주요 콘텐츠로 건너뛰기
소개
Use this guide to correctly apply replacement adhesive under your iPhone's display after a repair. Replacing the adhesive can help maintain your iPhone's water resistance. The pre-cut adhesive strips are very delicate and are easily damaged if not applied correctly, so you may want to have a spare on hand if following this guide for the first time.
Be sure you purchase adhesive that matches the color of your display to maintain the original look of the phone.
This procedure applies to all iPhone 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, X, XS, and XS Max models. (Prior models did not use display adhesive.)
Before you begin, you should have already removed your iPhone's display assembly and set it aside. Detailed instructions for each model can be found at the following links:
동영상 개요
  1. Begin by removing all the old display adhesive around the perimeter of your iPhone's case. You can pull the adhesive off with tweezers, or roll it up on the tip of a spudger with a roll-and-pull motion. You can pull the adhesive off with tweezers, or roll it up on the tip of a spudger with a roll-and-pull motion.
    • Begin by removing all the old display adhesive around the perimeter of your iPhone's case.
    • You can pull the adhesive off with tweezers, or roll it up on the tip of a spudger with a roll-and-pull motion.
    When you do not really want to get rid of the glue, but you do not have it, you can tie the glue off and pick it up with tweezers! You can remove it.
    yejin jun - 답글
  2. Use the tip of your spudger to remove any remaining smaller bits of adhesive. Use the tip of your spudger to remove any remaining smaller bits of adhesive.
    • Use the tip of your spudger to remove any remaining smaller bits of adhesive.
    Its crucial to get this done properly, otherwise the glue strip doesn’t sit properly. After thoroughly picking with a spudger, I cleaned up the remainder with a q-tip and brake cleaner.
    Nick Pope - 답글
  3. If you're reinstalling your existing display rather than replacing it with a new one, be sure to remove any remaining adhesive from the back of your display as well.
    • If you're reinstalling your existing display rather than replacing it with a new one, be sure to remove any remaining adhesive from the back of your display as well.
    This is important. About half of my old adhesive stuck to the display. Be sure to look under the clips at the top that hold the screen in place. Adhesive there may make it difficult to properly align the screen.
    donkkrueger - 답글
  4. Using a lint-free cloth (or coffee filter) with a bit of isopropyl alcohol, clean the areas of the case and rear display where you removed the old adhesive. For best results, swipe your cleaning cloth in one direction, not back and forth.
    • Using a lint-free cloth (or coffee filter) with a bit of isopropyl alcohol, clean the areas of the case and rear display where you removed the old adhesive.
    • For best results, swipe your cleaning cloth in one direction, not back and forth.
    • This will help remove any remaining adhesive residue and prep the surface for the new adhesive.
    I used an Isopropyl alcohol patch from a first aid kit.
    Joe Teichert - 답글
    I used a pre-moistened isopropyl cleaning wipe for eyeglasses, works great and cheap too. Heed the advice to only go in one direction as well - that adhesive will just get pushed all over if you don’t.
    anpav - 답글
    The video shows using a Q-tip with Isopropyl. Don’t use a Q-tip, the cotton will just stick to the remaining adhesive and make it hairy. An eyeglasses cleaning cloth moistened with acetone did the trick for me. Don’t get it drippy wet with the acetone, it may attack some plastics.
    bradiac - 답글
  5. Begin peeling  the backing from your replacement adhesive, starting with the large tab on the bottom edge. Don't completely separate the backing yet.
    • Begin peeling the backing from your replacement adhesive, starting with the large tab on the bottom edge.
    • Don't completely separate the backing yet.
