  14. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체, 디스플레이 어셈블리: 14 단계, 이미지 1/3 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체, 디스플레이 어셈블리: 14 단계, 이미지 2/3 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체, 디스플레이 어셈블리: 14 단계, 이미지 3/3
    • 이 단계에서 케이블을 분리하거나 다시 연결하기 전에 배터리가 분리되었는지 확인하세요.
    • Spudger/스퍼저의 평평한 끝부분 또는 손톱을 사용하여 하단 디스플레이 커넥터 두 개를 로직 보드의 소켓에서 위로 들어올려 분리하세요.
    • 이 케이블을 다시 연결하려면 딱 들어맞을 때까지 한쪽 끝을 눌러주고 반대쪽 끝에도 반복하세요. 가운데는 누르지 마세요. 만약 커넥터가 조금이라도 잘못 정렬되었다면 커넥터가 구부러져 영구적인 손상을 입을 수 있습니다.
    • 휴대폰을 재조립한 다음 빈 화면, 디스플레이에 흰색 선 또는 터치 반응이 부분적 또는 완전하지 않은 경우 두 케이블을 모두 분리하고 조심스럽게 다시 연결하여 제대로 장착하였는지 확인하세요.
    The note about the danger of pressing on the connector incorrectly is very legitimate. Though I find it more practical to use a wide (1.5 cm) case opener tool to press it down all at once. Minimizes risk of bending the connector.
    Talon - 답글
    What can happen if the battery is not disconnected before the two lower display connectors?
    Alextay - 답글
    Hello, by my expierence and what i have learned iphone repair videos you can ‘blow up’ capacitors which one in logic board, screen is sensetive with voltages and etc….
    Darius Varanavičius -
    what are my options if the display connector broke? can it be replaced or do I need to get a whole new screen?
    matomach - 답글
    When I removed the lower display cable bracket in step 12, the top connector stuck to the bracket and became disconnected.
    Grant Crawford - 답글
    My replacement screen wouldn't sit in the display connector properly, (wouldn't clip in both sides at same time) so I made sure it sat on one and it was lined up and got a thin piece of dense sponge and placed that over the connector, then proceeded to install the connector shield and screen works perfectly fine without a hitch. Very good tutorial just earnt me £25 lol
    Joshua Driscoll - 답글
    have the same issue, sometimes it doesn’t sit on the left side, other time not on the other, the difference is iphone not starting at all or looping with apple logo reboot…
    ibisiki -
    Bent the pins on the connector out of place, worked them very carefully back with fine nose tweezers. This was by far the crux of the repair for me.
    nicO - 답글
  15. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 15 단계, 이미지 1/3 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 15 단계, 이미지 2/3 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 15 단계, 이미지 3/3
    • 전면 패널 센서 어셈블리 커넥터 위로 브래킷을 고정하는 삼-점 Y000 나사 세 개를 풀어주세요:
    • 1.3mm 나사 한 개
    • 1.0mm 나사 두 개
    • 브래킷을 분리하세요.
    Posted a comment above on the first step. The screwdriver that I ordered Works taking out these two screens shown in the picture. However it does not work on the first bracket that needs to be removed. It seems that all screw sizes are somewhat different but I'm not finding a list showing different screwdriver sizes needed. Does this make sense? Could anybody please give me some advice on this thank you much.
    chris west - 답글
    I know your comment was posted a long time ago but just in case someone else has the same problem, the only difference in the screws are the lengths. The ends are the same.
    mcr4u2 - 답글
    What happens if you break “tear in half” the black tape stuff?
    assweeetasyou - 답글
    Unfortunately if you tear the black cable you will need to replace it !!!
    Wayne Lyell -
    Chris West the screwdriver that probably came with the kit was pentalobe to get the first two screws out to open the case. you need a .6mm Y tip driver for internal. its deceptively Phillips looking but is not it only has three blades in a Y, not 4 in a +
    Jeremiah Kjensmo - 답글
    I called the y tip a triangle tip until I read these comments. Thanks for the correction
    Kayla Tobin -
    Hello is it if I put wrong screw can damage the board?
    alicenine84 - 답글
    Care should be taken while removing the last 1.0mm screw, on the far right in the picture. This screw is screwed into another screw (or standoff) beneath the bracket. This standoff may come unscrewed and upon removing the bracket you may find the screw and standoff are still attached to the bracket. Do not lose this part if you decide to separate them , the standoff is not a normal phillips, and may require a special driver to reinstall. I used the phillips to start it back in, and relied on the screw to tighten it upon reassembly.
