주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
iPod Nano 7th Generation Front Panel Assembly Replacement
단지 전제 조건
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
필요한 것
  1. iPod Nano 7th Generation Front Panel Assembly Replacement, Front Panel Assembly: 1 단계, 이미지 1/2 iPod Nano 7th Generation Front Panel Assembly Replacement, Front Panel Assembly: 1 단계, 이미지 2/2
    • Lay the iOpener over the plastic tab to loosen the adhesive. Let the bag sit on the device for approximately 90 seconds before attempting to open the panel.
  2. iPod Nano 7th Generation Front Panel Assembly Replacement: 2 단계, 이미지 1/3 iPod Nano 7th Generation Front Panel Assembly Replacement: 2 단계, 이미지 2/3 iPod Nano 7th Generation Front Panel Assembly Replacement: 2 단계, 이미지 3/3
    • Use a plastic opening tool to pull the rear plastic cover away from the device until there is enough room to insert a spudger.
    • Insert a spudger under the cover, then pry it up and away from the device.
    • Remove the rear plastic cover from the iPod.
    • Be very careful in removing the plastic cover as the bluetooth antenna is adhered to it.
  3. iPod Nano 7th Generation Front Panel Assembly Replacement: 3 단계, 이미지 1/1
    • Gently bend the Bluetooth antenna to the right, out of the way of the screws in the bottom of the device.
    • Remove the single 1.4 mm Phillips #000 screw from the black plastic spacer.
  4. iPod Nano 7th Generation Front Panel Assembly Replacement: 4 단계, 이미지 1/2 iPod Nano 7th Generation Front Panel Assembly Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to remove the black plastic spacer from the Nano.
  5. iPod Nano 7th Generation Front Panel Assembly Replacement: 5 단계, 이미지 1/1
    • Remove the two 2 mm Phillips #000 screws from the bottom of the case.
  6. iPod Nano 7th Generation Front Panel Assembly Replacement: 6 단계, 이미지 1/2 iPod Nano 7th Generation Front Panel Assembly Replacement: 6 단계, 이미지 2/2
    • Insert a plastic opening tool into the seam between the white plastic front panel and the rear case.
    • Slide the opening tool along the edge of the front panel to free it from clips and adhesive.
  7. iPod Nano 7th Generation Front Panel Assembly Replacement: 7 단계, 이미지 1/1
    • Use a spudger to press the midframe screw tab up and out of the rear case.
  8. iPod Nano 7th Generation Front Panel Assembly Replacement: 8 단계, 이미지 1/1
    • Use a metal spudger to carefully pry near the Lightning connector and under all parts of the front panel assembly: the front glass/digitizer, the LCD display and the metal midframe.
    • The adhesive under the metal midframe/display assembly is quite strong and the components are fragile, so go slowly and gently. Make sure you do not bend the LCD screen.
  9. iPod Nano 7th Generation Front Panel Assembly Replacement: 9 단계, 이미지 1/2 iPod Nano 7th Generation Front Panel Assembly Replacement: 9 단계, 이미지 2/2
    • Continue prying along the edges under the front panel assembly, releasing the clips and adhesive along the sides of the device.
  10. iPod Nano 7th Generation Front Panel Assembly Replacement: 10 단계, 이미지 1/2 iPod Nano 7th Generation Front Panel Assembly Replacement: 10 단계, 이미지 2/2
    • Pull the front panel assembly slightly down and partially out of the device.
    • You only need to open the device enough to gain access to the display cable connectors near the sleep/power button.
    • Do not separate the two halves entirely, they are still connected by several cables.
  11. iPod Nano 7th Generation Front Panel Assembly Replacement: 11 단계, 이미지 1/2 iPod Nano 7th Generation Front Panel Assembly Replacement: 11 단계, 이미지 2/2
    • Use a spudger to release the digitizer cable and display data cable connectors.
  12. iPod Nano 7th Generation Front Panel Assembly Replacement: 12 단계, 이미지 1/1
    • Gently unfold the two halves of the device to access the internal components.
    • Do not try to completely separate the two sections, yet, as they are still attached via a soldered cable.
  13. iPod Nano 7th Generation Front Panel Assembly Replacement: 13 단계, 이미지 1/2 iPod Nano 7th Generation Front Panel Assembly Replacement: 13 단계, 이미지 2/2
    • Pull up on the battery pull tab to free the battery from its adhesive.
    • Flip the battery over into the rear case for safekeeping.
  14. iPod Nano 7th Generation Front Panel Assembly Replacement: 14 단계, 이미지 1/1
    • Completely separate the front panel assembly from the rest of the device.
결론
Sam Goldheart
회원 가입일: 10/18/12
458,568 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,572개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 128
