주요 콘텐츠로 건너뛰기
이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
iPhone X 배터리 교체
필요한 것
  1. iPhone X 배터리 교체, Pentalobe/펜타로브 나사: 1 단계, 이미지 1/1
    • 시작하기 전에 iPhone 배터리를 25% 이하로 방전하세요. 충전된 리튬-이온 배터리에 실수로 구멍이 생기면 화재를 일으키거나 폭발할 수 있습니다.
    • 분해를 시작하기 전에 iPhone 전원을 꺼주세요.
    • iPhone 하단 가장자리에 위치한 6.9mm-길이 pentalobe/펜타로브 나사 두 개를 빼주세요.
    • 나사가 벗겨지거나 손상된 경우 나사를 교체하세요.
    • iPhone 디스플레이를 열게되면 방수 봉인이 손상됩니다. 이 단계를 수행하기 전에 교체용 봉인을 준비하거나 봉인 없이 iPhone을 재조립할 경우 액체에 노출되지 않도록 주의하세요.
    There are 6.81mm long screws!
    Daniel - 답글
    One of the pentalobe screws is stripped :( - suggestions for how to get it out?
    cgtyoder - 답글
    same situation here
    kaunomarcius - 답글
    Same issue for me too, how do I get the stripped screw out?
    patronics - 답글
    Update: I was able to get the “stripped” screw out using another Pentalobe-2 screwdriver bit from another company. It seems it wasn’t the screw, but the screw driver that was actually stripped. Hence why the other screwdriver kit I got came with 3 of this bit, I suppose.
    patronics - 답글
    I ended up going to a jewelry store, and they drilled down into the screw, with of course an incredibly tiny bit. That allowed me to insert the P2 driver, and I was able to unscrew it at that point. Good luck!
    cgtyoder - 답글
    Same issue with the stripping. The tip of the iFixit P2 head in my $70 kit just ground off on the first screw and that was that. Not much you can do.
    Kyle Harris - 답글
    yes correct the same happened to me, the screws were perfect shaped never been open and as soon as i used the P2 it stripped the screws, seems like the P2 is slightly smaller but Dremel kit with a very small drill bits and precise knife tool is the way to go.
    Dulce Vidal - 답글
    This step in automatically followed through, without any thought. Why remove these screws? Can anybody explain? The Screen is detachable all the same, with them well screwed in…
    Uri - 답글
    These screws attach to a plate that’s part of the screen half of the phone. If you succeed in detaching the screen without removing those, it would seem reasonable that you will have damaged that plate or its ability to keep the two halves together.
    Dan Long -
    @Dan Long is right
    Uri -
    Clean out the pentalobe screw heads first so the tool goes all the way in. A small sewing needle works well to loosen any build up and then press some putty/chewing gum into the screw head and pull away quickly for a final clean out.
    William Olstad - 답글
    The this kit should include screws because you’re going to strip them. Can’t even get past step one. Did anybody figure this out
    justin - 답글
    Never opened my phone ever, when I went to look at the first step.. I noticed one of my screws was stripped. I thought it was impossible, but I removed the non stripped one, then once I got to the stripped one.. I learned my assumptions were correct. I bought this one straight from the apple site years ago ahaha Any tips to remove the stripped screw?
    Clarence Williams - 답글
    William Olstad's tip about cleaning the screws with a needle and a bit of poster putty worked well for me. There was a lot of crud in there! The opening is shallow, so it's easy to see how the screwdriver wouldn't catch with even a bit of grit in the way, No problem getting the pentalobe screws out with the ifixit screwdriver.
    punkinann - 답글
    If all else fails, very carefully cut a slot across the head of the screw with a Dremel tool using a diamond bit that dentist will gladly give you - I ask my dentist for used bits; and chuck them in a drill bit chuck designed for Dremel. The slot allows you to use a tiny, straight blade screwdriver. You can reuse the screw or replace it with a new pentalobe screw.
    Dan Smith - 답글
  2. iPhone X 배터리 교체, 깨진 부분에 테이프 붙이기: 2 단계, 이미지 1/3 iPhone X 배터리 교체, 깨진 부분에 테이프 붙이기: 2 단계, 이미지 2/3 iPhone X 배터리 교체, 깨진 부분에 테이프 붙이기: 2 단계, 이미지 3/3
    • iPhone 스크린에 금이 갔다면 유리에 테이프를 붙여 수리하는 동안 추가 파손을 막고 신체적 상해를 방지하세요.
    • iPhone 스크린 전체가 덮일 때까지 투명 포장 테이프를 겹쳐 붙이세요.
    • 수리하는 동안 튀는 유리 파편으로 부터 눈을 보호하기 위해 보안경을 착용하세요.
    • 만약 다음 몇 과정에서 흡입 컵이 스크린에 잘 붙지 않으면, 강력 테이프(덕트 테이프 등)를 접어 손잡이 형태로 만들어 붙이고 들어 올리세요.
    • 다른 모든 방법이 실패하면 흡입 컵에 초강력 순간접착제를 붙일 수 있습니다.
  3. iPhone X 배터리 교체, Anti-Clamp/안티-클램프 지침: 3 단계, 이미지 1/3 iPhone X 배터리 교체, Anti-Clamp/안티-클램프 지침: 3 단계, 이미지 2/3 iPhone X 배터리 교체, Anti-Clamp/안티-클램프 지침: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Clamp
    $24.95
    구매
    • 다음 세 단계는 여는 절차를 더 쉽게 하기 위해 고안된 도구 안티-클램프에 대한 설명입니다. 안티-클램프를 사용하지 않는다면 세 단계를 건너뛰고 다른 방법을 사용하세요.
    • 안티-클램프 사용법에 대한 전체 지침은 이 안내서를 확인하세요.
    • 파란색 손잡이를 뒤로 당겨 안티-클램프의 팔을 잠금 해제하세요.
    • 팔을 휴대폰의 왼편 또는 오른편 가장자리 위로 밀어 주세요.
    • 흡입 컵을 휴대폰의 하단 가장자리에 배치하세요—전면에 하나, 후면에 하나.
    • 적절한 위치에 컵을 함께 꽉 쥐고 흡착하세요.
    • 휴대폰 표면이 너무 미끄러워 안티-클램프가 잘 고정되지 않으면 테이프를 사용하여 표면에 더 잘 고정되게 할 수 있습니다.
  4. iPhone X 배터리 교체: 4 단계, 이미지 1/3 iPhone X 배터리 교체: 4 단계, 이미지 2/3 iPhone X 배터리 교체: 4 단계, 이미지 3/3
    • 파란색 손잡이를 앞으로 당겨 팔을 고정하세요.
    • 손잡이를 시계 방향으로 360도 돌리거나 컵이 늘어나기 시작할 때까지 돌리세요.
    • 흡입 컵이 서로 정렬된 상태를 유지하는지 확인하세요. 정렬에서 벗어나기 시작하면 흡입 컵을 약간 풀고 팔을 다시 정렬하세요.
  5. iPhone X 배터리 교체: 5 단계, 이미지 1/3 iPhone X 배터리 교체: 5 단계, 이미지 2/3 iPhone X 배터리 교체: 5 단계, 이미지 3/3
    • iOpener를 가열하여 안티-클램프의 팔에 끼워 넣습니다.
    • 헤어 드라이어, 열선총 또는 핫 플레이트를 사용할 수도 있지만—과도한 열은 디스플레이 및/또는 내부 배터리를 손상할 수 있으므로 신중히 진행하세요.