    Saw in a different persons YouTube video the battery connector was causing a problem with the film because its disconnected and up, they cut a small slit in the film, Might test laying the film hold the adhesive on the phone before starting and see if thats a problem depending on phone and adhesive. Never hurt to check
    Dwayn Draper - 답글
    +1 Great tip. Thanks
    Critter -
    Great tip. Had this issue.
    robert langley - 답글
    I cut a strip of backing film and placed it under the battery connector, then manipulated it’s ribbon to make it lay flat.
    bradiac - 답글
  6. Before applying the adhesive, make sure your iPhone's battery connector lays flat so it doesn't press against the blue release liner. It's okay to temporarily reconnect the battery if needed—just be sure to disconnect it again before installing the display. Carefully align the exposed lower edge of the adhesive strip with the bottom edge of your iPhone's case. Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Before applying the adhesive, make sure your iPhone's battery connector lays flat so it doesn't press against the blue release liner. It's okay to temporarily reconnect the battery if needed—just be sure to disconnect it again before installing the display.
    • Carefully align the exposed lower edge of the adhesive strip with the bottom edge of your iPhone's case.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • When it's correctly aligned, gently press the exposed lower adhesive strip into place.
    The three pictures show him peeling the adhesive backing away as he lays the adhisive in the phone. I found it easier to peel the whole backing away and then very carefully align the whole adhesive before gently pressing any of it in place. This way, you can be sure it will line up perfectly and avoid having to redo it.
    Joe Teichert - 답글
    Props to Dwayn Draper for his above comment above. I see no way to do this step without either pressing the battery connector down (which would energize the logic board and perhaps be bad), or cutting a hole in the adhesive backing to accommodate the battery connector while it sticks up. I laid the whole blue thing over the phone and used a sharpie to mark where the connector stuck up. Then I used a sharp pair of scissors to cut out the marked part of the backing. This allowed the adhesive to line up nicely around the edges of the phone.
    Joe Teichert - 답글
    I tried peeling off the whole backing like the comment above suggested and I completely messed up this part. thinking about this next time i would align it first with the backing on, then carefully peel it back, similar to how this ifixit article directs.
    Radd Guarin - 답글
    i destroyed the seal immediately cause of my thumbs not being in the right spot as i tried to peel the protector back a bit… more of a personal error, everything else in my build was easy peasy… i wish it was a bit clearer on the seal where to start from, the picture shown and the protective backing on my seal was slightly different so i wasnt sure if i was starting from the correct side to start peeling away and think that may have led to my error as well…. hopefully i can remember mine isnt waterproof anymore and ill try to replace it again next time something goes wrong on this phone
    douglas - 답글
    Before exposing the adhesive, test fit the packet to see which way it orients. There was several cutouts on mine for the various components which protrude above the perimeter. The adhesive looked pretty symmetrical, but the backing only went one way.
    bradiac - 답글
  7. Continue peeling away the backing from the adhesive, gently pressing the adhesive into place from the bottom of your iPhone to the top. If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with fresh adhesive. If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
    • Continue peeling away the backing from the adhesive, gently pressing the adhesive into place from the bottom of your iPhone to the top.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with fresh adhesive.
    • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
    Please take your time with this and slowly get done right. I almost messed up on this step because I was rushing.
    Jeffrey Robinos - 답글
  8. Finish separating the adhesive backing and discard it. Finish separating the adhesive backing and discard it.
    • Finish separating the adhesive backing and discard it.
    Doesn’t make sense, the screen connectors are below gasket. How do you attach screen after installing gasket?
    fm Haynie - 답글
    The screen connectors are INSIDE the PERIMETER of the screen adhesive.
    John - 답글
  9. Use the tip of a spudger to press all the adhesive into place around the entire perimeter of your iPhone. Be careful not to press on the camera or other internal components. Be careful not to press on the camera or other internal components.
    • Use the tip of a spudger to press all the adhesive into place around the entire perimeter of your iPhone.
    • Be careful not to press on the camera or other internal components.
    Press hard. Some of the adhesive came off the phone as I was peeling the backing away in the step 11. You want to make sure it stuck on the phone so it doesn’t stay attached to the backing.
