주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone X Disassembly
필요한 것
동영상 개요
  1. iPhone X Disassembly, Turn off the phone and remove SIM Card: 1 단계, 이미지 2개 중 1개 iPhone X Disassembly, Turn off the phone and remove SIM Card: 1 단계, 이미지 2개 중 2개
    • Press the wake button and volume down button to turn off the phone.
  2. iPhone X Disassembly, Open the phone: 2 단계, 이미지 3개 중 1개 iPhone X Disassembly, Open the phone: 2 단계, 이미지 3개 중 2개 iPhone X Disassembly, Open the phone: 2 단계, 이미지 3개 중 3개
    • Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will allow the phone to be opened more easily.
  3. iPhone X Disassembly, Remove the iPhone X OLED screen: 3 단계, 이미지 3개 중 1개 iPhone X Disassembly, Remove the iPhone X OLED screen: 3 단계, 이미지 3개 중 2개 iPhone X Disassembly, Remove the iPhone X OLED screen: 3 단계, 이미지 3개 중 3개
    • Undo 5 screws shown in the picture below with a tripoint #Y000 screwdriver
    • These screws are all different sized so keep track of where they go
    • Release the battery/LCD screen/digitizer/ear speaker connectors with a spudger.
  4. iPhone X Disassembly, Remove the ear speaker: 4 단계, 이미지 2개 중 1개 iPhone X Disassembly, Remove the ear speaker: 4 단계, 이미지 2개 중 2개
    • Undo 3 Y000 screws and heating the flex cable with a heat gun, we can remove the ear speaker easily
  5. iPhone X Disassembly, Remove rear-facing cameras.: 5 단계, 이미지 1개 중 1개
    • Remove the 2 Phillips #PH00 screws and remove the metal plate, release the rear cameras connectors.
    • These screws are also different sizes
  6. iPhone X Disassembly, Remove motherboard.: 6 단계, 이미지 2개 중 1개 iPhone X Disassembly, Remove motherboard.: 6 단계, 이미지 2개 중 2개
    • Release all connectors on the motherboard with a spudger
    • Undo 3 Phillips #PH00 screws on the mother board then we can take out the mother board.
  7. iPhone X Disassembly, Remove Loudspeaker and Taptic engine: 7 단계, 이미지 3개 중 1개 iPhone X Disassembly, Remove Loudspeaker and Taptic engine: 7 단계, 이미지 3개 중 2개 iPhone X Disassembly, Remove Loudspeaker and Taptic engine: 7 단계, 이미지 3개 중 3개
    • Undo 8 screws on the retaining plate then remove the plate taking care to not break the small connector on the plate that connects just under the taptic engine
    • Remove the loud speaker and the taptic engine.
  8. iPhone X Disassembly, Remove battery: 8 단계, 이미지 2개 중 1개 iPhone X Disassembly, Remove battery: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Pulling out 4 battery adhesives with a tweezers then we can remove the battery.
  9. iPhone X Disassembly, Remove front-facing camera: 9 단계, 이미지 2개 중 1개 iPhone X Disassembly, Remove front-facing camera: 9 단계, 이미지 2개 중 2개
    • Heating the front facing camera with a heat gun will make it easily to be removed
  10. iPhone X Disassembly, Remove the charging port and antenna: 10 단계, 이미지 3개 중 1개 iPhone X Disassembly, Remove the charging port and antenna: 10 단계, 이미지 3개 중 2개 iPhone X Disassembly, Remove the charging port and antenna: 10 단계, 이미지 3개 중 3개
    • Release 4 screws on the frame shown in the picture
    • Heating the charging port flex cable then we can remove it easily
  11. iPhone X Disassembly, Remove Wi-Fi antenna: 11 단계, 이미지 3개 중 1개 iPhone X Disassembly, Remove Wi-Fi antenna: 11 단계, 이미지 3개 중 2개 iPhone X Disassembly, Remove Wi-Fi antenna: 11 단계, 이미지 3개 중 3개
    • Release 7 screws on the Wi-Fi flex cable
    • Heating the flex cable with a heat gun make it easier to be removed
  12. iPhone X Disassembly, Remove power button flex cable: 12 단계, 이미지 3개 중 1개 iPhone X Disassembly, Remove power button flex cable: 12 단계, 이미지 3개 중 2개 iPhone X Disassembly, Remove power button flex cable: 12 단계, 이미지 3개 중 3개
    • Release 3 screws on the power button
    • Heating the flex cable with a heat gun then it can be removed easily
결론
다른 134명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Mandy
회원 가입일: 12/05/14
9,612 평판
안내서 9개를 작성함
26가이드 댓글
It's good
Chalak Chomani - 답글 공유
excellent guide!!!
Andy Lee - 답글 공유
The iPhone X assemble video: https://youtu.be/E5jyuxgpE_g
Mandy - 답글 공유
What About the backside ? I heard that when the backside is shattered, it’s almost impossible to repair, because of the glue that holds the backside and parts together ?
Arnoud - 답글 공유
Hi avdk, we don’t tear down the back glass but we will pay attention to this question. If there is a definite answer, I will reply to you .Thank you.
Mandy - 공유
댓글 쓰기
조회 통계:
지난 24시간: 22
지난 7일: 138
지난 30일: 582
전체 시간: 232,534