    • iPhone 하단 가장자리에 놓이도록 iOpener를 접으세요.
    • 접착제가 풀려서 틈이 생길 때까지 1분 정도 기다리세요.
    • 스크린 자체가 아닌 스크린과 플라스틱 베젤 밑에 여는 픽을 끼우세요.
    • 안티-클램프가 충분한 틈을 만들지 못하면 열을 더 가하고 핸들을 1/4 바퀴 돌리세요.
    • 한 번에 1/4 바퀴 이상 돌리지 말고 매번 돌릴 때마다 1분 정도 기다리세요. 안티-클램프와 시간에 맡기세요.
    • 다음 세 단계는 건너뛰세요.
    DO NOT separate the glass from the plastic bumper or rim around it. These instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body. It is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - 답글
    Thanks for pointing this out! I'll revise this step to clarify this point.
    Arthur Shi -
  6. iPhone X 배터리 교체: 6 단계, 이미지 1/1
    • iPhone 하단 가장자리를 가열하면 디스플레이를 고정하고 있는 접착제가 부드러워져서 보다 쉽게 ​​열 수 있습니다.
    • 헤어 드라이어 또는 열선총, 혹은 iOpener를 준비하여 iPhone 하단 가장자리를 약 1분 동안 가열하면 접착제가 부드러워집니다.
    • 헤어 드라이어나 열선총을 사용하는 경우 스크린이 손상될 수 있으므로 너무 강하게 가열하지 마세요.
    General tip regarding heating necessary to remove adhesive:
    consider using a heated tip of a small screwdriver or metal spudger (not the one made of plastic, provided in kit), rather than to heat the device itself.
    Uri - 답글
    You then need to be careful about the temp of the tool which if hot enough can melt plastic components or harm them. Keeping the heat source (heat gun) far enough away from the object that you’ll eventually melt the glue but would be much harder to melt components. I try to keep 4” or 5” gap between the source & object
    Sandman619 -
    Thanks for the info. Could a air convector do the job
    dominique.br - 답글
    When opening a device that has previously been worked on, and on which the adhesive might not have been replaced, be extremely carful when opening the phone. It will open much more easily than expected. If you’re not careful you might rip a cable.
    jonpol - 답글
    Is this tool required or can I just use the Anti-Clamp by itself.
    Mikail - 답글
    If you have a 3d printer, heat the bed to 80c and put the phone screen side down on it for 30 secs
    philip.joseph123 - 답글
  7. iPhone X 배터리 교체: 7 단계, 이미지 1/2 iPhone X 배터리 교체: 7 단계, 이미지 2/2
    • 단일 흡입 핸들을 사용하는 경우 유리의 구부러진 부분을 피하면서 휴대폰 하단 가장자리에 사용하세요.
    If you were using some form of screen protector, it may come off first as soon as you pull on the suction cup. Do not be alarmed. That is normal behavior.
    Alain-Daniel Wa-Baguma - 답글
    3m VSB double stick tape will stick to the screen when the suction cups fail (see my comment on step 1)
    Tawan Khamapirad - 답글
  8. iPhone X 배터리 교체: 8 단계, 이미지 1/3 iPhone X 배터리 교체: 8 단계, 이미지 2/3 iPhone X 배터리 교체: 8 단계, 이미지 3/3
    • 흡입 컵을 확실하고 일정한 압력으로 위로 당겨 전면 패널과 후면 케이스 사이에 약간의 틈을 만드세요.
    • 스크린 자체가 아닌 스크린의 플라스틱 베젤 밑에 여는 픽을 끼우세요.
    • 디스플레이를 제자리에 고정하는 방수 접착제는 매우 강합니다; 이 초기 틈을 만들려면 상당한 힘이 들어갑니다. 틈을 여는데 어려움을 겪고 있다면 더 많은 열을 가하고 여는 도구를 넣을 수 있을 만큼 틈이 생길 때까지 스크린을 위아래로 부드럽게 들었다 놨다하여 접착제를 약하게 만들어주세요.
    In addition to safety goggles, I would recommend you also wear good gloves to avoid getting cut with the glass as you try to pry it open.
    The top about applying more heat and gently rocking the screen up and down to weaken the adhesive did the trick for me. Thank you!
    Monil Shah - 답글
    There needs to be more clarity on where to shove the opening pick into. There is actually two openings that the pry tool can be forced into: one below the black plastic bezel, and one above the black plastic bezel. When I heated my screen with a warming pad and pulled up the suction cup, it actually pried apart above the black plastic bezel which removed the touch screen from the display panel. With this being the first newer iPhone I'd opened since the 3GS, I didn't realize that I was opening the wrong opening as the directions only mentioned one opening and did not warn of this. I was pretty disappointed in the lack of mentioning this, as I was taking my time and following it to the tee. As a result, it destroyed my original iPhone screen.
    Caleb Davison - 답글
    DO NOT separate the glass from the plastic bumper or rim around it. As someone else noted, these instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body of the phone. When pulling upwards with the suction cup, it is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - 답글
    Thank you for pointing this out! I've updated the step to reflect this.
    Arthur Shi -
    The suction cup doesn't work at all... The minimum force I apply to lift it up, it comes off completely. This is very frustrating!!!
    Mario Silva - 답글
  9. iPhone X 배터리 교체: 9 단계, 이미지 1/3 iPhone X 배터리 교체: 9 단계, 이미지 2/3 iPhone X 배터리 교체: 9 단계, 이미지 3/3
    • Opening pick/여는 픽을 iPhone 하단 왼쪽 모서리부터 왼쪽 가장자리를 따라 위로 밀어서 디스플레이를 제자리에 고정하는 접착제를 잘라주세요.
    • 여는 픽을 3mm 이상 끼우지 마세요. 내부 부품을 손상할 수 있습니다.
  10. iPhone X 배터리 교체, 스크린 정보: 10 단계, 이미지 1/1
    • iPhone 오른편 가장자리를 따라서 민감한 케이블이 지나갑니다. 케이블을 손상할 수 있으므로 이곳에 픽을 끼우지 마세요.
    Wouldn’t it be better to put this part BEFORE the step where you have to pry open the phone?
    Jan D. Höllwarth - 답글
  11. iPhone X 배터리 교체: 11 단계, 이미지 1/3 iPhone X 배터리 교체: 11 단계, 이미지 2/3 iPhone X 배터리 교체: 11 단계, 이미지 3/3
    • iPhone의 하단 가장자리에 픽을 다시 넣고 오른쪽 가장자리를 따라 위로 밀어서 접착제를 계속 분리하세요.
    • 디스플레이 케이블을 손상할 수 있으므로 픽을 3mm 이상 끼우지 마세요.
    If you have flat feeler gauges (for adjusting engine valve tappet clearance, ignition points … old school) the .003” thick gauge goes right in. Work your way up in thickness until you can get the pic or supplied pry tool in. Don’t insert metal feeler gauge in too far, just enough to hold crack open. I didn’t need to use the suction cup. I used a hot/cold gel pack heated in microwave to heat edges to soften glue a bit. Made sure it wasn’t so hot I couldn’t stand it on my skin.
