소개
In this replacement guide the user will learn how to disassemble the iRULU down to the logic board, and replace the battery.
필요한 것
Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
The battery is located right above the logic board, and can be identified as a large flat black rectangle.
Use the plastic opening to scrape away the glue that is holding down the battery.
이 단계에 사용된 도구:Desoldering Pump$3.99
You should see that the battery is connected by 2 wires, one black and one red that lead to the logic board.
Heat up a soldering iron and melt the solder that is connecting the battery to the logic board.
Completely remove the battery from the device.
Insert the new battery and re-solder the corresponding wires to their respective locations.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
Where do you get a new battery
The batteries should be in a holder, not have to unsolder and solder. Most people do not have a soldering iron.
