이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
Pry the rear case away from the front case.
Lift the bottom of the rear case and remove it from the rest of the iPod.
Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
Remove the single Phillips screw securing the logic board to the front case.
Peel the battery up from the front case with an iPod opening tool.
Remove the logic board and battery from the iPod.
Using the pointed tip of a spudger, push the shuffle switch in to separate it from the front case.
다른 2명이 해당 안내서를 완성하였습니다.