    William Olstad - 답글
  12. iPhone X 배터리 교체: 12 단계, 이미지 1/3 iPhone X 배터리 교체: 12 단계, 이미지 2/3 iPhone X 배터리 교체: 12 단계, 이미지 3/3
    • 디스플레이의 상단 가장자리는 접착제와 클립으로 고정되어 있습니다.
    • Lightning 포트 방향으로 디스플레이를 조심히 당기거나 흔들면서 여는 픽으로 디스플레이 상단 모서리 주위를 밀어주세요.
    • 너무 세게 힘을 가하면 클립은 부서집니다. 인내심을 가지고 신중하게 작업하세요.
    • 전면 패널 센서 어레이가 손상될 수 있으므로 픽을 3mm 이상 끼우지 마세요.
    • 픽을 반대쪽 모서리로 밀고 디스플레이를 고정하는 나머지 접착제를 자르세요.
    These are the best instructions I’ve ever read for anything.! Thank you!
    Peter Andrew - 답글
  13. iPhone X 배터리 교체: 13 단계, 이미지 1/1
    • 흡입 컵의 작은 손잡이를 당겨 전면 패널에서 분리하세요.
  14. iPhone X 배터리 교체: 14 단계, 이미지 1/3 iPhone X 배터리 교체: 14 단계, 이미지 2/3 iPhone X 배터리 교체: 14 단계, 이미지 3/3
    • 책의 뒷 표지처럼 디스플레이를 왼편을 위로 펼쳐서 iPhone을 열어주십시오.
    • 아직 디스플레이를 완전히 분리하지 마십시오. 여전히 약한 리본 케이블 여럿이 iPhone 로직 보드에 연결되어 있습니다.
    • 사진 처럼 프레임이 디스플레이와 함께 분리되고 기기에 끼지 않도록 확인하세요.
    • 휴대폰에 작업하는 동안 디스플레이를 다른 물건에 기대어 세워 놓으십시오.
    • 재조립하는 동안 디스플레이를 제자리에 놓고 상단 가장자리를 따라 클립을 정렬한 다음 상단 가장자리를 조심스럽게 눌러 제자리에 고정시킵니다. 제대로 들어맞지 않으면 디스플레이 주변의 클립 상태를 점검하고 구부러지지 않았는지 확인하세요.
    My phone came apart in a different way and looks not right the little box at the top of the display as actually bolted to the top of the frame body I think something went really wrong when I opened it.
    Mike Kostersitz - 답글
    It opens like a book but be careful not to open it all the way — only as far as shown in the photo. Otherwise it will strain the thin cable that connects the sensor module and then no more FaceID for you (or, as it turns out me). This could have been made more explicit in the instructions.
    Richard Tucker - 답글
    It opens like a book but be careful not to open it all the way  … the small stainless steel tabs that hold the screen around the metal frame, that are on the bend place (right side of the phone)… are tend to bend, you can straighten them back to 90 deg. but the plastic base that they are on? very fragile- watch out not to break the plastic bezel … it may come apart of the glass.
    dabur872 - 답글
    Advice for re-assembly: Before closing up the phone with the seal, check if phone is powering up again and speaker, mic and sensors are still working. If done this check even before installing the board connector bracket in Step 13.
    Alexander Nowak - 답글
  15. iPhone X 배터리 교체, 디스플레이 어셈블리: 15 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • 로직 보드 커넥터 브래킷을 고정하는 Y000 나사 다섯 개를 풀어주세요:
    • 1.1mm 나사 세 개
    • 3.1mm 나사 한 개
    • 3.7mm 나사 한 개
    • iPhone 손상을 피하기 위하여 수리하는 내내 빼놓은 각각의 나사를 기억하여 원래 자리로 정확히 돌려놓으세요.
    One thing I found helpful for replacing the screws was to use only the 000screwdriver tip, without the handle. This way, the tip isn’t magnetized and the screw doesn’t tend to ‘roll’ off the screwdriver tip (the screw has almost no mass, so the head (largest surface) is pulled around to the side of the screwdriver tip when magnetized).
    Rich May 23, 2020
    ungodly - 답글
    My 3.1mm screw had a stripped head, could not remove it. (Factory defect, this iPhone was never opened)
    So I had to give up removing the display assembly, and jumped directly to battery replacement, Step 20.
    That was tricky as I had to keep the display at 90º with a risk of breaking display connectors, but hopefully the replacement went well.
    I would not recommend to do this but to follow the guide, but, in case someone encounters a similar issue, that could help!
    vingu - 답글
    My 1.1mm screw had a stripped head. Used a 3mm steel drill to cut the head off (just 1 mm deep haha) so i could remove the bracket.
    Renout - 답글
    Be careful on reassembly. Keep the screen supported and not moving. I had difficulty getting the screws in and ended up ruining the screen connectivity at the back of the screen where the ribbon cables go in near the center. I was trying to hand hold the screen and it ended up moving around too much.
    SETH GREEN - 답글
    To keep track of the screws, I copy the photos showing their places, then arrange these photos on document in Pages, print it. Next I apply two sided sticky tape (the roll-on type). So all screws have their corresponding places …
    Max Glanzmann - 답글
  16. iPhone X 배터리 교체: 16 단계, 이미지 1/1
    • 브래킷을 분리하세요.
    • 브래킷이 가볍게 부착되어 있을 수 있습니다. 조심히 하지만 확실하게 들어 올려 분리하세요.
    • 재조립 할 때는 디스플레이를 제자리에 봉하기전에 iPhone 전원을 켜고 모든 기능을 테스트하는 것이 좋습니다. 작업을 계속하기 전에 iPhone 전원을 완전히 끄는 것을 잊지마세요.
    I tested it, then proceeded to close up the device without the bracket. Do I need to reopen and install? All connections are good?
    monastra7 - 답글
    The bracket helps those many connectors underneath maintain good contact. Probably in the short term nothing bad will happen, but I’d hang onto the bracket and reinstall it when convenient.
    Jeff Suovanen -
    Agree with Jeff
    cgtyoder -
    I tested all imaginable functionality on the new OLED screen. Taptics are fine. Then, I noticed that the battery wasn't charging. Any ideas as to what could have gone wrong?
    Monica - 답글
    for me, the replacement battery was completely dead, small panic when the power-on button was pressed, but quickly realised that this was the situation, and now watching the phone take a power cycle.
    James Stanbridge - 답글
    Before clicking the screen assembly back, I tried to test the iPhone by pushing the start button, but nothing happened. After taking off the bracket, reseating the plugs I tried again - nothing happened! Then I plugged in the charging cable connected with the iMac, and it started immediately. So if the phone does not start using the startup button, it might just be a glitch when reconnecting the battery.
    Max Glanzmann - 답글
  17. iPhone X 배터리 교체: 17 단계, 이미지 1/2 iPhone X 배터리 교체: 17 단계, 이미지 2/2
    • Spudger/스퍼저 또는 깨끗한 손톱으로 배터리 커넥터를 로직 보드의 커넥터 소켓에서 들어올리세요.
    • 이 보드 및 다른 보드 연결 부분을 둘러싼 검정색 실리콘 씰을 손상시키지 마세요. 이 씰은 물과 먼지의 침입을 추가 방지합니다.
    • 수리 중에 실수로 소켓에 닿아 휴대폰에 전원이 공급되지 않도록 커넥터를 로직 보드에서 바깥쪽으로 약간 구부려 주세요.
    cosa può succedere se non si disconnette la scheda logica'?
    luca.valli - 답글
    note: be careful not to crush or puncture your battery at this step!! I gave mine a minor dent, which I hope wont be a problem.. but something to keep in mind for fxlks in the future!
