주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPod Nano 6th Generation Logic Board Assembly Replacement
필요한 것
    1. iPod Nano 6th Generation Logic Board Assembly Replacement, Front Panel Assembly: 1 단계, 이미지 1개 중 1개
      • Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
      • Be careful not to overheat the front panel assembly, as it may result in damage to the LCD.
      댓글 쓰기
    2. iPod Nano 6th Generation Logic Board Assembly Replacement: 2 단계, 이미지 1개 중 1개
      • While the front panel is still warm, use the edge of an opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
      • Do not attempt to pry out the front panel assembly from, or insert the opening tool into the left side of the display, as the display data cable is right underneath and may be damaged in the process.
      • Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
      • If the front panel is excessively difficult to lift out of the outer case, reheat the area and try again.
      댓글 쓰기
    3. iPod Nano 6th Generation Logic Board Assembly Replacement: 3 단계, 이미지 2개 중 1개 iPod Nano 6th Generation Logic Board Assembly Replacement: 3 단계, 이미지 2개 중 2개
      • Lift the front panel assembly from the headphone jack side of the Nano.
      • Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
      • The front panel assembly is still attached to the Nano by two cables.
      댓글 쓰기
    4. iPod Nano 6th Generation Logic Board Assembly Replacement: 4 단계, 이미지 1개 중 1개
      • Lay the front panel assembly next to the Nano.
      • Remove the following two screws:
      • One 2.3 mm Phillips screw
      • One 2.6 mm shouldered Phillips screw
      댓글 쓰기
    5. iPod Nano 6th Generation Logic Board Assembly Replacement: 5 단계, 이미지 2개 중 1개 iPod Nano 6th Generation Logic Board Assembly Replacement: 5 단계, 이미지 2개 중 2개
      • Use an opening tool to pry the steel shield out of the Nano by its upper right corner.
      • Remove the steel shield from the Nano.
      댓글 쓰기
    6. iPod Nano 6th Generation Logic Board Assembly Replacement: 6 단계, 이미지 2개 중 1개 iPod Nano 6th Generation Logic Board Assembly Replacement: 6 단계, 이미지 2개 중 2개
      • Use an opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board.
      댓글 쓰기
    7. iPod Nano 6th Generation Logic Board Assembly Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the front panel assembly, minding its two cables that may get caught.
      • To reassemble, you can use the double-sided tape found here.
      댓글 쓰기
    1. iPod Nano 6th Generation Logic Board Assembly Replacement, Logic Board Assembly: 8 단계, 이미지 1개 중 1개
      • Use an iPod opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
      댓글 쓰기
    2. iPod Nano 6th Generation Logic Board Assembly Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the single 1.9 mm Phillips screw securing the logic board to the outer case.
      댓글 쓰기
    3. iPod Nano 6th Generation Logic Board Assembly Replacement: 10 단계, 이미지 2개 중 1개 iPod Nano 6th Generation Logic Board Assembly Replacement: 10 단계, 이미지 2개 중 2개
      • Use an iPod opening tool to gently pry the battery up from the adhesive securing it to the outer case.
      • The adhesive is very strong. Work carefully and slowly, making sure to not slip and break any fragile components.
      • Use your thumb to pull the battery toward the left side of the Nano as you pry the battery's other edge out of the outer case.
      댓글 쓰기
    4. iPod Nano 6th Generation Logic Board Assembly Replacement: 11 단계, 이미지 1개 중 1개
      • Use an iPod opening tool to gently pry the logic board off the adhesive holding it against the outer case.
      • Do not excessively pry the logic board upward.
      댓글 쓰기
    5. iPod Nano 6th Generation Logic Board Assembly Replacement: 12 단계, 이미지 2개 중 1개 iPod Nano 6th Generation Logic Board Assembly Replacement: 12 단계, 이미지 2개 중 2개
      • Use your iPod opening tool to gently push the dock connector toward the center of the Nano.
      • Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 65명이 해당 안내서를 완성하였습니다.
9가이드 댓글
Hi, i wonder if you could help me... I changed my cracked screen (my ipod worked even though the screen was broken) but then when I assembled the ipod ( I did everything you did) it doesn't work, nor does my computer recognize it anymore. Would you happen to know what might be the problem? Have I unintentionally somehow damaged it?
d1k4 - 답글 공유
Thanks for the guide Andrew! I've just replaced my cracked screen and everything works flawlessly.
Cristian Dragos - 답글 공유
Is there any where to send them in and have a professional repair them. I’ve tired some of the things on the site but I think I may have damaged them further? Please advise.
Valerie - 답글 공유
Hi..just to tell u about my ipod. It was accidentaly washed in my washing machine. I want to know..is the ipod still in function if i replace the battery only not the board. Im still hoping that my ipod still can be use. I love my ipod 6th generation. It has sentimental value to me..huhu
madeq 78 - 답글 공유
I did the very same thing, washed my 6th gen in the washer. when i realized what i had done, i immediately put the ipod in a tub of rice. now it works, but only when it’s plugged in. I’m pretty sure it’s the battery that needs replacing. I’ve not replaced the battery as all of the things i need from ifixit are out of stock. If everything on the ipod works except that it won’t hold a charge and stay on unless plugged in, then it’s most likely the battery and replacing it will probably fix the problem.
thefactory01 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 26
지난 7일: 50
지난 30일: 153
전체 시간: 112,002