    Joe Teichert - 답글
  10. Use the flat edge of your spudger to press the adhesive into place at all four corners of your iPhone. Use the flat edge of your spudger to press the adhesive into place at all four corners of your iPhone.
    • Use the flat edge of your spudger to press the adhesive into place at all four corners of your iPhone.
  11. Grab the small pull tab (located at one of the corners) and peel off the large front liner from the adhesive. On some versions, this liner may consist of up to four smaller pieces rather than a large single piece. On some versions, this liner may consist of up to four smaller pieces rather than a large single piece.
    • Grab the small pull tab (located at one of the corners) and peel off the large front liner from the adhesive.
    • On some versions, this liner may consist of up to four smaller pieces rather than a large single piece.
  12. Completely separate the front adhesive liner(s) and discard it. At this point you may still have very thin strips of release liner covering all of the adhesive, which prevents it from accidentally sticking to anything while you begin reassembling your iPhone. Don't remove these small release liners just yet.
    • Completely separate the front adhesive liner(s) and discard it.
    • At this point you may still have very thin strips of release liner covering all of the adhesive, which prevents it from accidentally sticking to anything while you begin reassembling your iPhone. Don't remove these small release liners just yet.
    My iPhone 6s Plus kit did not have the thin strip of release liners but worked fine.
    spitasky2 - 답글
    The release liners either stuck to the main backing as I pulled it off, or it pulled the adhesive itself away from the phone! Be very careful, or you’ll have a sticky mess trying to get the adhesive back in place.
    Joe Teichert - 답글
    The iphone 6s does not have this thin film so when I was attaching the screen I ruined my adhesive. Not sure why this one is different but it definitely makes things more challenging.
    Brett Gragg - 답글
    Same here. I ended up placing a wide strip cut from the front adhesive liner across the top end where the display cables attach, as well as placing the rear adhesive liner crossways over the phones mid section to help keep from touching and/or damaging the adhesive during reassembly.
    bradiac - 답글
  13. Refer to your iPhone's display replacement guide in order to: Reconnect all display cables
    • Refer to your iPhone's display replacement guide in order to:
    • Reconnect all display cables
    • Reconnect the battery
    • Reinstall the cable connector cover brackets, and secure their screws.
    • This is a good time to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue.
  14. iPhone 7 / 7 Plus only: Before installing your display, check the condition of the black gaskets on the two small screw bosses on the bottom edge of your display, near the home button. If the gaskets are misaligned, use tweezers to carefully recenter them.
    • iPhone 7 / 7 Plus only: Before installing your display, check the condition of the black gaskets on the two small screw bosses on the bottom edge of your display, near the home button.
    • If the gaskets are misaligned, use tweezers to carefully recenter them.
    • iPhone 6s and 6s Plus models don't have these gaskets.
    The gaskets on my iPhone 7 are actually sleeves that slide onto the screw bosses, covering both sides. Be sure both gaskets are fully in place, not only pressed on one side of the boss. This is not shown in the pictures here.
    zachcramer - 답글
    My iPhone 7+ didn’t have gaskets or sleeves, bought directly from Apple, SIM free/unlocked. I’m the 1st to open it.
    jeffrey griffith - 답글
    same case for my iPhone 7+ Model A1784 , it didn’t have gaskets or sleeves, bought directly from Apple, SIM free/unlocked. I’m the 1st to open it also.
    Xavier LESTEVEN -
  15. While supporting the display, use tweezers to begin peeling off the final release liners, exposing the adhesive. While supporting the display, use tweezers to begin peeling off the final release liners, exposing the adhesive. While supporting the display, use tweezers to begin peeling off the final release liners, exposing the adhesive.
    • While supporting the display, use tweezers to begin peeling off the final release liners, exposing the adhesive.
  16. Continue removing the release liner from the entire perimeter of the iPhone. Take care not to touch the exposed adhesive. Take care not to touch the exposed adhesive.
