주요 콘텐츠로 건너뛰기
iPhone X 디스플레이 어셈블리 교체
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iPhone X 디스플레이 어셈블리 교체, Pentalobe/펜타로브 나사: 1 단계, 이미지 1/1
    • 시작하기 전에 iPhone 배터리를 25% 이하로 방전하세요. 충전된 리튬-이온 배터리에 실수로 구멍이 생기면 화재를 일으키거나 폭발할 수 있습니다.
    • 분해를 시작하기 전에 iPhone 전원을 꺼주세요.
    • iPhone 하단 가장자리에 위치한 6.9mm-길이 pentalobe/펜타로브 나사 두 개를 빼주세요.
    • 나사가 벗겨지거나 손상된 경우 나사를 교체하세요.
    • iPhone 디스플레이를 열게되면 방수 봉인이 손상됩니다. 이 단계를 수행하기 전에 교체용 봉인을 준비하거나 봉인 없이 iPhone을 재조립할 경우 액체에 노출되지 않도록 주의하세요.
    There are 6.81mm long screws!
    Daniel - 답글
    One of the pentalobe screws is stripped :( - suggestions for how to get it out?
    cgtyoder - 답글
    same situation here
    kaunomarcius - 답글
    Same issue for me too, how do I get the stripped screw out?
    patronics - 답글
    Update: I was able to get the “stripped” screw out using another Pentalobe-2 screwdriver bit from another company. It seems it wasn’t the screw, but the screw driver that was actually stripped. Hence why the other screwdriver kit I got came with 3 of this bit, I suppose.
    patronics - 답글
    I ended up going to a jewelry store, and they drilled down into the screw, with of course an incredibly tiny bit. That allowed me to insert the P2 driver, and I was able to unscrew it at that point. Good luck!
    cgtyoder - 답글
    Same issue with the stripping. The tip of the iFixit P2 head in my $70 kit just ground off on the first screw and that was that. Not much you can do.
    Kyle Harris - 답글
    yes correct the same happened to me, the screws were perfect shaped never been open and as soon as i used the P2 it stripped the screws, seems like the P2 is slightly smaller but Dremel kit with a very small drill bits and precise knife tool is the way to go.
    Dulce Vidal - 답글
    This step in automatically followed through, without any thought. Why remove these screws? Can anybody explain? The Screen is detachable all the same, with them well screwed in…
    Uri - 답글
    These screws attach to a plate that’s part of the screen half of the phone. If you succeed in detaching the screen without removing those, it would seem reasonable that you will have damaged that plate or its ability to keep the two halves together.
    Dan Long -
    @Dan Long is right
    Uri -
    Clean out the pentalobe screw heads first so the tool goes all the way in. A small sewing needle works well to loosen any build up and then press some putty/chewing gum into the screw head and pull away quickly for a final clean out.
    William Olstad - 답글
    The this kit should include screws because you’re going to strip them. Can’t even get past step one. Did anybody figure this out
    justin - 답글
    Never opened my phone ever, when I went to look at the first step.. I noticed one of my screws was stripped. I thought it was impossible, but I removed the non stripped one, then once I got to the stripped one.. I learned my assumptions were correct. I bought this one straight from the apple site years ago ahaha Any tips to remove the stripped screw?
    Clarence Williams - 답글
    William Olstad's tip about cleaning the screws with a needle and a bit of poster putty worked well for me. There was a lot of crud in there! The opening is shallow, so it's easy to see how the screwdriver wouldn't catch with even a bit of grit in the way, No problem getting the pentalobe screws out with the ifixit screwdriver.
    punkinann - 답글
    If all else fails, very carefully cut a slot across the head of the screw with a Dremel tool using a diamond bit that dentist will gladly give you - I ask my dentist for used bits; and chuck them in a drill bit chuck designed for Dremel. The slot allows you to use a tiny, straight blade screwdriver. You can reuse the screw or replace it with a new pentalobe screw.
    Dan Smith - 답글
  2. iPhone X 디스플레이 어셈블리 교체, 깨진 부분에 테이프 붙이기: 2 단계, 이미지 1/3 iPhone X 디스플레이 어셈블리 교체, 깨진 부분에 테이프 붙이기: 2 단계, 이미지 2/3 iPhone X 디스플레이 어셈블리 교체, 깨진 부분에 테이프 붙이기: 2 단계, 이미지 3/3
    • iPhone 스크린에 금이 갔다면 유리에 테이프를 붙여 수리하는 동안 추가 파손을 막고 신체적 상해를 방지하세요.