    Noal Balint - 답글
    Thanks, already did it)
    Stephen Hedrick -
  18. iPhone X 배터리 교체: 18 단계, 이미지 1/2 iPhone X 배터리 교체: 18 단계, 이미지 2/2
    • Spudger/스퍼저 또는 손톱으로 전면 패널 센서 어셈블리 커넥터를 분리하세요.
  19. iPhone X 배터리 교체: 19 단계, 이미지 1/2 iPhone X 배터리 교체: 19 단계, 이미지 2/2
    • Spudger/스퍼저 또는 손톱을 사용하여 OLED 패널 케이블 커넥터를 분리하세요.
    • 이와 같은 프레스 커넥터를 다시-붙이려면 조심스럽게 정렬하여 한쪽을 제대로 들어맞을 때까지 아래로 누른 다음 다른 쪽도 반복하세요. 가운데 부분은 누르지 마세요. 커넥터가 잘못 정렬되어 있을 경우 핀이 구부러져 영구적인 손상을 입을 수 있습니다.
    Snap ‘em in like little Legos.
    Ray Johnson - 답글
    Maybe the manual should flip step 17 and 18 (as the digitizer cable from 18, is in the way of the OLED cable of step 17) ?
    Renout - 답글
  20. iPhone X 배터리 교체: 20 단계, 이미지 1/2 iPhone X 배터리 교체: 20 단계, 이미지 2/2
    • Spudger/스퍼저를 사용하여 소켓에서 디지타이저 케이블 커넥터를 들어 올려 분리하세요.
    • 이 커넥터의 오목한 위치는 재연결을 까다롭게 합니다. 천천히 정렬한 다음 손가락 끝으로 조심스럽게 눌러주세요—한쪽 끝을 먼저 누른 다음 다른 쪽 끝을. 딸깍하는 느낌으로 제자리에 고정됩니다.
    • 수리를 마친 후 스크린에 터치 반응이 없는 부분이 생긴 경우 배터리를 분리한 다음 이 커넥터를 다시 제대로 들어맞게 장착하고 소켓에 먼지 또는 기타 장애물이 없음을 확인하세요.
    This was probably the hardest part other than trying to get the screen off with the crappy suction cups. I re-installed the bracket only the find out that the touch screen would not respond to touch. Had to remove the five screws, remove the bracket and reseat the recessed screen connector. Reseating the bracket took another 10+ minutes. I carefully used the angled forceps to grab the cable and align the connector being careful not to damage the cable.
    Once you have the connector seated, I would reconnect the battery, power on the phone, and check the touch screen response before re-installing the bracket (step 13).
    Yeah, this was probably the trickiest part of the reassembly. The power connector cable kept getting in the way so I moved it carefully but fully out of the way. Then it was a matter of fiddling around with it a bit and being careful not to force it on.
    Jeffrey Hoy -
    I was positive that I had messed something up, I had powered up the phone to test three different times and everything seemed find except there was no touch at all. On my fourth attempt, I carefully examined everything for dust and debris (blowing gently), and I did notice that a corner of the connector (more like part of the ribbon) was bent slightly, and I straightened it. I don't know if it was the ribbon or some tiny debris, but after reseating a fourth time, it worked.
    Pol Llovet - 답글
    Very important part of the tutorial. Be careful and patience! In my case the screen and camera didn't respond after assemble, so I tried again to reconnect the connector like tutorial said and it worked well. Now my iPhone feel like a new one 💪🏼
    Efrain Maestre - 답글
  21. iPhone X 배터리 교체: 21 단계, 이미지 1/3 iPhone X 배터리 교체: 21 단계, 이미지 2/3 iPhone X 배터리 교체: 21 단계, 이미지 3/3
    • 전면 패널 센서 어셈블리 플렉스 케이블이 제 위치에 살짝 붙어있습니다.
    • 접착제가 분리될 때까지 케이블을 조심히 들어올리세요.
    Do this sensor affect face id?
    bonglkv - 답글
    It is part of the face id part so yes. This is the ear piece too so if the ribbon tears there is a chance the ear piece will stop working as well.
    Stephen Patterson - 답글
    Be super careful handling this ribbon particularly. I did a battery install and, when I was done, I had a phone with a new battery and no Face ID. That’s a $300 Apple repair, and no 3rd party shop will touch it. I believe the ribbon lays vertically (i.e., perpendicular to the “floor” of the phone, against the side edge of the battery. During the re-install, I must have forced the ribbon into position after seating the connector, causing fatal flexing of the ribbon. (Don’t know this for sure, but I see another comment saying that this cable is part of Face ID.) Anyway, bottom line: BE CAREFUL REMOVING AND REINSTALLING THIS RIBBON!
    Jonathan Pines - 답글
    My flex cable was more than lightly adhered in place. I needed to use a guitar pic or similar to help encourage adhesive to separate. I wouldn’t pull too hard like shown in pictures unless you had just the right grip on the ribbon cable so as to avoid damaging flex cable. See note above (5/31/20)
    William Olstad - 답글
    Bizarre — it turns out my whole front panel sensor assembly came entire off of the front screen and is stuck to the logic board.
    Karl Jarvis - 답글
    I also found the glue quite recluctant to release so I applied a second or two of heat using the wife's hair dryer which softened it and the cable lifted much easier then. Be careful not to apply too much heat though which could then impact other internal components.
    LosBenitos - 답글
    Cho ít cồn 90° vào để mềm keo dễ tháo
    huuhaukimngan - 답글
    my iphone x doesn't have a front panel sensor? in fact, it looks completely different than the picture???
    Kenneth McLeod - 답글
    @kennethmcleod, most likely you've separated the screen frame from the screen itself. We see this most commonly when people neglect to remove the pentalobe screws next to the charging port. Usually the cure is to take out those screws, then repeat the screen removal process on the frame that's still attached to the phone.
    Jerry Wheeler -
    You don't need to disconnect the front sensor to change the screen. Just leave it connected and remove from the screen side.
    Anthony Boshell - 답글
  22. iPhone X 배터리 교체: 22 단계, 이미지 1/1
    I tried this and broke the cable can it still repair
    Alexis Rodriguez - 답글
    At this point I would have found it easier to remove the glue from the edges than later on when I was reassembling it. I bought the kit that had the replacement glue in it.
    Grant - 답글
    Excellent guide! Would love to have a link to moving the sensor assembly from the old display to the new here.
    Nicole - 답글
    CAUTION:
    Removing the Taptic Engine or Speaker in next step is optional and the guide continues as this was per se needed.
    Unnecessary work and also If you remove the speaker you lose the adhesive gasket and this is not included in the scope of delivery of the "Battery replacement" offering.
    So do not remove and avoid losing waterproofing.
    Julian Gonzalez - 답글
  23. iPhone X 배터리 교체, Lower Speaker/하단 스피커: 23 단계, 이미지 1/2 iPhone X 배터리 교체, Lower Speaker/하단 스피커: 23 단계, 이미지 2/2
    • iPhone 하단 근처의 접지 패드 세 줄을 건드리지 않도록 주의하세요.
