주요 콘텐츠로 건너뛰기
iRULU AX106 Logic Board Replacement
필요한 것
  1. iRULU AX106 Logic Board Replacement, iRULU AX106: 1 단계, 이미지 1개 중 1개
    • Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
    • There may be plastic covers protecting the screws, if this is the case take a phillips head screwdriver, and gently apply pressure on the covers until they come off.
  2. iRULU AX106 Logic Board Replacement: 2 단계, 이미지 2개 중 1개 iRULU AX106 Logic Board Replacement: 2 단계, 이미지 2개 중 2개
    • Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
    • While a good deal of force is required to separate the screen from the case, make sure to separate the screen from the case at each corner before attempting to completely remove the screen. There are delicate wires that may be damaged if the screen is removed is before the corners are separated.
  3. iRULU AX106 Logic Board Replacement: 3 단계, 이미지 3개 중 1개 iRULU AX106 Logic Board Replacement: 3 단계, 이미지 3개 중 2개 iRULU AX106 Logic Board Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
  4. iRULU AX106 Logic Board Replacement, Logic Board: 4 단계, 이미지 2개 중 1개 iRULU AX106 Logic Board Replacement, Logic Board: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • Locate where the speaker wires are attached to the logic board, and use a soldering iron and solder sucker to remove the wires from the board.
    • Then, locate the wires connecting the logic board to the battery and desolder them the same way.
    • The soldering iron is extremely hot. Please use caution when using these tools.
  5. iRULU AX106 Logic Board Replacement: 5 단계, 이미지 2개 중 1개 iRULU AX106 Logic Board Replacement: 5 단계, 이미지 2개 중 2개
    • Completely remove the old logic board, being careful not to damage any wires
    • Place the new logic board exactly where the old one was located. Leave the wires in an easily accessible position.
    • Solder the wires in the corresponding places exactly where you disconnected them from the old logic board.
결론
작성자
3다른 기여자 명과 함께
Victoria Holbrook
회원 가입일: 03/24/15
15 평판
안내서 1개를 작성함
UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G7
3 회원들
안내서 8개를 작성함
1가이드 댓글
very very good¡¡¡¡
jorgemcglez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 983
