이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
Pry the top bezel off the adhesive securing it to the display retainer.
Remove the two angled Phillips screws from the two corners of the display retainer.
Insert an iPod opening tool between the outer case and the display retainer.
Use the tool to slide the display assembly out of the case slightly.
Slide the display out of the Nano. It will move about .5" until the display data cable limits its travel.
With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
다른 30명이 해당 안내서를 완성하였습니다.
