주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPod Mini Display Replacement
필요한 것
    1. iPod Mini Display Replacement, Top Bezel: 1 단계, 이미지 1개 중 1개
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      댓글 쓰기
    2. iPod Mini Display Replacement: 2 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Jimmy
      $7.95
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
      • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
      • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
      댓글 쓰기
    3. iPod Mini Display Replacement: 3 단계, 이미지 1개 중 1개
      • Lift the top bezel off of the iPod.
      댓글 쓰기
    1. iPod Mini Display Replacement, Bottom Bezel: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Jimmy
      $7.95
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
      댓글 쓰기
    2. iPod Mini Display Replacement: 5 단계, 이미지 1개 중 1개
      • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
      • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
      댓글 쓰기
    3. iPod Mini Display Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the metal retaining bracket out of the iPod.
      댓글 쓰기
    1. iPod Mini Display Replacement, Display: 7 단계, 이미지 1개 중 1개
      • Be careful, this connector is fragile.
      • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
      댓글 쓰기
    2. iPod Mini Display Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the two #00 Phillips screws securing the headphone jack to the casing.
      댓글 쓰기
    3. iPod Mini Display Replacement: 9 단계, 이미지 1개 중 1개
      • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
      • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
      댓글 쓰기
    4. iPod Mini Display Replacement: 10 단계, 이미지 1개 중 1개
      • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
      댓글 쓰기
    5. iPod Mini Display Replacement: 11 단계, 이미지 1개 중 1개
      • Lift the battery off of the logic board and lay it to the side of the iPod.
      댓글 쓰기
    6. iPod Mini Display Replacement: 12 단계, 이미지 1개 중 1개
      • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
      • This tab is fragile so be careful not to break it.
      댓글 쓰기
    7. iPod Mini Display Replacement: 13 단계, 이미지 1개 중 1개
      • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
      댓글 쓰기
    8. iPod Mini Display Replacement: 14 단계, 이미지 1개 중 1개
      • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
      댓글 쓰기
    9. iPod Mini Display Replacement: 15 단계, 이미지 1개 중 1개
      • Turn the iPod over.
      • Carefully lift the display up and slide it out of its connector.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 27명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
2가이드 댓글
Hey when I tried to lift up the tab ,it came out flying what to do now ?
Vatsal - 답글 공유
I can't get the logic board to slide out. What should I use? Do you think heat would help
Ohdoh - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 56
지난 30일: 219
전체 시간: 42,908
