주요 콘텐츠로 건너뛰기
소개
Prerequisite for entire button ribbon cable, volume buttons, power button, and rear case.
부품
지정된 부품이 없습니다.
  1. iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: 1 단계, 이미지 1/3 iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: 1 단계, 이미지 2/3 iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: 1 단계, 이미지 3/3
    • Insert the flat end of a spudger between the rear-facing camera and its frame.
    • Gently twist the spudger to free the camera.
    • Lift the rear-facing camera up out of its socket, and remove it from the iPod Touch.
  2. iPod Touch 5th Generation Rear-Facing Camera Replacement: 2 단계, 이미지 1/3 iPod Touch 5th Generation Rear-Facing Camera Replacement: 2 단계, 이미지 2/3 iPod Touch 5th Generation Rear-Facing Camera Replacement: 2 단계, 이미지 3/3
    • Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable.
    • Run the spudger along the full length of the tape to disconnect it from the rear case.
  3. iPod Touch 5th Generation Rear-Facing Camera Replacement: 3 단계, 이미지 1/2 iPod Touch 5th Generation Rear-Facing Camera Replacement: 3 단계, 이미지 2/2
    • Peel and remove the foam tape from the rear case of the iPod.
  4. iPod Touch 5th Generation Rear-Facing Camera Replacement: 4 단계, 이미지 1/3 iPod Touch 5th Generation Rear-Facing Camera Replacement: 4 단계, 이미지 2/3 iPod Touch 5th Generation Rear-Facing Camera Replacement: 4 단계, 이미지 3/3
    • Use the tip of a spudger to peel up the edge of the tape covering the button ribbon cable.
    • Use tweezers or your fingers to peel the tape up from the rear case, and remove it from the iPod.
결론
Andrew Optimus Goldheart
회원 가입일: 2009년 10월 17일
488,373 평판
안내서 410개 작성하였습니다
iFixit iFixit 회원
Community
146 회원들
안내서 15,632개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 77