    • iPhone 스크린 전체가 덮일 때까지 투명 포장 테이프를 겹쳐 붙이세요.
    • 수리하는 동안 튀는 유리 파편으로 부터 눈을 보호하기 위해 보안경을 착용하세요.
    • 만약 다음 몇 과정에서 흡입 컵이 스크린에 잘 붙지 않으면, 강력 테이프(덕트 테이프 등)를 접어 손잡이 형태로 만들어 붙이고 들어 올리세요.
    • 다른 모든 방법이 실패하면 흡입 컵에 초강력 순간접착제를 붙일 수 있습니다.
  3. iPhone X 디스플레이 어셈블리 교체, Anti-Clamp/안티-클램프 지침: 3 단계, 이미지 1/3 iPhone X 디스플레이 어셈블리 교체, Anti-Clamp/안티-클램프 지침: 3 단계, 이미지 2/3 iPhone X 디스플레이 어셈블리 교체, Anti-Clamp/안티-클램프 지침: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Clamp
    $24.95
    구매
    • 다음 세 단계는 여는 절차를 더 쉽게 하기 위해 고안된 도구 안티-클램프에 대한 설명입니다. 안티-클램프를 사용하지 않는다면 세 단계를 건너뛰고 다른 방법을 사용하세요.
    • 안티-클램프 사용법에 대한 전체 지침은 이 안내서를 확인하세요.
    • 파란색 손잡이를 뒤로 당겨 안티-클램프의 팔을 잠금 해제하세요.
    • 팔을 휴대폰의 왼편 또는 오른편 가장자리 위로 밀어 주세요.
    • 흡입 컵을 휴대폰의 하단 가장자리에 배치하세요—전면에 하나, 후면에 하나.
    • 적절한 위치에 컵을 함께 꽉 쥐고 흡착하세요.
    • 휴대폰 표면이 너무 미끄러워 안티-클램프가 잘 고정되지 않으면 테이프를 사용하여 표면에 더 잘 고정되게 할 수 있습니다.
  4. iPhone X 디스플레이 어셈블리 교체: 4 단계, 이미지 1/3 iPhone X 디스플레이 어셈블리 교체: 4 단계, 이미지 2/3 iPhone X 디스플레이 어셈블리 교체: 4 단계, 이미지 3/3
    • 파란색 손잡이를 앞으로 당겨 팔을 고정하세요.
    • 손잡이를 시계 방향으로 360도 돌리거나 컵이 늘어나기 시작할 때까지 돌리세요.
    • 흡입 컵이 서로 정렬된 상태를 유지하는지 확인하세요. 정렬에서 벗어나기 시작하면 흡입 컵을 약간 풀고 팔을 다시 정렬하세요.
  5. iPhone X 디스플레이 어셈블리 교체: 5 단계, 이미지 1/3 iPhone X 디스플레이 어셈블리 교체: 5 단계, 이미지 2/3 iPhone X 디스플레이 어셈블리 교체: 5 단계, 이미지 3/3
    • iOpener를 가열하여 안티-클램프의 팔에 끼워 넣습니다.
    • 헤어 드라이어, 열선총 또는 핫 플레이트를 사용할 수도 있지만—과도한 열은 디스플레이 및/또는 내부 배터리를 손상할 수 있으므로 신중히 진행하세요.
    • iPhone 하단 가장자리에 놓이도록 iOpener를 접으세요.
    • 접착제가 풀려서 틈이 생길 때까지 1분 정도 기다리세요.
    • 스크린 자체가 아닌 스크린과 플라스틱 베젤 밑에 여는 픽을 끼우세요.
    • 안티-클램프가 충분한 틈을 만들지 못하면 열을 더 가하고 핸들을 1/4 바퀴 돌리세요.
    • 한 번에 1/4 바퀴 이상 돌리지 말고 매번 돌릴 때마다 1분 정도 기다리세요. 안티-클램프와 시간에 맡기세요.
    • 다음 세 단계는 건너뛰세요.
    DO NOT separate the glass from the plastic bumper or rim around it. These instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body. It is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - 답글
    Thanks for pointing this out! I'll revise this step to clarify this point.
