주요 콘텐츠로 건너뛰기
iPod Shuffle 3rd Generation Logic Board Replacement
필요한 것
  1. iPod Shuffle 3rd Generation Logic Board Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Logic Board Replacement: 2 단계, 이미지 2개 중 1개 iPod Shuffle 3rd Generation Logic Board Replacement: 2 단계, 이미지 2개 중 2개
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Logic Board Replacement: 3 단계, 이미지 1개 중 1개
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Logic Board Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
  5. iPod Shuffle 3rd Generation Logic Board Replacement, Logic Board: 5 단계, 이미지 1개 중 1개
    • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
  6. iPod Shuffle 3rd Generation Logic Board Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the single Phillips screw securing the logic board to the front case.
  7. iPod Shuffle 3rd Generation Logic Board Replacement: 7 단계, 이미지 1개 중 1개
    • Peel the battery up from the front case with an iPod opening tool.
    • Remove the logic board and battery from the iPod.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Matthew Newsom
회원 가입일: 01/05/10
41,975 평판
안내서 67개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 6,683
