소개
Use this guide to replace a broken screen or restore touch functionality to your 7th Generation iPod Nano.
필요한 것
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the iOpener over the plastic tab to loosen the adhesive. Let the bag sit on the device for approximately 90 seconds before attempting to open the panel.
Insert a spudger under the metal midframe and display on the left side of the home button.
Rotate the spudger around the home button and across the front panel, releasing the adhesive holding the display in place.
Use the flat end of a spudger to push the home button gasket toward the center of the button to release the light adhesive.
Work your way around the home button in this manner until you can easily remove the button from the front glass.
다른 29명이 해당 안내서를 완성하였습니다.
댓글 10개
Tried everything to loosen the adhesive around the metal midframe... Nothing worked, and finally (after a lot of prying) I managed to get it out... only to have damaged the lcd digitizer underneath the screen!
If you're going to attempt this, have a spare digitizer nearby, and be willing to fail. After spending $60+ on parts and tools, i'm worse off then where I started.
I have no idea how this is considered moderate, meanwhile the Classic is considered very difficult.
Hi! Where can I find in US a front glass replacement for my iPod Nano 7th? Do you know a website to get it? Please write me to tavoacevedom@yahoo.es. Thks.
did you find a glass? I am also looking for one.... hbsamat@yahoo.com
So far, so bad. I left the iopener on there for 90 seconds. Not loose at all. Heated it again a little longer and left on for a little longer. Still not loose at all. Pried and pried and BROKE THE BLUETOOTH ANTENNA!!!! Still soldiering on, but the front part is not coming loose either. Beginning to regret the attempt big time.