    Arthur Shi -
  6. iPhone X 디스플레이 어셈블리 교체: 6 단계, 이미지 1/1
    • iPhone 하단 가장자리를 가열하면 디스플레이를 고정하고 있는 접착제가 부드러워져서 보다 쉽게 ​​열 수 있습니다.
    • 헤어 드라이어 또는 열선총, 혹은 iOpener를 준비하여 iPhone 하단 가장자리를 약 1분 동안 가열하면 접착제가 부드러워집니다.
    • 헤어 드라이어나 열선총을 사용하는 경우 스크린이 손상될 수 있으므로 너무 강하게 가열하지 마세요.
    General tip regarding heating necessary to remove adhesive:
    consider using a heated tip of a small screwdriver or metal spudger (not the one made of plastic, provided in kit), rather than to heat the device itself.
    Uri - 답글
    You then need to be careful about the temp of the tool which if hot enough can melt plastic components or harm them. Keeping the heat source (heat gun) far enough away from the object that you’ll eventually melt the glue but would be much harder to melt components. I try to keep 4” or 5” gap between the source & object
    Sandman619 -
    Thanks for the info. Could a air convector do the job
    dominique.br - 답글
    When opening a device that has previously been worked on, and on which the adhesive might not have been replaced, be extremely carful when opening the phone. It will open much more easily than expected. If you’re not careful you might rip a cable.
    jonpol - 답글
    Is this tool required or can I just use the Anti-Clamp by itself.
    Mikail - 답글
    If you have a 3d printer, heat the bed to 80c and put the phone screen side down on it for 30 secs
    philip.joseph123 - 답글
  7. iPhone X 디스플레이 어셈블리 교체: 7 단계, 이미지 1/2 iPhone X 디스플레이 어셈블리 교체: 7 단계, 이미지 2/2
    • 단일 흡입 핸들을 사용하는 경우 유리의 구부러진 부분을 피하면서 휴대폰 하단 가장자리에 사용하세요.
    If you were using some form of screen protector, it may come off first as soon as you pull on the suction cup. Do not be alarmed. That is normal behavior.
    Alain-Daniel Wa-Baguma - 답글
    3m VSB double stick tape will stick to the screen when the suction cups fail (see my comment on step 1)
    Tawan Khamapirad - 답글
  8. iPhone X 디스플레이 어셈블리 교체: 8 단계, 이미지 1/3 iPhone X 디스플레이 어셈블리 교체: 8 단계, 이미지 2/3 iPhone X 디스플레이 어셈블리 교체: 8 단계, 이미지 3/3
    • 흡입 컵을 확실하고 일정한 압력으로 위로 당겨 전면 패널과 후면 케이스 사이에 약간의 틈을 만드세요.
    • 스크린 자체가 아닌 스크린의 플라스틱 베젤 밑에 여는 픽을 끼우세요.
    • 디스플레이를 제자리에 고정하는 방수 접착제는 매우 강합니다; 이 초기 틈을 만들려면 상당한 힘이 들어갑니다. 틈을 여는데 어려움을 겪고 있다면 더 많은 열을 가하고 여는 도구를 넣을 수 있을 만큼 틈이 생길 때까지 스크린을 위아래로 부드럽게 들었다 놨다하여 접착제를 약하게 만들어주세요.
    In addition to safety goggles, I would recommend you also wear good gloves to avoid getting cut with the glass as you try to pry it open.
    The top about applying more heat and gently rocking the screen up and down to weaken the adhesive did the trick for me. Thank you!
    Monil Shah - 답글
    There needs to be more clarity on where to shove the opening pick into. There is actually two openings that the pry tool can be forced into: one below the black plastic bezel, and one above the black plastic bezel. When I heated my screen with a warming pad and pulled up the suction cup, it actually pried apart above the black plastic bezel which removed the touch screen from the display panel. With this being the first newer iPhone I'd opened since the 3GS, I didn't realize that I was opening the wrong opening as the directions only mentioned one opening and did not warn of this. I was pretty disappointed in the lack of mentioning this, as I was taking my time and following it to the tee. As a result, it destroyed my original iPhone screen.
    Caleb Davison - 답글
    DO NOT separate the glass from the plastic bumper or rim around it. As someone else noted, these instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body of the phone. When pulling upwards with the suction cup, it is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - 답글
    Thank you for pointing this out! I've updated the step to reflect this.
    Arthur Shi -
    The suction cup doesn't work at all... The minimum force I apply to lift it up, it comes off completely. This is very frustrating!!!
