주요 콘텐츠로 건너뛰기
iPod Touch 5th Generation Battery Replacement
필요한 것
    • Follow this video guide from start to finish and enjoy!
결론
Did you follow all the steps? Yes! Then enjoy!
다른 28명이 해당 안내서를 완성하였습니다.
Fix It Planet
회원 가입일: 05/29/15
1,531 평판
안내서 3개 작성하였습니다
22 Comments
The solder in the video looks like a clear liquid, I’m I missing something. I’m used to solder that looks like wire? Is there something new that is easier to use?
Thanks for putting this up, I’m trying to decide if I can do the soldering and I just want to make sure I know what I’m getting myself into.
Joshua Edwards - 답글
Sorry for the confusion. That clear liquid is actually flux. The solder has been put on the iron tip prior to soldering the pads. Not much solder is needed but the flux is necessary to help the flow and bonding of the solder.
Fix It Planet - 답글
What kind of wick do you use?
Nick DeRissio - 답글
Goot wick. Model: CP - 2015 Width: 2 mm
Fix It Planet -
Could I use an IOpener tool to open the ipod?
Best Songs - 답글
댓글 쓰기
조회 통계:
24 시간 전: 13
7일 전: 105
30일 전: 547
전체 시간: 32,996
