소개
No audio? Replace the headphone jack!
Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
After all five tabs along the right side are free, the case should easily open.
다른 19명이 해당 안내서를 완성하였습니다.
댓글 4개
How do you add a "confirmed success"? This worked perfectly for me. Thanks iRobot!
I agree that these pry tools pretty low quality. They did work faster than the guitar picks I've used in the past, but the material is just not durable. They were pretty much destroyed after one case opening.
The instructions are great, however when you ask about spares required there is no mention of the ribbon cable I require, just the board assembly!
Hi
Where can I buy these components?
Thanks