    Mario Silva - 답글
  9. iPhone X 디스플레이 어셈블리 교체: 9 단계, 이미지 1/3 iPhone X 디스플레이 어셈블리 교체: 9 단계, 이미지 2/3 iPhone X 디스플레이 어셈블리 교체: 9 단계, 이미지 3/3
    • Opening pick/여는 픽을 iPhone 하단 왼쪽 모서리부터 왼쪽 가장자리를 따라 위로 밀어서 디스플레이를 제자리에 고정하는 접착제를 잘라주세요.
    • 여는 픽을 3mm 이상 끼우지 마세요. 내부 부품을 손상할 수 있습니다.
  10. iPhone X 디스플레이 어셈블리 교체, 스크린 정보: 10 단계, 이미지 1/1
    • iPhone 오른편 가장자리를 따라서 민감한 케이블이 지나갑니다. 케이블을 손상할 수 있으므로 이곳에 픽을 끼우지 마세요.
    Wouldn’t it be better to put this part BEFORE the step where you have to pry open the phone?
    Jan D. Höllwarth - 답글
  11. iPhone X 디스플레이 어셈블리 교체: 11 단계, 이미지 1/3 iPhone X 디스플레이 어셈블리 교체: 11 단계, 이미지 2/3 iPhone X 디스플레이 어셈블리 교체: 11 단계, 이미지 3/3
    • iPhone의 하단 가장자리에 픽을 다시 넣고 오른쪽 가장자리를 따라 위로 밀어서 접착제를 계속 분리하세요.
    • 디스플레이 케이블을 손상할 수 있으므로 픽을 3mm 이상 끼우지 마세요.
    If you have flat feeler gauges (for adjusting engine valve tappet clearance, ignition points … old school) the .003” thick gauge goes right in. Work your way up in thickness until you can get the pic or supplied pry tool in. Don’t insert metal feeler gauge in too far, just enough to hold crack open. I didn’t need to use the suction cup. I used a hot/cold gel pack heated in microwave to heat edges to soften glue a bit. Made sure it wasn’t so hot I couldn’t stand it on my skin.
    William Olstad - 답글
  12. iPhone X 디스플레이 어셈블리 교체: 12 단계, 이미지 1/3 iPhone X 디스플레이 어셈블리 교체: 12 단계, 이미지 2/3 iPhone X 디스플레이 어셈블리 교체: 12 단계, 이미지 3/3
    • 디스플레이의 상단 가장자리는 접착제와 클립으로 고정되어 있습니다.
    • Lightning 포트 방향으로 디스플레이를 조심히 당기거나 흔들면서 여는 픽으로 디스플레이 상단 모서리 주위를 밀어주세요.
    • 너무 세게 힘을 가하면 클립은 부서집니다. 인내심을 가지고 신중하게 작업하세요.
    • 전면 패널 센서 어레이가 손상될 수 있으므로 픽을 3mm 이상 끼우지 마세요.
    • 픽을 반대쪽 모서리로 밀고 디스플레이를 고정하는 나머지 접착제를 자르세요.
    These are the best instructions I’ve ever read for anything.! Thank you!
    Peter Andrew - 답글
  13. iPhone X 디스플레이 어셈블리 교체: 13 단계, 이미지 1/1
    • 흡입 컵의 작은 손잡이를 당겨 전면 패널에서 분리하세요.
  14. iPhone X 디스플레이 어셈블리 교체: 14 단계, 이미지 1/3 iPhone X 디스플레이 어셈블리 교체: 14 단계, 이미지 2/3 iPhone X 디스플레이 어셈블리 교체: 14 단계, 이미지 3/3
    • 책의 뒷 표지처럼 디스플레이를 왼편을 위로 펼쳐서 iPhone을 열어주십시오.
    • 아직 디스플레이를 완전히 분리하지 마십시오. 여전히 약한 리본 케이블 여럿이 iPhone 로직 보드에 연결되어 있습니다.
    • 사진 처럼 프레임이 디스플레이와 함께 분리되고 기기에 끼지 않도록 확인하세요.
    • 휴대폰에 작업하는 동안 디스플레이를 다른 물건에 기대어 세워 놓으십시오.
    • 재조립하는 동안 디스플레이를 제자리에 놓고 상단 가장자리를 따라 클립을 정렬한 다음 상단 가장자리를 조심스럽게 눌러 제자리에 고정시킵니다. 제대로 들어맞지 않으면 디스플레이 주변의 클립 상태를 점검하고 구부러지지 않았는지 확인하세요.
