주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. iPod Nano 1st Generation 수리는 저희 서비스 설명서를 사용하십시오.
  1. iPod Nano 1st Generation Teardown, Open The iPod: 1 단계, 이미지 1/2 iPod Nano 1st Generation Teardown, Open The iPod: 1 단계, 이미지 2/2
    • 1. Using an ipod unclipping tool (which could be a knife or similar to it), unclip the outer casing by putting the tool up to the connection point. This should pop the case off. Note that force will need to be used.
  2. iPod Nano 1st Generation Teardown: 2 단계, 이미지 1/1
    • 2. Remove the circuit board by unscrewing the 3 screws (there is 1 more screw but dont unscrew it, it holds the headphone jack) that hold it down. Note that specialised screwdrivers may need to be used.
  3. iPod Nano 1st Generation Teardown: 3 단계, 이미지 1/2 iPod Nano 1st Generation Teardown: 3 단계, 이미지 2/2
    • 3. Carefully remove the connected wires underneath the motherboard to disconnect the clickwheel and the screen.
  4. iPod Nano 1st Generation Teardown: 4 단계, 이미지 1/3 iPod Nano 1st Generation Teardown: 4 단계, 이미지 2/3 iPod Nano 1st Generation Teardown: 4 단계, 이미지 3/3
    • 4. The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover.
  5. iPod Nano 1st Generation Teardown: 5 단계, 이미지 1/3 iPod Nano 1st Generation Teardown: 5 단계, 이미지 2/3 iPod Nano 1st Generation Teardown: 5 단계, 이미지 3/3
    • 5. Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply and carefully pull them off.
  6. iPod Nano 1st Generation Teardown: 6 단계, 이미지 1/1
    • 6. Finally you should have the ipod dismantelled and you should be able to put the ipod back together.
Craig Lawrence
회원 가입일: 03/11/10
444 평판
안내서 1개 작성함
댓글 6개
when i put the rear cover back on, the charging station doesn't line up correctly and the charging station sticks out a bit. any advice?
krnchang - 답글
is the batter swollen
Derek King - 답글
Yes, happened to a Zune 80 I have
CTCL -
Thank you for this - took the fear factor out of changing battery on my much loved Nano!
jimbradshaw - 답글
It’s extremely hard to connect LCD and Button cables. I screwed it up while reconnecting the cables. IF, you want to disassemble this machine by fun, don’t ever try it.
Sizun Cho - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 31
30일 전: 144
전체 시간: 28,545