    • Taptic Engine/탭틱 엔진 및 스피커 하단의 브래킷을 고정하는 나사 일곱 개를 풀어주세요:
    • 1.9mm Y000 나사 두 개
    • 1.2mm Y000 나사 한 개
    • 1.2mm Y000 나사 한 개
    • 2.4mm Phillips/십자 나사 한 개
    • 1.7mm Phillips/십자 나사 한 개
    • 1.5mm Phillips/십자 나사 한 개
    For battery replacement:
    It is not necessary to remove Taptic Engine and speaker to replace a battery. Go straight to the step #33
    Additional video: https://youtu.be/2GfBOlJEW10
    Alexander - 답글
    I wish I seen this before I did all that! Thank you for that information. Next time I do something like this. I'm gonna pay more attention to the comments.
    Eric Marino -
    Removing the Taptic Engine and speaker greatly improves your chances of getting the battery adhesive strips out intact. If those break, you’ll have a much tougher time.
    Jeff Suovanen -
    Boy, I tried to skip removing these items but was unable to get the glue strips out with them in place, not much to grab and tabs were kind of stuck to a seam in the battery, and hard to tell the difference between the seam and the strip tabs. For me I had to remove these items to get this done.
    marshallburchard -
    I stopped removing things after getting the display side off. There were 3 screws stripped on the speaker cover which wouldn't come out so I punted. Just pried the battery out with a smudger tool and some patience, starting at the top and working towards the bottom. New battery is in and working fine.
    Andy Price - 답글
    The 2.4mm screw identified as “green” needs a Y000 screwdriver
    seb6po - 답글
    Thanks for not removing the following steps. this made me break the connector for the bottom speakers >:(
    Andrew Romano - 답글
    The color codes are missing from my display — only on this step.
    nat2 - 답글
    The screws color and quantities in list don’t match the schematic ! I wish i had a magnetic screw mat before starting, because not only i removed the Taptic Engine and speaker unnecessarily, but i also lost a screw ?
    fb.mailing.lists - 답글
    For first timer, dont think its possible to skip these steps and remove battery. It’s hard to remove the glue
    Wex - 답글
    Does anyone know the purpose of this bracket "with grounding pads"? What would be the possible side effects if it was damaged or not connected properly during reassembly?
    Anne Aunyme - 답글
    I had to remove the tactic and speaker could not get the glue strips out so glad the steps to do so were in this guide.
    P Bond - 답글
    Sure would like to know WHY the warning "Be careful not to touch the three rows of grounding pads..." What would or could happen if I did touch them??
    Chad Gagnon - 답글
    Removing the battery strips is a major PITA, just skip this step and everything onwards, remove the one strip on the top part of the battery (according to step 33) and for the bottom part of the battery, pry it off with a plastic spudger.
    Yes, this is not the elegant solution, but the quickest and easiest one. This method is better, as you don't want to keep the old battery anyway, so why bother. (You must not puncture the battery though! But as long as you're only working with a plastic tool and are careful, nothing can happen from my experience.)
    speaker gasket - 답글
  24. iPhone X 배터리 교체: 24 단계, 이미지 1/2 iPhone X 배터리 교체: 24 단계, 이미지 2/2
    • 배터리와 가장 가까운 가장자리에서 브래킷을 들어올리세요. 작은 플렉스 케이블을 통해 연결되어 있으므로 완전히 제거하지 마십시오.
  25. iPhone X 배터리 교체: 25 단계, 이미지 1/2 iPhone X 배터리 교체: 25 단계, 이미지 2/2
    • 브래킷을 잡아 방해되지 않도록 치워놓고 spudger/스퍼저의 끝을 사용하여 플렉스 케이블을 들어 올려 분리하세요.
  26. iPhone X 배터리 교체: 26 단계, 이미지 1/1
    • 브래킷을 분리하세요.
    My bracket was in two pieces.
    Jim Steward - 답글
  27. iPhone X 배터리 교체: 27 단계, 이미지 1/2 iPhone X 배터리 교체: 27 단계, 이미지 2/2
    • 스피커 커넥터 커버를 고정하는 2.1mm Y000 나사를 풀어주세요.
    L'unique vis non?
    Easy Repair - 답글
    Effectivement ;-) Merci pour les bons yeux et la remarque !
    Claire Miesch -
  28. iPhone X 배터리 교체: 28 단계, 이미지 1/1
    • 스피커 커넥터 커버를 분리하세요.
  29. iPhone X 배터리 교체: 29 단계, 이미지 1/2 iPhone X 배터리 교체: 29 단계, 이미지 2/2
    • Spudger/스퍼저 끝을 사용하여 스피커 커넥터를 들어 올려 분리하세요.
    As mentioned in a comment by timblake2112 (see step 29), this step is not necessary and can be skipped skipped. I would advise you to do so, as removing your speaker is guaranteed to ruin your gasket and rubber seal. This will result in loss of water resistancy of your iPhone and could potentially harm the sound quality of your speaker.
    Try removing the Taptic Engine without removing the speaker. It might still be possible removing the battery adhesive strips and your speaker will stay in its original condition.
    speaker gasket - 답글
  30. iPhone X 배터리 교체: 30 단계, 이미지 1/2 iPhone X 배터리 교체: 30 단계, 이미지 2/2
    • 스피커를 들어 올릴때 방금 분리한 스피커 플렉스 케이블이 손상되지 않도록 주의하세요. 필요한 경우 스피커가 나올 수 있도록 케이블을 배터리쪽으로 구부리세요.
    • iPhone 케이스 가장자리 근처 스피커 상단 가장자리 밑으로 spudger/스퍼저를 삽입하세요.
    • 조심스럽게 들어 올려 스피커 상단 가장자리를 조금 들어 올립니다.
    • 스피커를 재설치할 때 플렉스 케이블의 위치를 ​​확인하고 케이블이 스피커 밑에 갇히지 않도록 주의하세요.
  31. iPhone X 배터리 교체: 31 단계, 이미지 1/3 iPhone X 배터리 교체: 31 단계, 이미지 2/3 iPhone X 배터리 교체: 31 단계, 이미지 3/3
    • 스피커의 측면 가장자리를 잡고 좌우로 흔들어 iPhone 하단 가장자리에 고정하는 접착제를 분리하세요.
    • 접착 개스킷이 분리될 때까지 스피커를 iPhone 하단 가장자리에서 당겨 주세요.
    speaker gasket - 답글
  32. iPhone X 배터리 교체: 32 단계, 이미지 1/2 iPhone X 배터리 교체: 32 단계, 이미지 2/2
    • 스피커를 분리하세요.
    • 스피커의 접착 개스킷은 재사용할 수 없습니다. 핀셋으로 남은 접착제를 벗겨주세요.
    • 물과 먼지의 침입을 방지하려면 재조립할 때 접착 개스킷을 교체하세요. 개스킷이 제대로 부착되도록 약간의 isopropyl/이소프로필 알코올과 보풀이 없는 천 또는 커피 필터로 닦아주세요. 스피커에 새 개스킷을 설치한 다음 스피커를 설치하세요.
    You don’t need to remove the speaker and ruin its gasket. You can wiggle and slide the taptic engine out without removing the speaker. I’ve done this twice on rear shell replacement jobs.
    timblake2112 - 답글
    Maybe I'm a bit daft, but where's the instruction just how to line up the speaker gasket when replacing? I only have one so I'd like to avoid wrecking it. And I completely cleaned off the old one in order to do a good job of things. Why no simple instruction from part supply link?
