주요 콘텐츠로 건너뛰기
iPhone XS Max SIM Card Replacement
필요한 것
  1. iPhone XS Max SIM Card Replacement, SIM Card: 1 단계, 이미지 1/3 iPhone XS Max SIM Card Replacement, SIM Card: 1 단계, 이미지 2/3 iPhone XS Max SIM Card Replacement, SIM Card: 1 단계, 이미지 3/3
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located near the side button on the edge of the iPhone.
    • Press firmly to eject the tray.
  2. iPhone XS Max SIM Card Replacement: 2 단계, 이미지 1/2 iPhone XS Max SIM Card Replacement: 2 단계, 이미지 2/2
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
427,783 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,718개 작성하였습니다
댓글 2개
Oh. That’s how you do. I took the display out to reach the sim. Would have been sooooo much easier like this hack using this ingenious tool.
L' Barouf - 답글
L’Barouf,
This guide isn’t a hack. This guide is the way the removal and insertion of a SIM card, in the iPhone XS Max, was designed to be.
What you did, while being the more delicate and providing you with more knowledge of the inner layout of your iPhone, was actually the hack.
Leo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 40
30일 전: 207
전체 시간: 19,038
