주요 콘텐츠로 건너뛰기
iPod 1st Generation Rear Panel Replacement
필요한 것
  1. iPod 1st Generation Rear Panel Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod 1st Generation Rear Panel Replacement: 2 단계, 이미지 1/1
    • Opening the iPod can be challenging; don't get discouraged if it takes you a few tries to get the iPod to open.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
  3. iPod 1st Generation Rear Panel Replacement: 3 단계, 이미지 1/1
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
  4. iPod 1st Generation Rear Panel Replacement: 4 단계, 이미지 1/1
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
  5. iPod 1st Generation Rear Panel Replacement: 5 단계, 이미지 1/1
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
    • Lift the rear panel away from the iPod.
결론
다른 3명이 해당 안내서를 완성하였습니다.
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 22
전체 시간: 8,528