    MrRoundel - 답글
  33. iPhone X 배터리 교체, Taptic Engine/탭틱 엔진: 33 단계, 이미지 1/2 iPhone X 배터리 교체, Taptic Engine/탭틱 엔진: 33 단계, 이미지 2/2
    • Taptic Engine/탭틱 엔진을 고정하는 2.3mm Phillips/십자 나사를 풀어주세요.
  34. iPhone X 배터리 교체: 34 단계, 이미지 1/2 iPhone X 배터리 교체: 34 단계, 이미지 2/2
    • Spudger/스퍼저를 사용하여 Taptic Engine/탭틱 엔진 플렉스 케이블을 소켓에서 똑바로 들어 올려 분리하세요.
  35. iPhone X 배터리 교체: 35 단계, 이미지 1/1
    • Taptic Engine/탭틱 엔진을 분리하세요.
  36. iPhone X 배터리 교체, 배터리: 36 단계, 이미지 1/1
    • iPhone X 배터리는 stretch-release/늘여-떼는 접착제 네 개로 후면 케이스에 고정되어 있습니다—상단에 한 개, 하단에 세 개.
    • 각 접착제 끝에는 배터리의 측면 가장자리에 살짝 붙어있는 검정색 당김-탭이 있습니다.
  37. iPhone X 배터리 교체: 37 단계, 이미지 1/3 iPhone X 배터리 교체: 37 단계, 이미지 2/3 iPhone X 배터리 교체: 37 단계, 이미지 3/3
    • 첫 번째 배터리 접착 탭을 배터리 하단 가장자리에서 떼어내세요.
    • 각 탭의 중앙에는 작은 고리가 있습니다; 탭을 잡는데 어려움이 있다면 공구를 루프 사이로 넣어주세요.
    • 날카로운 도구로 배터리를 찌르지 않도록 주의하세요. 구멍난 배터리는 위험한 화학 물질을 유출하거나 화재가 발생할 수 있습니다.
    hole breaks instantly on pulling. adhesive tab does not release from side of battery
    Dominick garton - 답글
    I had a lot of trouble with this. Only two came out properly and the others snapped off. I heated up the back of the phone with a hair dryer then used the flat end of the spudger to slowly pry it off right to left, bottom to top.
    Grant - 답글
    just pry it off, why bother
    speaker gasket - 답글
  38. iPhone X 배터리 교체: 38 단계, 이미지 1/3 iPhone X 배터리 교체: 38 단계, 이미지 2/3 iPhone X 배터리 교체: 38 단계, 이미지 3/3
    • 위의 단계를 반복하여 배터리 하단 가장자리에 있는 나머지 접착 스트립 두 개를 제거하세요.
    • 중앙 접착 탭 근처의 스피커 케이블 커넥터가 손상되지 않도록 주의하세요.
  39. iPhone X 배터리 교체: 39 단계, 이미지 1/3 iPhone X 배터리 교체: 39 단계, 이미지 2/3 iPhone X 배터리 교체: 39 단계, 이미지 3/3
    • 다음 단계에서는 각 탭을 당겨 배터리 아랫면의 접착제를 천천히 늘여주세요. 이 특수 늘여-떼는 접착제는 늘어날 때 고정하는 힘을 잃고 손에 끌려나오므로 배터리를 쉽게 들어 올릴 수 있습니다.
    • 성공 확률을 높이려면:
    • 배터리를 누르지 마세요. iPhone을 옆으로 단단히 잡으세요.
    • 스트립을 평평하고 주름없게 당겨주세요.
    • 스트립이 충분히 늘어나서 떨어지도록 매우 천천히 당기세요. 스트립을 늘려 제거하는데 약 15-30초가 걸립니다.
    • 스트립이 배터리의 하단 가장자리를 따라 걸리지 않도록 낮은 각도로 당기세요.
    • 배터리 아랫면에서 접착 스트립이 끊어져 회수할 수 없는 경우 다른 스트립으로 이동하고 다음 절차로 진행하세요.
  40. iPhone X 배터리 교체: 40 단계, 이미지 1/3 iPhone X 배터리 교체: 40 단계, 이미지 2/3 iPhone X 배터리 교체: 40 단계, 이미지 3/3
    • 외부 배터리 접착 탭 중 하나를 잡아 배터리에서 iPhone 아래쪽으로 천천히 당기세요.
    • 배터리와 후면 케이스 사이에서 스트립이 빠져나올 때까지 스트립을 일정한 힘으로 당기세요.
    • 스트립은 원래 길이의 몇 배로 늘어납니다. 필요하다면 스트립을 계속 당기면서 늘어난 스트립을 배터리에 가깝게 다시-잡고 당기세요.
    • 제거 과정에서 배터리 접착 탭이 끊어지는 경우 손가락 또는 무딘 핀셋을 사용하여 남아있는 접착제를 찾아 계속 당기세요.
    • 배터리 아랫면에서 접착 스트립이 끊어져 회수할 수 없는 경우 나머지 스트립을 제거하려 노력하고 다음 절차를 따라 진행하세요.
    I found it easier to grab the end of the adhesive strip sideways with narrow tweezers, "twirl " the tweezers to wrap the strip around them a few times, then gently pull the strip with the tweezers.
    punkinann - 답글
  41. iPhone X 배터리 교체: 41 단계, 이미지 1/3 iPhone X 배터리 교체: 41 단계, 이미지 2/3 iPhone X 배터리 교체: 41 단계, 이미지 3/3
    • 이전 단계를 반복하여 반대쪽에 있는 스트립을 제거하고 중앙 스트립을 마지막으로 남겨 둡니다.
  42. iPhone X 배터리 교체: 42 단계, 이미지 1/3 iPhone X 배터리 교체: 42 단계, 이미지 2/3 iPhone X 배터리 교체: 42 단계, 이미지 3/3
    • 스피커 플렉스 케이블에 걸리지 않도록 주의하며 중앙 스트립을 제거하세요.
  43. iPhone X 배터리 교체: 43 단계, 이미지 1/2 iPhone X 배터리 교체: 43 단계, 이미지 2/2
    • 최종 당김 탭은 Face ID 하드웨어와 매우 가깝습니다. Apple 만이 손상된 Face ID를 복원할 수 ​​있으므로 작업에 주의하세요.
    • 배터리 셀 상단의 가장자리에 있는 최종 접착 스트립 당김 탭을 벗기고 분리하세요.
    surtout ne pas passer avec la spatule par le bas, vous risqueriez d arracher la nappe du volume et du nfc,
    Ludovic Klein - 답글
  44. iPhone X 배터리 교체: 44 단계, 이미지 1/3 iPhone X 배터리 교체: 44 단계, 이미지 2/3 iPhone X 배터리 교체: 44 단계, 이미지 3/3
    • 최종 접착 스트립을 당겨 제거하세요.
    • 배터리가 iPhone에서 분리될 때 스트립이 배터리를 날릴 수 있으므로 배터리에 손을 얹어 지키세요—그러나 배터리 자체를 누르지는 마세요. 더해진 압력은 접착 스트립을 배터리 아랫면에서 끊을 수 있습니다.
    • 접착 스트립 네 개를 모두 성공적으로 제거했다면 다음 단계는 건너뛰세요.
    • 배터리 아랫면에서 접착 스트립이 끊어져 회수할 수 없는 경우 다음 절차로 진행하세요.