    • Continue removing the release liner from the entire perimeter of the iPhone.
    • Take care not to touch the exposed adhesive.
  17. The release liner may consist of two or more pieces. As you remove the final piece, you may need to pause and reposition the display. The release liner may consist of two or more pieces. As you remove the final piece, you may need to pause and reposition the display.
    • The release liner may consist of two or more pieces. As you remove the final piece, you may need to pause and reposition the display.
  18. Hold the display out of the way as you remove the final piece of release liner. Hold the display out of the way as you remove the final piece of release liner. Hold the display out of the way as you remove the final piece of release liner.
    • Hold the display out of the way as you remove the final piece of release liner.
  19. Carefully align the top edge of the display with the top edge of the phone body. Position the display so that the tabs along the top edge fit into place just underneath the top edge of the iPhone's case.
    • Carefully align the top edge of the display with the top edge of the phone body.
    • Position the display so that the tabs along the top edge fit into place just underneath the top edge of the iPhone's case.
  20. Before closing up the display, check to make sure that all cables are clear. If any cables get pinched between the edge of the display and the body of the iPhone, they may be damaged beyond repair.
    • Before closing up the display, check to make sure that all cables are clear.
    • If any cables get pinched between the edge of the display and the body of the iPhone, they may be damaged beyond repair.
  21. As you lower the display into place, apply gentle pressure against the display's bottom edge so that the top edge stays flush with the top edge of the iPhone. This also prevents the two small gaskets near the home button from scraping against the iPhone's lower edge. Press on the sides of the display near the top of the iPhone, and work your way down to click the display into place.
    • As you lower the display into place, apply gentle pressure against the display's bottom edge so that the top edge stays flush with the top edge of the iPhone.
    • This also prevents the two small gaskets near the home button from scraping against the iPhone's lower edge.
    • Press on the sides of the display near the top of the iPhone, and work your way down to click the display into place.
    My new LCD screen part didn’t come with gaskets! And I forgot about the ones on the old cracked screen until too late.
    Therese Peffer - 답글
    Does anyone know where to buy replacement gaskets?
    Redding - 답글
    Oddly enough, my iPhone 7+ never had these foam gaskets from the factory.
    I bought it new online, SIM free/unlocked from Apple and I’m the 1st to open it up.
  22. In order for the adhesive to bond correctly, you'll need to apply even pressure around the perimeter of your iPhone. The camera bump complicates matters, but you can compensate by laying your iPhone face-down and placing coins around the perimeter. You can use coins of any denomination, so long as they are as thick or slightly thicker than the camera bump. If your iPhone has a high-gloss finish, such as Jet Black, add a strip of tape around the perimeter to protect the finish before placing any coins.
    • In order for the adhesive to bond correctly, you'll need to apply even pressure around the perimeter of your iPhone. The camera bump complicates matters, but you can compensate by laying your iPhone face-down and placing coins around the perimeter.
    • You can use coins of any denomination, so long as they are as thick or slightly thicker than the camera bump.
    • If your iPhone has a high-gloss finish, such as Jet Black, add a strip of tape around the perimeter to protect the finish before placing any coins.
    • Place a coin at each corner of your iPhone, and place two coins on either side of the camera bump.
    • Place additional coins around the entire perimeter of your iPhone.
    • Using a hair dryer or heat gun, evenly heat the side edges all the way around the iPhone until they are slightly too hot to touch. The heat will help the adhesive form a more complete bond. Don't overheat the iPhone, or you may cause the battery to ignite or damage other heat-sensitive components, like the display.
    What happens if I skip this step of heating the phone and just placing some heavy books on my iPhone 6s? I have this question because I don’t own neither a heat gun nor a hair dryer. Pls help
    Sreeram ASRK - 답글
    Your phone will work fine. This step is more about getting the adhesive to bond securely to help create a waterproof seal. If you don’t have any way to heat it, using more weight and leaving it there for a longer period of time may help.
