주요 콘텐츠로 건너뛰기
iPod 4th generation or Photo hard drive replacement by micro SD card
필요한 것
  1. iPod 4th generation or Photo hard drive replacement by micro SD card, Rear Panel: 1 단계, 이미지 1/1
    • Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
  2. iPod 4th generation or Photo hard drive replacement by micro SD card: 2 단계, 이미지 1/3 iPod 4th generation or Photo hard drive replacement by micro SD card: 2 단계, 이미지 2/3 iPod 4th generation or Photo hard drive replacement by micro SD card: 2 단계, 이미지 3/3
    • Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
    • You may need to rock the pick back and forth to slide it in farther.
    • Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
    • Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
    • After all five tabs along the right side are free, the case should easily open.
  3. iPod 4th generation or Photo hard drive replacement by micro SD card: 3 단계, 이미지 1/1
    • The iPod case is now open, but don't separate the two halves just yet. There is still an orange ribbon cable connecting the headphone jack to the logic board.
    • Open the case like a book with the dock connector edge at the top, and lay the rear panel next to the front half of the iPod.
  4. iPod 4th generation or Photo hard drive replacement by micro SD card: 4 단계, 이미지 1/1
    • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
    • This ribbon cable is very fragile. If you are replacing the battery, you can choose to skip this step and keep the headphone jack connected to the motherboard. Prop and tape the rear case against a box to keep it in place. Be very careful not to strain the fragile headphone jack cable as you work.
  5. iPod 4th generation or Photo hard drive replacement by micro SD card, Removing the hard drive disk: 5 단계, 이미지 1/2 iPod 4th generation or Photo hard drive replacement by micro SD card, Removing the hard drive disk: 5 단계, 이미지 2/2
    • Remove the hard drive with your hand, by holding both the iPod and hard drive connector (hold tight in order to not broke the connector).
  6. iPod 4th generation or Photo hard drive replacement by micro SD card, Assemble the storage unit: 6 단계, 이미지 1/3 iPod 4th generation or Photo hard drive replacement by micro SD card, Assemble the storage unit: 6 단계, 이미지 2/3 iPod 4th generation or Photo hard drive replacement by micro SD card, Assemble the storage unit: 6 단계, 이미지 3/3
    • Put the micro sd card into the CF adapter.
    • Then put the CF adapter into the CE to CF 1.8" adapter.
  7. iPod 4th generation or Photo hard drive replacement by micro SD card, (optional) Remove the hard drive disk connector stopper: 7 단계, 이미지 1/1
    • Depending on the CE adapter you have, you may need to remove the stopper on the hard drive disk connector on the iPod. Use tweezers to do so.
    • If you notice that you can't fully plug your new memory unit without this step do this, else your memory unit may not be recognized.
  8. iPod 4th generation or Photo hard drive replacement by micro SD card, Plug your storage unit: 8 단계, 이미지 1/2 iPod 4th generation or Photo hard drive replacement by micro SD card, Plug your storage unit: 8 단계, 이미지 2/2
    • Plug your memory unit in place of the old hard drive.
    • It's normal that to have 4 free slots on the memory unit. Be sure to position the memory unit as on the photo.
    • It may be usefull to use double face tape on the battery to ensure the storage unit won't move.
    • Storage unit being thicker than an hard drive, adding a card board on it may help keeping everythin in place while reassembling.
  9. iPod 4th generation or Photo hard drive replacement by micro SD card, Reconnect bottom case connector: 9 단계, 이미지 1/1
    • Reconnect the bottom case connector. Before reassembling the iPod.
  10. iPod 4th generation or Photo hard drive replacement by micro SD card, Connect your iPod to your PC: 10 단계, 이미지 1/1
    • Don't reassemble your iPod before connecting it to your PC. The opening step is the hardest part, in case of mistake you won't have to reopen it.
    • Just put the top case on the bottom one without pushing.
  11. iPod 4th generation or Photo hard drive replacement by micro SD card, (optional) Install iPod support on your computer: 11 단계, 이미지 1/1
    • After connecting the iPod to the PC you may need to install iPod support. Follow iTunes instructions. Unplug the iPod, Restart iTunes, Restart your PC. Replug the iPod.
  12. iPod 4th generation or Photo hard drive replacement by micro SD card, Restore the iPod (software): 12 단계, 이미지 1/1
    • Once connected to your computer, iTunes will tell you that the iPod needs to be restored. Follow iTunes instructions to restore the software.
  13. iPod 4th generation or Photo hard drive replacement by micro SD card, Plug your iPod to a wall plug: 13 단계, 이미지 1/2 iPod 4th generation or Photo hard drive replacement by micro SD card, Plug your iPod to a wall plug: 13 단계, 이미지 2/2
    • The iPod will prompt you to plug it to a wall plug. While this screen is displayed you can't continue.
    • Pluging the iPod to the computer is not enough. If it doesn't work check the power adapter or the iPod cable. iPhone wall adapter (1A) is sufficient for this task.
    • If it reboots to the iPod menu (language settings) you have finished.
  14. iPod 4th generation or Photo hard drive replacement by micro SD card, Finalize the software restoration process: 14 단계, 이미지 1/3 iPod 4th generation or Photo hard drive replacement by micro SD card, Finalize the software restoration process: 14 단계, 이미지 2/3 iPod 4th generation or Photo hard drive replacement by micro SD card, Finalize the software restoration process: 14 단계, 이미지 3/3
    • Finalize the software restoration process by accepting the Apple license.
  15. iPod 4th generation or Photo hard drive replacement by micro SD card, Test iPod before reassembling: 15 단계, 이미지 1/2 iPod 4th generation or Photo hard drive replacement by micro SD card, Test iPod before reassembling: 15 단계, 이미지 2/2
    • It's important that you check everything, from charging to synchronizing and listenning to music before reassembling the iPod.
    • If something is not functionning properly, double check each steps.
결론
To reassamble your iPod follow the steps in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Marc_Alx
회원 가입일: 02/27/22
349 평판
안내서 1개 작성함
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 34
7일 전: 160
30일 전: 580
전체 시간: 4,359