  45. iPhone X 배터리 교체: 45 단계, 이미지 1/2 iPhone X 배터리 교체: 45 단계, 이미지 2/2
    • 접착 스트립이 끊어지고 배터리가 후면 케이스에 붙어 있으면 iOpener를 준비하거나 헤어 드라이기를 사용하여 후면 케이스 배터리 바로 뒤를 가열하세요.
    • 후면 케이스가 편안하게 만질 수 없을 정도로 약간 뜨거워질 때까지만 iPhone을 가열하세요. iPhone을 과열하지 마세요. 실수로 배터리가 점화될 수 있습니다.
    • iPhone을 뒤집어 놓고 배터리 아랫면에 강한 줄(치실 또는 얇은 기타 줄)을 끼우세요.
    • 손가락을 보호하기 위해 줄 끝을 천으로 감싸거나 장갑을 끼세요.
    • 톱질 동작으로 배터리 길이를 따라 끈을 좌우로 잡아 당겨 접착제를 분리하세요. 접착제는 느리게 변형되기 때문에 다소 시간이 걸릴 수 있지만 인내심을 갖고 견디면 떨어질 것입니다. 배터리를 변형 또는 손상시키지 마세요.
    • iPhone 배터리를 들어 올리기 위해 비집는 도구를 사용하는 경우 매우 조심하세요. 조심하지 않으면 배터리 바로 아래의 리본 케이블 또는 무선 충전 코일이 손상될 수 있습니다.
    if you use a guitar string, remember NOT to use a METALLIC guitar string.
    Ross King - 답글
    flexible plastic rules with alcohol work too
    Wex - 답글
    I can confirm that IPA (Iso Propyl Alcohol) and, in my case, the plastic plectra in any iFixit kit worked a treat.
    P Bond -
  46. iPhone X 배터리 교체: 46 단계, 이미지 1/1
    • 배터리 하단 가장자리를 잡고 iPhone에서 분리하세요.
    • 새 배터리를 설치하기 전에 Taptic Engine/탭틱 엔진 및 스피커를 먼저 설치하세요. 이는 배터리를 설치할 때 올바르게 정렬하도록 돕습니다.
    • 교체 부품에 접착제가 제공되지 않은 경우 배터리를 설치할 때 이 안내서를 참조하여 배터리의 접착 스트립을 교체하세요.
    • 재조립 후 강제 재시작을 하세요. 이는 여러가지 문제를 방지하며 문제 해결을 단순화 합니다.
    When reinstalling the battery, the Taptic Engine does serve as a useful way to orient the battery, but it should also be noted that if you push right up against that as you install the battery (as I did) and don’t pay any attention to power connector (shown in step 14), there is a risk that the connector from the battery will not line exactly with the connector port on the board. Mine was only off a mm so I had to get a little creative to try to get it to stretch to reach and connect to the port on the board. Just keep that in mind as you place the battery (with adhesive) down.
    Jesse Bolane - 답글
    Connect the battery first then put it in place. Other way it is hard to adjust power connector.
    Alexander - 답글
    I would also HIGHLY suggest re-installing the speaker as well before installing the battery - it was a very tight squeeze as the bottom-right of the battery was snug against the speaker when I tried to get that back in.
    cgtyoder - 답글
결론
새 교체 부품을 원래 부품과 비교하세요—설치하기 전에 남아있는 부품을 옮기거나 새 부품에서 접착 백킹을 제거해야 할 수 있습니다.
기기를 재조립하려면 이 지침을 역순으로 따르세요.
전자 폐기물을 R2 또는 e-Stewards 인증 재활용 센터로 가져가세요.
수리가 계획대로 진행되지 않았습니까? 자사의 Answers 커뮤니티에서 확인하세요.
다른 391명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en ko
62%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Jeff Suovanen
회원 가입일: 08/06/13
427,002 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 16,560개 작성하였습니다
댓글 51개
In the store it says the iSlack is only for iPhone 5 and 6. In this review the iSlack is used (without tray). Does that mean it can be used on the iPhone X as well?
Ronald van der Meer - 답글
@rvdm The little bracket in the middle of the iSclack is sized for iPhone 5, but that bracket is optional and very easy to detach. At that point you have a really great general-purpose suction tool that works for all kinds of devices (even bigger ones like tablets). I’ll see about updating the description on the store page to reflect that fact. ;)
Jeff Suovanen -
Have you all ever had a problem of the phone staying stuck on a percentage and takes so long to charge plz let me know because I just got my iPhone X and it take so long to charge and I got it brand new from AT&T
Cristan Montes - 답글
Esta solucionado el tema del Chip Texas instrument para baterias no reemplazadas en Apple, gracias.
FELIX MARQUEZ - 답글
¿A qué te refieres con eso?
Tomas -
C’è un errore di traduzione al passo 33 BATTERIA , iphone X diventa iphone 8.
Marco
Marco Pautasso - 답글
Ciao Marco! Hai occhi di lince! Grazie per il commento. Ho corretto la traduzione. Commenti di questo tipo sono sempre benvenuti. Hai anche la possibilità di adattare direttamente la traduzione, cliccando sull’icona “Traduci”. Saluti, Claire
Claire Miesch -
Note that my replacement battery was completely dead when I installed it, so when I tested it, I thought perhaps something wasn’t hooked up right. After removing the bracket for the connectors and reattaching the battery connector I tried again. Since that failed, I plugged the phone in. I got a “no charge” battery icon. After a few minutes I removed the phone from the charger. The phone stayed on with the “plug in the phone” icon, so I knew everything was put back together correctly.
Jon12 - 답글
Critical Note! When installing the new battery make sure the connector lines up. The instructions mention having the speaker and taptic engine in place so I focused on squaring up with those. This was a mistake! Now my connector is 2mm too low and won’t line up. Not sure how I will fix this yet but hopefully I won't need to remove everything again.
Christopher Jones - 답글
Where can I buy a genuine original iPhone X battery as amazon Walmart sells fake batteries
masrin - 답글
You can not buy a genuine battery.
Alexander -
How to make out a genuine original battery from a fake one sold all over the globe?
masrin - 답글
Super Set, auch toll das hier die Dichtung dabei ist. Akku lädt und zeit die %-Werte an. Beim nächsten Mal kauf Ichs gleich hier"! War jetzt schon die 2te Reparatur. Mittlerweile schaff ich das schon ca. 40 min ;)
Danke
Peter - 답글
Aparecerá el porcentaje de la batería en el apartado de “salud”?
Gustavo González Martínez - 답글
removing the components that are below the battery seems rather unnecessary to me, you could remove the battery without taking those out
Samuel Casas - 답글
I had an issue with a swollen battery on a iphone X, the battery was pushing the display assembly and the phone couldn’t close properly. Replaced with new battery and all went fine. Great guide as always
Georgi Ivanov - 답글
This battery already comes with battery health indicator or need to reprogram the battery ?
danial nabil - 답글
Big thank you for introduction!
commaai - 답글
It would be nice if this addressed the waterproof adhesive, mentioned in Step 6. Doesn’t pulling the phone apart make it no longer watertight?
Winston - 답글
Instructions for replacing the adhesive seals are linked in the guide (Step 19). I wouldn’t count on your phone being waterproof after a repair, but a phone from 2017-2018 likely won’t be particularly water-resistant anymore, anyway. Those seals tend to degrade over time.
Jeff Suovanen -
Hi, I bought the battery from you and installed it exactly like your steps.