    My phone came apart in a different way and looks not right the little box at the top of the display as actually bolted to the top of the frame body I think something went really wrong when I opened it.
    Mike Kostersitz - 답글
    It opens like a book but be careful not to open it all the way — only as far as shown in the photo. Otherwise it will strain the thin cable that connects the sensor module and then no more FaceID for you (or, as it turns out me). This could have been made more explicit in the instructions.
    Richard Tucker - 답글
    It opens like a book but be careful not to open it all the way  … the small stainless steel tabs that hold the screen around the metal frame, that are on the bend place (right side of the phone)… are tend to bend, you can straighten them back to 90 deg. but the plastic base that they are on? very fragile- watch out not to break the plastic bezel … it may come apart of the glass.
    dabur872 - 답글
    Advice for re-assembly: Before closing up the phone with the seal, check if phone is powering up again and speaker, mic and sensors are still working. If done this check even before installing the board connector bracket in Step 13.
    Alexander Nowak - 답글
  15. iPhone X 디스플레이 어셈블리 교체, 디스플레이 어셈블리: 15 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • 로직 보드 커넥터 브래킷을 고정하는 Y000 나사 다섯 개를 풀어주세요:
    • 1.1mm 나사 세 개
    • 3.1mm 나사 한 개
    • 3.7mm 나사 한 개
    • iPhone 손상을 피하기 위하여 수리하는 내내 빼놓은 각각의 나사를 기억하여 원래 자리로 정확히 돌려놓으세요.
    One thing I found helpful for replacing the screws was to use only the 000screwdriver tip, without the handle. This way, the tip isn’t magnetized and the screw doesn’t tend to ‘roll’ off the screwdriver tip (the screw has almost no mass, so the head (largest surface) is pulled around to the side of the screwdriver tip when magnetized).
    Rich May 23, 2020
    ungodly - 답글
    My 3.1mm screw had a stripped head, could not remove it. (Factory defect, this iPhone was never opened)
    So I had to give up removing the display assembly, and jumped directly to battery replacement, Step 20.
    That was tricky as I had to keep the display at 90º with a risk of breaking display connectors, but hopefully the replacement went well.
    I would not recommend to do this but to follow the guide, but, in case someone encounters a similar issue, that could help!
    vingu - 답글
    My 1.1mm screw had a stripped head. Used a 3mm steel drill to cut the head off (just 1 mm deep haha) so i could remove the bracket.
    Renout - 답글
    Be careful on reassembly. Keep the screen supported and not moving. I had difficulty getting the screws in and ended up ruining the screen connectivity at the back of the screen where the ribbon cables go in near the center. I was trying to hand hold the screen and it ended up moving around too much.
    SETH GREEN - 답글
    To keep track of the screws, I copy the photos showing their places, then arrange these photos on document in Pages, print it. Next I apply two sided sticky tape (the roll-on type). So all screws have their corresponding places …
    Max Glanzmann - 답글
  16. iPhone X 디스플레이 어셈블리 교체: 16 단계, 이미지 1/1
    • 브래킷을 분리하세요.
    • 브래킷이 가볍게 부착되어 있을 수 있습니다. 조심히 하지만 확실하게 들어 올려 분리하세요.
    • 재조립 할 때는 디스플레이를 제자리에 봉하기전에 iPhone 전원을 켜고 모든 기능을 테스트하는 것이 좋습니다. 작업을 계속하기 전에 iPhone 전원을 완전히 끄는 것을 잊지마세요.
    I tested it, then proceeded to close up the device without the bracket. Do I need to reopen and install? All connections are good?
    monastra7 - 답글
    The bracket helps those many connectors underneath maintain good contact. Probably in the short term nothing bad will happen, but I’d hang onto the bracket and reinstall it when convenient.
    Jeff Suovanen -
    Agree with Jeff
    cgtyoder -
    I tested all imaginable functionality on the new OLED screen. Taptics are fine. Then, I noticed that the battery wasn't charging. Any ideas as to what could have gone wrong?
    Monica - 답글
    for me, the replacement battery was completely dead, small panic when the power-on button was pressed, but quickly realised that this was the situation, and now watching the phone take a power cycle.
