주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
소개
Follow the steps in this guide to replace the loudspeaker in an iPhone 7. This guide includes instructions for removing the speaker assembly, and peeling off the Wi-Fi diversity antenna which needs to be transferred to your new loudspeaker.
동영상 개요
  1. Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. Attach a suction cup to the lower half of the display assembly, just above the home button. Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • Attach a suction cup to the lower half of the display assembly, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  4. Pull up on the suction cup to create a small gap between the display assembly and the rear case. Insert the flat end of a spudger into the gap. The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
    • Pull up on the suction cup to create a small gap between the display assembly and the rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
  5. Slide the spudger to the left along the lower edge of the iPhone. Twist the spudger to widen the gap between the display and rear case. Twist the spudger to widen the gap between the display and rear case.
    • Slide the spudger to the left along the lower edge of the iPhone.
    • Twist the spudger to widen the gap between the display and rear case.
  6. Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch. Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display. Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
    • Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch.
    • Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
  7. Insert the flat edge of a spudger into the bottom right corner of the device. Twist the spudger to widen the gap between the display assembly and the rear case. Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
    • Insert the flat edge of a spudger into the bottom right corner of the device.
    • Twist the spudger to widen the gap between the display assembly and the rear case.
    • Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
  8. Pull up on the suction cup to lift up the display and open the iPhone. Do not raise the display more than 10º as there are ribbon cables along the right edge of the device connecting the display to the logic board.
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are ribbon cables along the right edge of the device connecting the display to the logic board.
  9. Pull up on the small nub on the suction cup to remove it from the front panel.
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  10. Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place. Be careful not to damage the plastic clips on the top edge of the phone.
    • Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place.
    • Be careful not to damage the plastic clips on the top edge of the phone.
  11. Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case. Open the iPhone by swinging the display up from the left side, like the back cover of a book. Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Remove four tri-point Y000 screws securing the lower connector bracket, of the following lengths:
    • Three 1.2 mm screws
    • One 2.4 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  12. Remove the lower connector bracket.
    • Remove the lower connector bracket.
  13. Use the point of a spudger to lift the battery connector out of its socket on the logic board. Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to  the phone. Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to  the phone.
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  14. Make sure the battery is disconnected before you disconnect or reconnect the cables in this step. Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board. To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  15. Remove the two 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector. Remove the bracket. Remove the bracket.
    • Remove the two 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
    • Remove the bracket.
  16. Disconnect the front panel sensor assembly connector from its socket on the logic board. This press connector should also be reconnected one end at a time to minimize the risk of bending.
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  17. Remove the display assembly.
  18. Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
    • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
  19. Remove the vent. Remove the vent.
    • Remove the vent.
  20. Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board. Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
  21. Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
    • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
  22. Remove the Taptic Engine. Remove the Taptic Engine.
    • Remove the Taptic Engine.
  23. Remove the Phillips screw securing the Wi-Fi diversity antenna to  the rear case:
    • Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
    • One 3.2 mm screw
  24. Remove the following three Phillips screws securing the speaker to the rear case:
    • Remove the following three Phillips screws securing the speaker to the rear case:
    • Two 1.3 mm screws
    • One 2.0 mm screw
  25. Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board. Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board. Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
  26. Use tweezers to derout the antenna cables from their bracket on the logic board. Use tweezers to derout the antenna cables from their bracket on the logic board.
    • Use tweezers to derout the antenna cables from their bracket on the logic board.
  27. Use tweezers to remove the antenna cables from the clip on the speaker. Make sure to grasp the cable near the clip in order to avoid damaging the cable.
    • Use tweezers to remove the antenna cables from the clip on the speaker.
    • Make sure to grasp the cable near the clip in order to avoid damaging the cable.
  28. Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case. Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
    • Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
  29. Remove the speaker.
    • Remove the speaker.
  30. Gently remove the antenna from the clip on the speaker. Gently remove the antenna from the clip on the speaker.
    • Gently remove the antenna from the clip on the speaker.
  31. Gently remove the tab by lifting up with tweezers and separate the tab from the speaker. Gently remove the tab by lifting up with tweezers and separate the tab from the speaker.
    • Gently remove the tab by lifting up with tweezers and separate the tab from the speaker.
  32. Remove the Wi-Fi diversity antenna.
    • Remove the Wi-Fi diversity antenna.
결론
다른 30명이 해당 안내서를 완성하였습니다.
Evan Noronha
회원 가입일: 2015년 02월 05일
181,674 평판
안내서 178개 작성하였습니다
iFixit iFixit 회원
Community
108 회원들
안내서 9,883개 작성하였습니다
My right speaker is currently not working, and I think I will probably be doing his soon on my device. Thank you.
Alexander Wiand - 답글
Hi there
My iPhone 7 has static when calling and the person im calling cannot hear me. Can someone help me or tell me what is the problem? Is it the earpiece speaker or the speaker at the bottom of the iPhone? Please somebody. Thanks.
Deverard Devereux - 답글
Hi. I’ve the same problem. Have you fix with changing?
Alessandro -
I did all and now the iphone is not turning on
Raul G - 답글
that’s really sad. would you may have damaged to any cell while disassembling? because there is no chance for not turning the phone on, if you did it properly.
Sjen -
댓글 쓰기
조회 통계:
24 시간 전: 62
7일 전: 414
30일 전: 1,725
전체 시간: 48,771
