소개
Instructions on how to open a iPod 5th Generation
Insert the iFixit opening tool into the left side of the iPod, with the edge of the tool pointing towards the metal back.
A small guitar pick can be extremely helpful in opening the iPod. Simply insert it and slide the pick around the case to free the clips to streamline the process.
Gently enlarge the existing crevice by wiggling the iFixit opening tool and moving it to the left.
Continue doing so until the entire side of the iPod is loose.
You can then insert an iPod opening tool to the right of the Hold button.
Gently glide the iFixit opening tool on the top of the display, making sure to free the retaining clips.
The other sides of the iPod should now easily come loose. If they do not, use iFixit opening tools on the right side of the iPod in the same way as on the left side of the iPod.
Be sure to separate the front of the iPod from the back about an inch (or a couple of centimeters).
To reassemble your device do the instructions in reverse order
다른 4명이 해당 안내서를 완성하였습니다.
