주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
For iPhone 7-8P, 80% of Touch ID issues are caused by broken home button cable and we can fix the problem by jumping wires on the two layers of wires on the home button cable respectively. Which is very difficult especially when the bottom layer comes with many wires. And that’s when we bring you this new solution. With the help of the iPhone 7-8P Home Button Repair Socket Cable, we can fix the Touch ID problem in a safe and efficient way.
도구
부품
동영상 개요
  1. Press the power button to turn on the phone. The phone turns on normally. There is an alert saying "Unable to activate Touch ID on this iPhone.
    • Press the power button to turn on the phone. The phone turns on normally. There is an alert saying "Unable to activate Touch ID on this iPhone.
    • Try to press the home button. The home button is also unresponsive.
    • Go to Settings > Touch ID & Passcode. The option ‘Add a Fingerprint’ is grayed out.
    • Judging by this, home button relevant circuit or home button cable has malfunctioned.
  2. Take apart the phone and remove the display assembly. Run diode mode measurement of the home button connector. The measured value is normal.
    • Take apart the phone and remove the display assembly. Run diode mode measurement of the home button connector. The measured value is normal.
    • Which indicates that home button relevant circuit is also normal. The home button issue has nothing to do with the logic board.
  3. Next, we need to check the home button cable. Disconnect the home button cable. We can see that the home button cable nearby the socket is broken.
    • Next, we need to check the home button cable. Disconnect the home button cable. We can see that the home button cable nearby the socket is broken.
    • And for iPhone 7/7P/8/8P, 80% of Touch ID issues are caused by broken home button cable. We can fix the broken cable by jumping wires.
  4. LCD iPhone 스크린 수리 키트
    평생 품질 보증이 적용되는 저렴한 옵션.
    키트 쇼핑하기
    수리의 질 말고 비용을 절감하세요.
    키트 쇼핑하기
  5. Cut off the broken cable along with the socket. Then slice open the insulating coating on the cable. Scrape off the insulating coating and then wires on the upper layer with Sculpture Knife.
    • Cut off the broken cable along with the socket. Then slice open the insulating coating on the cable. Scrape off the insulating coating and then wires on the upper layer with Sculpture Knife.
    • Apply some solder paste and paste flux to the bottom layer. Apply the home button repair socket cable to the right position. Solder carefully with the Soldering Iron.
    • Apply some UV Curable Solder Mask to the soldered area. Then solidify the cable under UV Dryer Lamp for 5 minutes.
  6. Next, let’s join up the upper layer of wires by jumping wires. Solder the 0.02mm solder tinned enamelled wire to the corresponding position on the upper layer one by one.
    • Next, let’s join up the upper layer of wires by jumping wires. Solder the 0.02mm solder tinned enamelled wire to the corresponding position on the upper layer one by one.
    • Once done, apply some UV Curable Solder Mask. Then solidify the cable under UV Dryer Lamp for 5 minutes.
  7. Go to Settings > Touch ID & Passcode. The option ‘Add a Fingerprint’ is back to normal. Try to set up Touch ID on the phone. With Touch ID set up successfully on the phone, Touch ID function is also normal.
    • Go to Settings > Touch ID & Passcode. The option ‘Add a Fingerprint’ is back to normal. Try to set up Touch ID on the phone. With Touch ID set up successfully on the phone, Touch ID function is also normal.
    • Follow instructions in the video and learn how to fix iPhone 7 Plus Touch ID Not Working by repairing the broken Home Button Cable.
    • Credit: REWA Technology
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Phryne
회원 가입일: 2019년 11월 17일
5,704 평판
안내서 43개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 33
30일 전: 158
전체 시간: 563