    Benji - 답글
    I know this is late bit a trick I use to put the standoffs in (had to do 2 cause someone lost the screws I was replacing) is to take the screw that goes in it srew them together loosely to give it a fake phillips head then gently screw both into the spot the standoff goes in. you can then take the phillips out (may need to put a spudger between the screw and standoff to keep the standoff down then use a tiny flathead to gently tighten the standoff down. its a few steps but makes life easier if you need to replace it quickly.
    Stephen Patterson -
    I was able to remove the first 1.0 mm three tri-point Y000 screw from the bracket but I cannot for the life of me get the other 1.0 mm screw undone or the one 1.3 mm screw undone. Any tips?
    I tried pressing down a bit harder and I even put the first screw back in to see if it helped me loosen the other two but it did not work.
    My screwdriver was doing the job up until this point, and I’m worried I’ll strip the screw if I keep trying.
    Would appreciate any advice!
    jrosegoep - 답글
    Dear IFixit: First, I want You to know I love your repair guides. I consider You to be the absolute best repair manuals available. But, hopefully as your friend I am going to point out once the bracked is removed a 2.0 mm Standoff screw should appear. It’s 1 of 2 screws holding the Antena Flex Cable in place. Rob
    Robert Schmidt - 답글
  16. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 16 단계, 이미지 1/2 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 16 단계, 이미지 2/2
    • 로직 보드 소켓에서 전면 패널 센서 어셈블리 커넥터를 분리하세요.
    • 이 프레스 커넥터를 다시 연결할 때 구부러지는 위험을 최소화하기 위해 한 번에 한쪽 끝씩 연결하세요.
    Make sure that the orientation of the cable when you attach is correct! See the picture for the correct orientation. If it gets installed 180 degrees out(i.e., the ribbon goes up instead of down, then the earphone, front camera, and Home button will be inoperative. Ask me how I know!?! Worked great when installed correctly!
    Kevin Reilly - 답글
    Thanks Kevin. I would be stuck if I hadn't read your comment!?! Great input.
    Lukas Watts -
    That's save my life!thanks god!
    neg -
    I also made this mistake! Thank goodness it didn’t break anything.
    That Guy - 답글
  17. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 17 단계, 이미지 1/1
    When removing the old adhesive from the edges, duct tape can be useful. Simply use small strips of duct tape and your spudger to press the tape’s adhesive side carefully into the edges of the phone’s display and slowly peel the duct tape away from the display. The duct tape should pick up the remaining adhesive and carry it away from the edges. use the tip of the spudger to gently scrape away any remaining dirt or film from the crease around the edge and repeat the action with a new strip of tape to pick up any dirt, adhesive or grime from the surface. This should save considerable time.
    Benji - 답글
    Thank you for including a link to the iPhone Display Adhesive Replacement guide, this was very helpful!
    Robert O'Brien - 답글
    is it really necessary to remove the display? the screen connectors are delicate and I fear re-assembly errors. I changed the battery and did not remove any screen connectors. no problems.
    jacobra - 답글
    Due to the fact that THIS is the repair guide for replacing the DISPLAY it IS necessary to remove the display connectors. There is another guide for changing the battery -- you might want to follow that one.
    Hannes -
    I did not remove the display and ended up ripping one of the lower display cable ribbons when I turned the phone to remove one of the connectors. Be careful. I had to get a new display and move the Touch ID button.
    Shawn Hime - 답글
    I think that moving the replacement of the seal lower in the chain of events would be more beneficial. I'm replacing the battery, and stretching the adhesive tabs that held the battery in at a low angle kept sticking themselves to the newly-installed adhesive seal.