    Jeff Suovanen -
    You can set you iphone screen UP in the sun for a while to heat it up pretty well before the pressure/weight step
    John - 답글
    With the potential of electronics, I would like to have seen an quantitative temperate referenced as well as the qualitative (subjective).
    Thomas Tritt - 답글
    Also, an actual spacer would helped - coins kept sliding off as I was heating them.
    Thomas Tritt - 답글
  23. While the iPhone is still hot, grab at least four or five of your heaviest hardcover books, and place them squarely on top of your iPhone. The coins may leave a slight impression on the bottom book cover, so don't use anything valuable. Leave the books in place for about thirty minutes.
    • While the iPhone is still hot, grab at least four or five of your heaviest hardcover books, and place them squarely on top of your iPhone.
    • The coins may leave a slight impression on the bottom book cover, so don't use anything valuable.
    • Leave the books in place for about thirty minutes.
    Love the book selection :P
    skrolikowski - 답글
  24. Remove the books and use your fingers to press firmly on all four corners of the display. Press for about 3 seconds and then release.
    • Remove the books and use your fingers to press firmly on all four corners of the display.
    • Press for about 3 seconds and then release.
    • Remember to install your iPhone's two pentalobe screws.
    Very good tutorial but why this last step ?
    Easy Repair - 답글
    A bit of belt and braces.
    Rob leach - 답글
    Step 25: Pray that it all works and your phone turns on :p
    skrolikowski - 답글
    Seems like a better idea to move reinstallation of the pentalobe screws to Step 21 or immediately after it.
    D Davis - 답글
    Two problems:
    1) The adhesive for the bottom of the phone has a tiny extra lip. My first attempt was to line up the corners rather than the middle. This resulted in the adhesive being be a bit short at the top.
    2) During the final assembly, I could not get the phone to close. Double bad. I tried to peel up the screen to realign and tore one of the screen’s ribbon cables! I just received my second screen and adhesive today.
    I believe these two areas could be easily added to the above instructions. Everything else went fine.
    Arthur Yeh - 답글
    Ifixit please sell and release the adhesive for samsung s9+ to restore my water resistance after battery replacement.
    cutterpillowm - 답글
    They couldn’t care less about Samsung phones, they are like most apple biased company ever.
    Dinan Blueje -
결승점
다른 384명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 2013년 08월 06일
247,477 평판
안내서 212개 작성하였습니다
iFixit iFixit 회원
Community
104 회원들
안내서 9,243개 작성하였습니다
I just bought few iPhone 7 adhesives from my supplier, and I noticed that the adhesive is not really fitting on the frame.
The iFixit shop pictures show us the iPhone 7 Plus adhesive for black color and the iPhone 7 adhesive for white color.
The iPhone 7 Plus seems to be more precise and correct than the iPhone 7 one : the iPhone 7 Plus one respect the screw hole at upper left corner for example, but the iPhone 7 one doesn’t, it has extra curves (same as iPhone 6s lower left corner) and it doesn’t take up the full width of the frame edge.
Can anyone show us the shape of an original adhesive from a brand new iPhone 7 to compare ?
Martial B - 답글
This was the trickiest part of my screen replacement. Slim double sided adhesives always intimidate me because you only get one chance to line it up. I succeeded on my first attempt by following this guide and taking my time to line up the first edge as best as I could. The sides are the hardest part as they are very thin and I almost failed getting them lined up. Luckily I hadn’t pressed them down and was able to correct my alignment. Good preperation of the phone by removing the old adhesive completely and cleaning the area is my number one recommendation.
Nathan Stark - 답글
Adhesive makes everything harder. I chose to replace the adheasive on my 6s plus during a battery replacement, and it was easily the hardest part. No fault of Ifixit or this guide… the instructions above are spot on. But the cleaning of the adheasive takes forever, easily tripled my total repair time. And its really, really nerve racking to place the new adheasive. I do stuff like that all the time, but this was nuts. The strips are so tiny and delicate! Be really, really careful and take your time. This earns its “moderate” difficulty and then some.