    James Stanbridge - 답글
    Before clicking the screen assembly back, I tried to test the iPhone by pushing the start button, but nothing happened. After taking off the bracket, reseating the plugs I tried again - nothing happened! Then I plugged in the charging cable connected with the iMac, and it started immediately. So if the phone does not start using the startup button, it might just be a glitch when reconnecting the battery.
    Max Glanzmann - 답글
  17. iPhone X 디스플레이 어셈블리 교체: 17 단계, 이미지 1/2 iPhone X 디스플레이 어셈블리 교체: 17 단계, 이미지 2/2
    • Spudger/스퍼저 또는 깨끗한 손톱으로 배터리 커넥터를 로직 보드의 커넥터 소켓에서 들어올리세요.
    • 이 보드 및 다른 보드 연결 부분을 둘러싼 검정색 실리콘 씰을 손상시키지 마세요. 이 씰은 물과 먼지의 침입을 추가 방지합니다.
    • 수리 중에 실수로 소켓에 닿아 휴대폰에 전원이 공급되지 않도록 커넥터를 로직 보드에서 바깥쪽으로 약간 구부려 주세요.
    cosa può succedere se non si disconnette la scheda logica'?
    luca.valli - 답글
    note: be careful not to crush or puncture your battery at this step!! I gave mine a minor dent, which I hope wont be a problem.. but something to keep in mind for fxlks in the future!
    Noal Balint - 답글
    Thanks, already did it)
    Stephen Hedrick -
  18. iPhone X 디스플레이 어셈블리 교체: 18 단계, 이미지 1/2 iPhone X 디스플레이 어셈블리 교체: 18 단계, 이미지 2/2
    • Spudger/스퍼저 또는 손톱으로 전면 패널 센서 어셈블리 커넥터를 분리하세요.
  19. iPhone X 디스플레이 어셈블리 교체: 19 단계, 이미지 1/2 iPhone X 디스플레이 어셈블리 교체: 19 단계, 이미지 2/2
    • Spudger/스퍼저 또는 손톱을 사용하여 OLED 패널 케이블 커넥터를 분리하세요.
    • 이와 같은 프레스 커넥터를 다시-붙이려면 조심스럽게 정렬하여 한쪽을 제대로 들어맞을 때까지 아래로 누른 다음 다른 쪽도 반복하세요. 가운데 부분은 누르지 마세요. 커넥터가 잘못 정렬되어 있을 경우 핀이 구부러져 영구적인 손상을 입을 수 있습니다.
    Snap ‘em in like little Legos.
    Ray Johnson - 답글
    Maybe the manual should flip step 17 and 18 (as the digitizer cable from 18, is in the way of the OLED cable of step 17) ?
    Renout - 답글
  20. iPhone X 디스플레이 어셈블리 교체: 20 단계, 이미지 1/2 iPhone X 디스플레이 어셈블리 교체: 20 단계, 이미지 2/2
    • Spudger/스퍼저를 사용하여 소켓에서 디지타이저 케이블 커넥터를 들어 올려 분리하세요.
    • 이 커넥터의 오목한 위치는 재연결을 까다롭게 합니다. 천천히 정렬한 다음 손가락 끝으로 조심스럽게 눌러주세요—한쪽 끝을 먼저 누른 다음 다른 쪽 끝을. 딸깍하는 느낌으로 제자리에 고정됩니다.
    • 수리를 마친 후 스크린에 터치 반응이 없는 부분이 생긴 경우 배터리를 분리한 다음 이 커넥터를 다시 제대로 들어맞게 장착하고 소켓에 먼지 또는 기타 장애물이 없음을 확인하세요.
    This was probably the hardest part other than trying to get the screen off with the crappy suction cups. I re-installed the bracket only the find out that the touch screen would not respond to touch. Had to remove the five screws, remove the bracket and reseat the recessed screen connector. Reseating the bracket took another 10+ minutes. I carefully used the angled forceps to grab the cable and align the connector being careful not to damage the cable.
    Once you have the connector seated, I would reconnect the battery, power on the phone, and check the touch screen response before re-installing the bracket (step 13).
    Yeah, this was probably the trickiest part of the reassembly. The power connector cable kept getting in the way so I moved it carefully but fully out of the way. Then it was a matter of fiddling around with it a bit and being careful not to force it on.
    Jeffrey Hoy -
    I was positive that I had messed something up, I had powered up the phone to test three different times and everything seemed find except there was no touch at all. On my fourth attempt, I carefully examined everything for dust and debris (blowing gently), and I did notice that a corner of the connector (more like part of the ribbon) was bent slightly, and I straightened it. I don't know if it was the ribbon or some tiny debris, but after reseating a fourth time, it worked.
