주요 콘텐츠로 건너뛰기
iPhone 8 Pentalobe/펜타로브/별 나사 교체
필요한 것
  1. iPhone 8 Pentalobe/펜타로브/별 나사 교체, Pentalobe/펜타로브/별 나사 분리: 1 단계, 이미지 1/1
    • 시작하기 전에 iPhone 배터리를 25% 이하로 방전하세요. 충전된 리튬-이온 배터리에 실수로 구멍이 생기면 화재를 일으키거나 폭발할 수 있습니다.
    • 분해를 시작하기 전에 iPhone 전원을 꺼주세요.
    • iPhone 하단 가장자리에 위치한 3.5mm pentalobe/펜타로브 나사 두 개를 빼주세요.
    • iPhone 디스플레이를 열게되면 방수 씰이 손상됩니다. 이 단계를 수행하기 전에 교체용 씰을 준비하거나 봉인 없이 iPhone을 재조립할 경우 액체에 노출되지 않도록 주의하세요.
    just how long are those screws- i turn and turn and turn and the lift off is soooo slight, seemingly insignificant…
    An. Jahnke - 답글
    I would recommend, from the very beginning, dumping all tools out of the kit (if you got it) and using that white paper tool box as a tray to organize the screws and braces in. It’s nice to work over because it catches screws well and makes it easy to see them if you drop any.
    Johnny Emrica - 답글
    That’s a great idea thank you
    Mohamed Dekkiche -
    Screw to the left of the charging port will not come out. Screw on the right came out no problem. Any ideas?
    Bill Maher - 답글
    I already replaced my iPhone 8 battery with one from iFixit and honestly I wasn't impressed. It worked well for a few months, but then I started noticing the peak performance capability dropping significantly thereafter. I followed the initial charging instructions to a tee and only let it drop below 20% once a month. Normal everyday use for me... no intense apps like games, etc. I considered having Apple do it this time around, but for these older models they don't keep the batteries in-stock and you have to give them your phone for up to a week. So in the end, I opted to try another battery from iFixit instead. Hopefully this one will last longer.
    tripmusic - 답글
    How with the gigantic kit do I not have a 3 1/2 pentalobe driver the very first screwdriver I reach for and that I need is not in any of these kits. What’s up with that?
    Michael Stephens - 답글
결론
기기를 재조립하려면 이 지침을 역순으로 따르세요.
다른 14명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en ko
100%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Adam O'Camb
회원 가입일: 04/11/15
196,191 평판
안내서 416개 작성하였습니다
댓글 2개
This guide is used by many other guides as first step! Don´t laugh about it.
VauWeh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 13
7일 전: 62
30일 전: 182
전체 시간: 13,595
