이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Replace a cracked or faulty display.
필요한 것
Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
After all five tabs along the right side are free, the case should open easily.
Lift up the hard drive with one hand and carefully disconnect the hard drive ribbon from the logic board.
Lift the hard drive out of the iPod.
Use a spudger to carefully disconnect the orange display ribbon from the front panel.
다른 8명이 해당 안내서를 완성하였습니다.
