주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
The plastic front half of your iPod case.
  1. Before opening your iPod, ensure that the hold switch is in the locked position.
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
    • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
  3. Continue to run the opening tool along the side of the case until all five tabs have been released.
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
  4. Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
  5. Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
  6. Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
    • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
  7. Peel up the metallic tape attached to the top of the battery.
    • Peel up the metallic tape attached to the top of the battery.
  8. Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
    • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
  9. Carefully disconnect the orange ribbon cable from the hard drive.
    • Carefully disconnect the orange ribbon cable from the hard drive.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
    • Lift the hard drive out of the iPod.
  10. For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
    • For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
    • Loosen the connector by pulling the brown locking bar toward the hard drive cable using the tips of your fingers.
  11. Slide the hard drive cable out of its connector.
    • Slide the hard drive cable out of its connector.
  12. Lift the blue hard drive mounting bracket out of the iPod.
    • Lift the blue hard drive mounting bracket out of the iPod.
  13. Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
    • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
  14. Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
    • Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
    • Loosen the touch wheel connector by pulling the brown locking bar toward the side of the iPod using the tips of your fingers.
  15. Reove the 8 T6 Torx screws from the logic board.
    • Reove the 8 T6 Torx screws from the logic board.
  16. Lift the logic board up enough to disconnect the orange touch wheel cable.
    • Lift the logic board up enough to disconnect the orange touch wheel cable.
    • Lift the logic board out of the iPod.
  17. Lift the touch wheel out of the front panel
    • Lift the touch wheel out of the front panel
  18. Front panel remains.
    • Front panel remains.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
iRobot
회원 가입일: 2009년 09월 24일
1 평판
안내서 648개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 3,578