Corban Young - 답글
wow that was hard to get in place. clean the edges well and use isopropyl alcohol. also practice a lot before removing the cover protection.
ericrose62 - 답글
i did it. i did the last step before using the books..
pantelg95 - 답글
After doing this step, is it still waterproof?
M. Refeir Yudio Ikhwanudin - 답글
As long as the adhesive is not damaged at ANY point during installation then yes it will be waterproof.
David Sladdin - 답글
Thank you! Went better than expected on my 6s.
Gagerminnix - 답글
Used a tooth pick and soft tooth brush to clean around the edges and then Is-propyl alcohol to finish before the seal. Ready :)
William Hudson - 답글
I totally failed this haha, had to remove some of the new adhesive to be able to put my screen back on the iphone. It holds now but %#*@ that was the longest part...
Casano Matthieu - 답글
Do you have to change it when only changing the battery to keep it being waterproof?
dajonny - 답글
Yes. Technically speaking, it’s your phone you don’t have to do anything you don’t want to. But it is strongly recommended as it’ll restore the dirt/dust proof resistance.
Puls -
Hi there,
I was wondering, is it okay to replace the screen without replacing the adhesive, will the screen fall off in and places or anything.
Basically i’m asking is it a requirement to replace the adhesive when replacing the screen?
Thank you~
Roberto Bombeeto - 답글
@thymother Not required at all; screws and brackets secure the display, and it’s in no danger of falling out regardless of whether the adhesive is there or not. The adhesive seems to be more for a little extra cushioning during hard-presses and as a dust/water seal.
Jeff Suovanen -
Took me two attempts, luckily I did both screen and battery at the same time, had two screen adhesives and the second one I nailed. 10/10 guide, just take your time.
Alex Bouchard - 답글
First iPhone screen replacement a breeze just had to be very attentive. Adhesive install you have to take it nice and easy.
Jeffrey Liangjokechai - 답글
Hi there,
How do you choose the colour of the display assembly adhesive for the IPhone 6S Plus?
bobby li - 답글
The adhesive color doesn't matter, unless you're concerned about keeping up appearances. In that case opposites attract. Black LCD = White ADH.
Puls -
Won’t the hair dryer blow the pennies off the back of the phone?
Michael Winston - 답글
Thanks Jeff! worked a treat
Kola - 답글
Oh and cutting a small hole in the backing for the battery connector was a genius idea!
Kola - 답글
It was better for me to start with one of sides less control issues. deltakilo
david koval - 답글
Used this as a guide to replace the LCD and digitizer in Motorola Droid Mini (XT1030). Main difference is that the screen is not held in by screws, only adhesives. Sat the phone face down on a paper towel with books on it, while on a 3d printer bed heated to 80 degrees C, for total of about 20 minutes (IR thermometer measured screen/frame at around 65C). Will see how well this holds up…
rbol - 답글
I would pay extra for a kit that includes an alignment jig for each specific phone type. You only get ONE shot to get the alignment of the adhesive correct, and I’ve never managed to do it.
Either that, or sell the replacement displays with the adhesive already attached to the back of the display assembly so all I have to do is swap over the home button, attach my cables, peel off the protective cover over the adhesive, and just lay it down.
Rocky Carr - 답글
You should add a note that getting isopropyl in the screen will permanently ruin it. Don’t ask me how I know.
Justin Howlett - 답글
Even a brand new phone, sides tend to unstick causing slightly raised bezels. I used a hairdryer and a lot of pressure to reseat the edge. Seems flush and uniform without any lifting
jerry123456789101112 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 356
지난 7일: 1,995
지난 30일: 9,493
전체 시간: 197,298