    In the end, I wound up having to just remove the section of the seal along the bottom of the case :-/
    If I'd been looking at the bigger picture, I'd have wanted to put the seal on right before reattaching the screen cables.
    Rob Russell - 답글
    This guide does not show you the removal process for the top camera assembly. My screen looks like the one pictured but my replacement doesn't have the top connector or any of the front facing camera components and since the ribbon for the connectors looks like its coming out from underneath the display I can't see how to swap it over to the new display.
    Jezagee - 답글
  18. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체, 기압 벤트: 18 단계, 이미지 1/1
    • 기압 벤트를 후면 케이스에 고정하는 다음 Phillips/십자 나사 두 개를 분리하세요:
    • 2.9mm 나사 한 개
    • 2.1mm 나사 한 개
    I skipped this step and go straight to step 25. I skipped it because I couldn’t get the screws to come off. But skipping those step did not prevent me or has any detrimental effects on performing step 25.
    Jamie Liao - 답글
    I agree, I don’t see any reason to remove the Taptic engine to remove the battery…It seems like more of a chance of screwing something else up…keep it simple…
    William Karis - 답글
    If you’re replacing the battery, removing the Taptic Engine gives you a much better chance of removing the battery adhesive strips successfully. To keep them from snagging and breaking, you want to pull them from as low an angle as possible. With the Taptic Engine in the way, you have to pull them at almost 90 degrees, or risk snagging them on the Taptic Engine.
    Jeff Suovanen -
    i can’t get the 2.1 screw 2 come out pls help anyone
    John Bryce - 답글
    I agree with Jamie Liao above. Skips steps 18-24 as described. Before proceeding with step 25, I heated a microwavable hot/cold compress (used to treat muscle strains). I set the iPhone back casing on the heated compress before pulling out the adhesive strips.
    Again, there is no need to do steps 18 through 24.
    Thomas Young - 답글
    i didn’t remove this and had major issues pulling the adhesive strips out. I literally couldn’t grasp them and then when i did, they broke! UGH! I was able to complete the installation but i must have done something wrong because my phone still isnt working. It just ‘flashes’ the apple logo. Won’t do anything else. Should have just taken it in for repair. Now i have to buy a new phone anyway.
    Tina Matthews - 답글
  19. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 19 단계, 이미지 1/2 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 19 단계, 이미지 2/2
    • 기압 벤트를 Taptic Engine/탭틱 엔진 방향으로 조심히 밀어 기압 벤트를 iPhone 하단 가장자리에 고정하는 접착제를 분리하세요.
    Adhesive may require a tiny amount of tugging of the barometric vent to free it…
    Sarr Sheffer - 답글
  20. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 20 단계, 이미지 1/1
    • 벤트를 분리하세요.
  21. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체, Taptic Engine/탭틱 엔진: 21 단계, 이미지 1/2 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체, Taptic Engine/탭틱 엔진: 21 단계, 이미지 2/2
    • Spudger/스퍼저의 평평한 끝을 사용하여 로직 보드 소켓에서 Taptic Engine/탭틱 엔진 커넥터를 분리하세요.
  22. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 22 단계, 이미지 1/1
    • Taptic Engine/탭틱 엔진을 후면 케이스에 고정하는 1.5mm Phillips/십자 나사 세 개를 분리하세요.
    what do you do if the top left screw is not coming out?
    Karrington Dowe - 답글
    There is a little guide pin for the Taptic Engine proper seating
    Landis - 답글
  23. iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 23 단계, 이미지 1/2 iPhone 7 Plus Taptic Engine/탭틱 엔진 교체: 23 단계, 이미지 2/2
    • Taptic Engine/탭틱 엔진을 분리하세요.
결론
기기를 재조립하려면 이 지침을 역순으로 따르세요.
다른 61명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en ko
85%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Scott Havard
회원 가입일: 06/27/16
49,630 평판
안내서 31개 작성하였습니다
댓글 3개
is there a replacement taptic engine available to purchase?
Jody Tamplen - 답글
Did you end up finding one anywhere?
Matthew Lafond -
you can purchase a taptic engine on the ifixit store :-)
I Malloy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 77
30일 전: 304
전체 시간: 42,051
