주요 콘텐츠로 건너뛰기
iPod 1st Generation Scroll Wheel Replacement
필요한 것
  1. iPod 1st Generation Scroll Wheel Replacement, Turn on the Hold switch: 1 단계, 이미지 1개 중 1개
    • Before beginning, be sure to activate the iPod's Hold switch to prevent the device from accidentally turning on.
  2. iPod 1st Generation Scroll Wheel Replacement, Cut a Strip of Tape: 2 단계, 이미지 1개 중 1개
    • Cut a strip of tape, preferably duct tape, about 6-8 inches long. Make sure it's wide enough to be able to cover the entire surface area of the Scroll Wheel
    • It is possible to use other types of tapes, like packing tape or stitched Scotch tape side-by-side, although it may take a few extra attempts in later steps.
  3. iPod 1st Generation Scroll Wheel Replacement, Prepping the iPod: 3 단계, 이미지 3개 중 1개 iPod 1st Generation Scroll Wheel Replacement, Prepping the iPod: 3 단계, 이미지 3개 중 2개 iPod 1st Generation Scroll Wheel Replacement, Prepping the iPod: 3 단계, 이미지 3개 중 3개
    • Lay the iPod flat on a solid table, then lay the strip of tape flat onto the Scroll Wheel, then press down on the entire surface of the Scroll Wheel & center Select button.
    • With one hand firmly grasping the iPod, pull the strip of tape upwards with your other to remove the Scroll Wheel from it's housing.
    • Be sure beforehand to slowly peel the tape off of the other buttons to prevent them from being pulled off as well, notably the Play/Pause button & the Menu button
  4. iPod 1st Generation Scroll Wheel Replacement, Remove Wheel parts from tape: 5 단계, 이미지 3개 중 1개 iPod 1st Generation Scroll Wheel Replacement, Remove Wheel parts from tape: 5 단계, 이미지 3개 중 2개 iPod 1st Generation Scroll Wheel Replacement, Remove Wheel parts from tape: 5 단계, 이미지 3개 중 3개
    • Simply peel off the Scroll Wheel & it's Select button from the strip of tape
  5. iPod 1st Generation Scroll Wheel Replacement, Done: 6 단계, 이미지 1개 중 1개
    • Congratulations! You've successfully removed the Scroll Wheel from your iPod 1st Gen.
결론
To reassemble your device, put the main Scroll Wheel mechanism back in first, followed by the center Select button.
작성자
1다른 기여자 명과 함께
nbmusic
회원 가입일: 09/30/21
133 평판
안내서 1개를 작성함
2가이드 댓글
Very brutal and very effective.
张兴潼 - 답글
Made me laugh of how rudimental it is but how effective it is, is like making a depilation to the iPod
Foxy the dj - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 40
전체 시간: 647
