주요 콘텐츠로 건너뛰기
iPhone XS Max Back Glass Replacement
필요한 것
동영상 개요
  1. iPhone XS Max Back Glass Replacement, Back Glass Separating Without Phone Disassembling: 1 단계, 이미지 1/1
    • Here we have an iPhone XS Max with broken back glass. Run function test first. All going well. Test wireless charging - nothing goes wrong.
  2. iPhone XS Max Back Glass Replacement: 2 단계, 이미지 1/1
    • Next, let’s scan the back glass with the Laser Machine.
    • Turn the phone off and place it upside down under the focus positioning probe. Press the ‘auto focus’ button on the panel.
    • With the focus length indicator on, place the phone upside down on the operating panel.
  3. iPhone XS Max Back Glass Replacement: 3 단계, 이미지 1/1
    • Run the matching program. Choose corresponding model and drawing. Get all parameters set.
    • Click ‘Red Light’ to turn on laser aiming function. Click ‘Mark’ to scan the back glass with the laser light.
    • Note: there will be smog when the laser light is scanning. So we need to switch on the Air Purifier.
  4. iPhone XS Max Back Glass Replacement: 4 단계, 이미지 1/1
    • Once finished, the back glass becomes transparent.
    • Again, let’s turn on the phone and run function test. All going well. Wireless charging also goes well.
  5. iPhone XS Max Back Glass Replacement: 5 단계, 이미지 1/1
    • Next, let’s separate the back glass from the mid-frame. The scanned back glass can be separated easily.
    • Insert the metal pry piece into the gap between the back glass and the mid-frame. Slide back and forth to separate the back glass from the mid-frame.
  6. iPhone XS Max Back Glass Replacement: 6 단계, 이미지 1/1
    • Once the back glass has been separated completely, scan with the laser light to remove residual glue on the mid-frame.
  7. iPhone XS Max Back Glass Replacement: 7 단계, 이미지 1/1
    • Once done, clean the mid-frame thoroughly.
    • Apply some B7000 glue to the mid-frame. Get the new big hole back glass in position and adhere with proper force.
    • Once done, clip the four sides of the phone with clamps and wait several minutes for the glue to dry out.
결승점
다른 14명이 해당 안내서를 완성하였습니다.
Phryne
회원 가입일: 11/17/19
19,058 평판
안내서 18개 작성하였습니다
11 댓글
Yeah, like I have a laser machine.
Gregg Stanley - 답글
Thanks for the turorial. Like a laser machine can be found hanging around like a regular tool.
Franklin - 답글
The actual !&&*? Is this a joke? TF is this doing here? Is that machine include with every iPhone?
Admer Bits - 답글
This is the reason, why there is a note at the very top of this tutorial: This guide is meant for repair professionals.
There is a german saying: “Who can read has a huge benefit.” Just kidding … ;-)
BenZ78 - 답글
i want to buy iphone xs max back panel (back glass)
SADAM TURK - 답글
댓글 쓰기
조회 통계:
24 시간 전: 55
7일 전: 279
30일 전: 1,287
전체 시간: 73,592
