필요한 것
1 단계 Front Panel
주의: 1-4 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Wedge the PX 3688 plastic opening tool between the glass front panel and the plastic frame. Start near the top where the volume control buttons are located and stay on one side of iPod.
Turn the tool in a hinge-like rotation away from the iPod and pry the glass panel out of its case.
Be careful to work at a slow and gentle pace. Avoid breaking anything inside the iPod, especially the screen.
Remove the Phillips screw in the top left corner attaching the metal tray to the rear panel.
Insert a PX 3688 plastic opening tool with the edge angled up, toward the underside of the display, between the white plastic backlight and the metal beneath it.
Pry the lower edge of the display up until it's at about a 45 degree angle with the rest of the iPod.
Hold the display in this position with one hand for the next step to avoid damaging the display ribbon cable.
12 단계 Logic Board
주의: 12-20 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Rotate the metal display tray to the top of the iPod, being careful of the ribbon connecting the battery to the logic board.
Use the flat end of a spudger to pry the battery off of the metal display tray.
Remove the metal display tray.
Place the battery back in the rear panel.
The headphone jack is attached to the logic board at five points.
Remove the old headphone jack from the logic board by prying the headphone jack ribbon off the logic board with the spudger.
다른 4명이 해당 안내서를 완성하였습니다.
