주요 콘텐츠로 건너뛰기
iPod Shuffle 2nd Generation Logic Board Assembly Replacement
필요한 것
  1. iPod Shuffle 2nd Generation Logic Board Assembly Replacement, Logic Board Assembly: 1 단계, 이미지 1개 중 1개
    • Before beginning, be sure your Shuffle is turned off as shown.
  2. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 2 단계, 이미지 2개 중 1개 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Use the edge of an iPod opening tool to pry the plastic cover off the headphone jack side of the Shuffle.
    • Remove the plastic cover and set it aside.
  3. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws from the headphone jack side of the Shuffle.
  4. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 4 단계, 이미지 2개 중 1개 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Use the edge of an iPod opening tool to remove the steel cover from the headphone jack side of the Shuffle.
  5. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 5 단계, 이미지 2개 중 1개 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Use the edge of an iPod opening tool to pry the plastic cover off the controls side of the Shuffle.
  6. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 6 단계, 이미지 2개 중 1개 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the hold and shuffle sliders from the Shuffle.
  7. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws on the controls side of the Shuffle.
  8. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 8 단계, 이미지 2개 중 1개 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Use the edge of an iPod opening tool to remove the steel plate from the controls side of the Shuffle.
  9. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Use the edge of an iPod opening tool to slightly pry the steel plate on the headphone jack side of the Shuffle away from the lip cut into the outer case.
  10. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 10 단계, 이미지 2개 중 1개 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Use your iPod opening tool to push the logic board assembly out of the outer case enough to grab the logic board by its edges.
    • Pull the logic board assembly out of the outer case.
결론
다른 21명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Bookholt
596,422 평판
안내서 619개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 33
전체 시간: 19,938
