주요 콘텐츠로 건너뛰기
iRULU AX106 Disassembly
필요한 것
  1. iRULU AX106 Disassembly, iRULU AX106 Disassembly: 1 단계, 이미지 1/1
    • Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
    • There may be plastic covers protecting the screws, if this is the case take a phillips head screwdriver, and gently apply pressure on the covers until they come off.
  2. iRULU AX106 Disassembly: 2 단계, 이미지 1/2 iRULU AX106 Disassembly: 2 단계, 이미지 2/2
    • Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
    • While a good deal of force is required to separate the screen from the case, make sure to separate the screen from the case at each corner before attempting to completely remove the screen. There are delicate wires that may be damaged if the screen is removed is before the corners are separated.
  3. iRULU AX106 Disassembly: 3 단계, 이미지 1/3 iRULU AX106 Disassembly: 3 단계, 이미지 2/3 iRULU AX106 Disassembly: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers, gently unplug connectors A and B from the logic board.
    • Completely separate the screen and case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Andrew Mele
회원 가입일: 03/24/15
146 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G7
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 2,653