    Pol Llovet - 답글
    Very important part of the tutorial. Be careful and patience! In my case the screen and camera didn't respond after assemble, so I tried again to reconnect the connector like tutorial said and it worked well. Now my iPhone feel like a new one 💪🏼
    Efrain Maestre - 답글
  21. iPhone X 디스플레이 어셈블리 교체: 21 단계, 이미지 1/3 iPhone X 디스플레이 어셈블리 교체: 21 단계, 이미지 2/3 iPhone X 디스플레이 어셈블리 교체: 21 단계, 이미지 3/3
    • 전면 패널 센서 어셈블리 플렉스 케이블이 제 위치에 살짝 붙어있습니다.
    • 접착제가 분리될 때까지 케이블을 조심히 들어올리세요.
    Do this sensor affect face id?
    bonglkv - 답글
    It is part of the face id part so yes. This is the ear piece too so if the ribbon tears there is a chance the ear piece will stop working as well.
    Stephen Patterson - 답글
    Be super careful handling this ribbon particularly. I did a battery install and, when I was done, I had a phone with a new battery and no Face ID. That’s a $300 Apple repair, and no 3rd party shop will touch it. I believe the ribbon lays vertically (i.e., perpendicular to the “floor” of the phone, against the side edge of the battery. During the re-install, I must have forced the ribbon into position after seating the connector, causing fatal flexing of the ribbon. (Don’t know this for sure, but I see another comment saying that this cable is part of Face ID.) Anyway, bottom line: BE CAREFUL REMOVING AND REINSTALLING THIS RIBBON!
    Jonathan Pines - 답글
    My flex cable was more than lightly adhered in place. I needed to use a guitar pic or similar to help encourage adhesive to separate. I wouldn’t pull too hard like shown in pictures unless you had just the right grip on the ribbon cable so as to avoid damaging flex cable. See note above (5/31/20)
    William Olstad - 답글
    Bizarre — it turns out my whole front panel sensor assembly came entire off of the front screen and is stuck to the logic board.
    Karl Jarvis - 답글
    I also found the glue quite recluctant to release so I applied a second or two of heat using the wife's hair dryer which softened it and the cable lifted much easier then. Be careful not to apply too much heat though which could then impact other internal components.
    LosBenitos - 답글
    Cho ít cồn 90° vào để mềm keo dễ tháo
    huuhaukimngan - 답글
    my iphone x doesn't have a front panel sensor? in fact, it looks completely different than the picture???
    Kenneth McLeod - 답글
    @kennethmcleod, most likely you've separated the screen frame from the screen itself. We see this most commonly when people neglect to remove the pentalobe screws next to the charging port. Usually the cure is to take out those screws, then repeat the screen removal process on the frame that's still attached to the phone.
    Jerry Wheeler -
    You don't need to disconnect the front sensor to change the screen. Just leave it connected and remove from the screen side.
    Anthony Boshell - 답글
  22. iPhone X 디스플레이 어셈블리 교체: 22 단계, 이미지 1/1
    I tried this and broke the cable can it still repair
    Alexis Rodriguez - 답글
    At this point I would have found it easier to remove the glue from the edges than later on when I was reassembling it. I bought the kit that had the replacement glue in it.
    Grant - 답글
    Excellent guide! Would love to have a link to moving the sensor assembly from the old display to the new here.
    Nicole - 답글
    CAUTION:
    Removing the Taptic Engine or Speaker in next step is optional and the guide continues as this was per se needed.
    Unnecessary work and also If you remove the speaker you lose the adhesive gasket and this is not included in the scope of delivery of the "Battery replacement" offering.
    So do not remove and avoid losing waterproofing.
    Julian Gonzalez - 답글
결론
기기를 재조립하려면 이 지침을 역순으로 따르세요.
다른 13명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en ko
100%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Jeff Suovanen
회원 가입일: 08/06/13
427,853 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,732개 작성하였습니다
댓글 한 개
Meh, i had to Replace the sensors and camera unit thingy too, but i managed it without advice, the iPhone X is nicer to repair as any other iPhone.
Thanks for the detailed step by step description. :)
(the iphone 8 teardown for example lacks extremely much Details)
GotWaffles ? - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 11,938
