주요 콘텐츠로 건너뛰기
iPod Nano 2nd Generation Top Bezel Replacement
필요한 것
  1. iPod Nano 2nd Generation Top Bezel Replacement, Top Bezel: 1 단계, 이미지 1/1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod Nano 2nd Generation Top Bezel Replacement: 2 단계, 이미지 1/1
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top.
    • Lift the top bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
결론
다른 12명이 해당 안내서를 완성하였습니다.
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 2개
But how do I install it on? Do I just push it back? I want to fix mine but it doesn't even have the top part anymore, or the hold switch
luis - 답글
I would recommend that you put some new adhesive on there. All you have to do is put the switch in its place and put on a new top and push it down.
Ad123re -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 29
전체 시간: 18,891
