주요 콘텐츠로 건너뛰기
iPod 5th Generation (Video) Front Faceplate Replacement
필요한 것
  1. iPod 5th Generation (Video) Front Faceplate Replacement, Open your iPod.: 1 단계, 이미지 1개 중 1개
    • Take caution while opening your iPod, making sure not to rip any ribbon cables.
    • You can use things such as a guitar pick or spudger to pry open the iPod.
  2. iPod 5th Generation (Video) Front Faceplate Replacement, Unplug the iPod's battery ribbon cable: 2 단계, 이미지 1개 중 1개
    • Gently unplug the battery ribbon cable from the iPod and lift up the back shell.
    • Make sure the iPod looks like the image shown.
  3. iPod 5th Generation (Video) Front Faceplate Replacement, Pry the frontplate off of the frame that holds the motherboard: 3 단계, 이미지 2개 중 1개 iPod 5th Generation (Video) Front Faceplate Replacement, Pry the frontplate off of the frame that holds the motherboard: 3 단계, 이미지 2개 중 2개
    • Using a spudger or pick, gently pry the frontplate off of the iPod's frame that holds internals such as the screen, motherboard, etc.
    • Your iPod should look like the second image when this step is completed.
  4. iPod 5th Generation (Video) Front Faceplate Replacement, Installing the new frontplate: 4 단계, 이미지 2개 중 1개 iPod 5th Generation (Video) Front Faceplate Replacement, Installing the new frontplate: 4 단계, 이미지 2개 중 2개
    • First, install the middle button that came with your new frontplate by lifting up the click wheel and simply clicking the center button into place.
    • Then, install the frontplate by just aligning the frontplate with the iPod frame and pressing it down into place until all the clips click together.
  5. iPod 5th Generation (Video) Front Faceplate Replacement, Plug the battery ribbon cable back in: 5 단계, 이미지 1개 중 1개
    • Before closing the iPod, make sure you reconnect the battery ribbon cable.
    • Be careful not to rip it!
  6. iPod 5th Generation (Video) Front Faceplate Replacement, Close your iPod and try to turn it on: 6 단계, 이미지 2개 중 1개 iPod 5th Generation (Video) Front Faceplate Replacement, Close your iPod and try to turn it on: 6 단계, 이미지 2개 중 2개
    • Once you've completed everything and closed your iPod, try and turn it on by pressing any button on the click wheel. If it turns on and everything works without issue, than you've successfully completed this guide!
    • But, if something doesn't work after replacing it, such as there being no sound or the screen is not displaying things correctly, reopen the iPod and examine the ribbon cables and capacitors to make sure none are missing or ripped.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
appealingapple
회원 가입일: 03/26/23
217 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 61
지난 30일: 266
전체 시간: 4,666
