소개
Prereq-only for detaching the display assembly.
필요한 것
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Remove three 1.2 mm Y000 screws securing the battery connector cover bracket.
Remove the bracket.
Use the point of a spudger to pry the battery connector straight up out of its socket.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Remove the two 1.2 mm Y000 screws securing the display connector bracket.
Remove the bracket.
Use the tip of a spudger to pry up and disconnect the digitizer cable.
Use the tip of a spudger to disconnect the display cable connector.
Remove the five screws securing the logic board connector bracket to the rear case:
One 1.3 mm Phillips screw
One 1.5 mm Phillips screw
Three 1.2 mm Y000 screws
Remove the bracket.
Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
다른 2명이 해당 안내서를 완성하였습니다.