But after two days of use, a message appears to me that this battery is not original and its percentage cannot be read !!!
What to do now ???
Fahad Mohammad Fahad - 답글
When changing the battery to a third party one, are there any notifications that appear such as “not a genuine battery” and does reprogramming the battery help prevent this.
Farjad Akram - 답글
BE WARNED! THE IPHONE’S OUTSIDE IS VERY, VERY SHARP! I escaped with 4 cuts on my fingers.
AemVR - 답글
I replaced two of these in one night. The first one worked great but the second’s OLED screen won’t come on. The phone is on because I can hear it charge when I plug it in, but for some reason the screen is dead.
Lucas - 답글
If you’re buying the battery from iFixit I strongly suggest getting the full kit and not the battery-only option so that you get the glue and the gasket. Great guide, thank you!
Grant - 답글
It is perfectly possible to do the replacement without removing anything other than the bracket and the battery connector.
This reduces the number of steps to about 10 and takes about 15 minutes.
Neil Roberts - 답글
Awesome guide! I finished it, and now I have a fully working X
Just one thing: the video and the instructions differ on step 20, making the rest unnecessary according to the video guide. On the other hand, it may facilitate taking the glue off, especially for newbies.
Ed Oliver - 답글
I don’t want to sound like “that guy,” but the cost of a battery replacement is only $69 at an Apple Store. This DIY solution, which can go t!ts up anywhere along the 43 steps, requires the purchase of parts that cost almost as much as just letting Apple do it. I love fixing/replacing/upgrading my hardware as much as the next guy, but this seems like a scenario where the majority of people would be better off visiting an Apple Store.
koelpien - 답글
Except that authorized stores won’t replace a swollen battery, and neither will Apple. Otherwise yes, if the few hours extra and a few 10s of dollars is the additional price for a turnkey solution, most folks are better off having the work done for them.
Mike Hocker -
Was suffering from a hugely swollen battery so it made removing the adhesive pretty difficult (and I was being super careful since the battery had swollen so much). The “stretch and pull” with the adhesive was a no-go and I was hesitant to heat the phone. I ended up slowly pulling up on the battery at the top and gently working the adhesive away. It took some time, but worked out.
Great guide, as usual!
Patrick C - 답글
Jeg har lige skiftet batteri på min iPhone X i starten kunne jeg kun oplade trådløst, men nu kan jeg slet ikke oplade Den reagerer slet ikke på noget mere den er helt død Hvad kan jeg gøre ???
enok - 답글
The adhesive under the original battery broke. ALL TABS RIPPED APART! I have no floss nor metal guitar string. Help please. This is my only mobile phone. I need it 24/7.
vmm - 답글
Commentary on swelled batteries: don’t tell Apple, they will mark your iPhone SerialNumber in their database as not repairable and you will never be able to get a battery replacement in the future (per Apple phone support, as we tried to get their swollen battery replaced by appointment). We are not happy campers, now I need to use up valuable time replacing the battery. At least replacing the battery is an option with the help of iFixit. (oh, and they won’t put in a new battery if I remove the old one either— although once the old one is removed the hardest part of the work is done)
Mike Hocker - 답글
Wasn’t too bad, except some of the screws that need to be removed are tiny and I found out that my eyes are not the best anymore ?.
jabuka - 답글
Many thanks for this great tutorial !! Just changed the battery of my 4 years old iPhone X, I’m very happy to have a fresh one inside !
Faabio - 답글
Hello,
I have an iPhone X Model number MQAF2LZ/A bought in Perú and once I started removing the display I noticed it doesn’t open like in the pictures or video here. There is a connector behind the ear piece that connects to the main board and I can’t open it. I see if I force it I will break this connector. Have somebody worked with this model? and recommend where to buy a replacement display? The one I bought is for model number MQAF2LL/A (USA). (the ribbon cables look different)
John W - 답글
Today I show you how to replace the battery of the Iphone X. We need one screwdriver, one suction cup, 1 iopener, 1 pair of tweezers, 1 plastic pry tool, and 1 spudger.  Remember to turn off the power. The replacement can cause the loss of water resistance. To replace the battery for iphone X, do the following steps. Step 1, use the screwdrive to remove the screws at the bottom. Use Iopener to soften the adhesive. Clip the suction cup onto the screen and use a pry tool to pry out the screen. Lift up the screen 90 degrees on the right. Take off the small screws holding the battery cable and the motherboard. Next, use the tweezers to lift up the metal bracket. Use a spudger to pry away the battery connector and 3 display connectors. Use tweezers to remove the battery stripe. Remove the old battery. Reverse the above steps to install the new battery.
Hội Nguyễn - 답글
This takes me like 2 mins no tools required and I reused the adhesives also so less waste . I dont pull anything or use tools bar a tri star….. Should be updated . Soak in alcohol slightly leave for 2 mins remove battery , dry and replace using old adhesive (which is perfect) no cleaning ….Digithaiz
Sam Barton - 답글
Jeez I dont mind even making you a guide for this as its mostly sit and wait for all of the 5 mins max this takes!
Sam Barton - 답글
Porcentaje de la Condición de la batería funcionará bien?
Inksane BēLCK - 답글
Misma pregunta.
Tomas -
Hallo,
ich habe mein iphone x display und batterie ausgetauscht, allerdings bekomme ich die fehlermeldung
Apple erfasst die Hardwarekennungen Ihres iPhones, um unsere Dienste zu identifizieren und zu aktivieren.
İch habe mein iphone x damals in der türkei gekauft und leider komme ich nach weiter woran kann das liegen ?
mst Ozyn - 답글
Excellent guide! Took about1,5 - 2 hours too including trying to remove all of that black sticky stuff! :) Should have bought some isopropanol... Aligning and fixing the new sealing was a bit tricky! Really had to think for a while which layer of plastic to remove first...
No problem removing the adhesive under the battery which never has worked on older iphones! pehww.... :)
Thomas Lundström - 답글
Worked great. Only putting the display adhesive on was difficult. I am thinking about fixing the broken display now, because it maked so much fun!
Mike Stanke - 답글
Personnellement je n’ai pas démonté les haut parleur et le bas de l’iPhone … j’ai directement chauffé à l’arrière et décollé la batterie …. Plus rapide et moins dangereux pour le reste
Dark Stig - 답글
I don't know if it's common knowledge, but I just flashed on what the first sign of my battery expanding was. I used an Otterbox Defender case on my iPhone X. 3-6 months before the battery made its expansion obvious, the volume buttons started not working well. I thought it was the Otterbox. But now that I've replaced the battery the volume buttons are working fine. Somehow the battery was distorting the physical interface between the phone buttons and the case buttons. By the time I noticed the battery inflating, it had pushed up the display screen away from its frame. Apparently the battery was getting rather dangerous for possible setting itself ablaze.
MrRoundel - 답글
0% Remaining cómo solucionar ??
Ernesto Salazar - 답글
I replaced my battery just fine but now my screen is wonky. I’m getting yellow and black lines and it’s not working properly. I reattached everything twice but still no luck. Any body have the same issues or a fix? My screen was perfect before changing out my battery.
Jeremy - 답글
This battery has to be reprogrammed to work with the health condition battery?
Tomas - 답글
Thanks so much - this is exactly what I needed :)
Molly Floyd - 답글
댓글 쓰기
조회 통계:
24 시간 전: 174
7일 전: 1,213
30일 전: 5,806
전체 시간: 776,165
