주요 콘텐츠로 건너뛰기
iPod 4th Generation or Photo Headphone Jack Bracket Replacement
필요한 것
  1. iPod 4th Generation or Photo Headphone Jack Bracket Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
  2. iPod 4th Generation or Photo Headphone Jack Bracket Replacement: 2 단계, 이미지 1/3 iPod 4th Generation or Photo Headphone Jack Bracket Replacement: 2 단계, 이미지 2/3 iPod 4th Generation or Photo Headphone Jack Bracket Replacement: 2 단계, 이미지 3/3
    • Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
    • You may need to rock the pick back and forth to slide it in farther.
    • Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
    • Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
    • After all five tabs along the right side are free, the case should easily open.
  3. iPod 4th Generation or Photo Headphone Jack Bracket Replacement: 3 단계, 이미지 1/1
    • The iPod case is now open, but don't separate the two halves just yet. There is still an orange ribbon cable connecting the headphone jack to the logic board.
    • Open the case like a book with the dock connector edge at the top, and lay the rear panel next to the front half of the iPod.
  4. iPod 4th Generation or Photo Headphone Jack Bracket Replacement: 4 단계, 이미지 1/1
    • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
    • This ribbon cable is very fragile. If you are replacing the battery, you can choose to skip this step and keep the headphone jack connected to the motherboard. Prop and tape the rear case against a box to keep it in place. Be very careful not to strain the fragile headphone jack cable as you work.
  5. iPod 4th Generation or Photo Headphone Jack Bracket Replacement, Headphone Jack Bracket: 5 단계, 이미지 1/1
    • Remove the 2 silver T6 Torx screws from the headphone jack.
  6. iPod 4th Generation or Photo Headphone Jack Bracket Replacement: 6 단계, 이미지 1/1
    • Remove the 3 silver Philips screws securing the headphone jack to the rear panel.
  7. iPod 4th Generation or Photo Headphone Jack Bracket Replacement: 7 단계, 이미지 1/1
    • Grasp the white headphone jack bracket and lift it out of the iPod.
결론
다른 4명이 해당 안내서를 완성하였습니다.
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 한 개
Acquistando il ricambio "headphone jack bracket" viene fornito anche il flat cable con connettore?
Purtroppo a me si è staccato il connettore dal flat cable e non viene fornito come ricambio, la speranza è che che comperando l' "headphone jack bracket" venga fornito con flat e connettore.
Grazie a tutti!
albidu-vacation - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 21
전체 시간: 8,641
